brakes locking up
Old 08-04-2005, 09:16 PM
tacoma_tns's Avatar
Default brakes locking up
I have a '92 honda accord lx. I have had problems with my brakes locking up (i.e., when I'm driving and stepping on my brake pedal, each time I step on it, it gets stiffer and stiffer until you can't even step on it anymore and the brakes are locked so that if I'm stepping on the gas, the car won't move even an inch). After I shut the car off and let it cool off for 30-45 minutes, the brakes are fine again. I took it in to Firestone and they changed the master cylinder, hose, and the calipers and it is still acting up. Does anyone know what's the diagnosis? People I have talked to ask did they bleed the brakes? But that should be standard procedure. Any help would be much appreciated.
Old 08-04-2005, 09:39 PM
deserthonda's Avatar
Default Re: brakes locking up (tacoma_tns)
wow they replaced a bunch of things... well first off i would get the money back or store credit since what they replaced did not fix the problem ....when u say they replaced the hose which hose ???? or do u mean hoses like brake hoses all 4 ,,,,did they chk the rear brakes at all?? somehing could be hanging up back there ,,, 1 more thing if the booster goes bad it would give u a hard pedal but i have never heard it to make brakes lock up ..
Old 08-05-2005, 06:27 AM
4thgen's Avatar
yeah, they sure did go right into it. Did it act differently at all when you got it back? Did firestone's mechanic even try driving it?
Old 08-05-2005, 06:56 AM
tacoma_tns's Avatar
I first changed the master cylinder because the brake pedal was sinking to the ground. After that is when the brakes started to lock up.
Firestone did take it for a test drive and they couldn't replicate the problem, but they claim it was the brake hose. So they changed the 2 hoses in the front. However, the problem occurred again when I took it home. You usually have to drive it for about 30 minutes thru the city because that requires a lot of brake usage. then u can slowly feel the brake pedal getting stiffer and stiffer. Then when I took it back in again, they test drived it and this time replicated the problem and said it was the calipers. They did this for free. However, yesterday it locked up again. It is the front brakes because the smoke and smell of the brakes burning is coming from the front.
Old 08-05-2005, 07:16 AM
well amigo u got a brake master cylinder problem you probably put a cheap autozone 1 get a master from honda ...................the way u wrote it u made it sound that they replaced the master cylinder if i had know you had replaced it previousely i would have told you to go there,,,,,,,,,,,,,,,i have seen this happen a lot with many cheap aftermarket brake master cylinders the push rod is way out of adjustment ,,all they got to do is readjust the brake master push rod i bet that will fix ur problem but i would still put a honda master cylinder.......
oh and i still get my money back from firestone for misdiagnosing it
Old 08-07-2005, 10:00 PM
yo tacoma what was the fix???
Old 08-07-2005, 10:53 PM
Eddiebx's Avatar
did you make sure u used the right master cylinder? if you have the wrong one thats slightly off, it can cause your brakes to be stuck, this is because the push rod lengths are slightly different
Old 08-07-2005, 11:28 PM
honda91accord's Avatar
maybe its time to go to firestone and kick some ***
Old 08-08-2005, 09:39 PM
Default Re: brakes locking up (honda91accord)
yo amigo what was the problem???
kfw5045
08-20-2014 10:29 AM
JDMPR
07-18-2009 02:09 PM
mikensu
12
05-09-2005 01:22 PM
zdimka
05-31-2004 01:09 PM
Quick Reply: brakes locking up
