ls vtec vs. gsr
Old 07-29-2005, 10:49 AM
ej8hybrid's Avatar
Default ls vtec vs. gsr
what would u guys go with ls vtec or gsr? ohh and its going to be in a ek coupe
Old 07-29-2005, 10:52 AM
Ekay Jay's Avatar
Default Re: ls vtec vs. gsr (ek9slut)
Depends on your budget and what u want ta do to the motor. Ls/vtec's are some strong *** motors if built properly, but gsr motors can produce some big hp #'s also. So it really depends on your budget and hwtau want.
Old 08-01-2005, 03:56 PM
ej8hybrid's Avatar
Default Re: ls vtec vs. gsr (JdM DA InTeGrA)
i want to have a strong *** motor that pulls hard with good numbers
Old 08-01-2005, 03:59 PM
xEnderx's Avatar
Unless you are goign to make DAMN sure that it is done right then I'd go with a GSR. LSvtec's are really only worth the time and effort if you are goign to run high CR in my opinion.
Old 08-01-2005, 04:03 PM
Professor15's Avatar
which ever one you can get your hands on...if built right. BOTH motors can pull good numbers and good times. I would peice together a vtec motor though...ls/vtec or gsr dont matta.
Old 08-01-2005, 04:10 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9slut &raquo;</TD></TR><TR><TD CLASS="quote">i want to have a strong *** motor that pulls hard with good numbers</TD></TR></TABLE>
then get a ls block and resleeve and bore it to 85mm..etc but stock for stock lsvtec vs gsr i'd go for a gsr anyday
Old 08-01-2005, 04:18 PM
Default Re: ls vtec vs. gsr (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
then get a ls block and resleeve and bore it to 85mm..etc but stock for stock lsvtec vs gsr i'd go for a gsr anyday </TD></TR></TABLE>reasons?
Old 08-01-2005, 04:27 PM
ej8hybrid's Avatar
right now i have a gsr block with ctr pistons and b16 head should i keep or go with ls-v or b20-v
Old 08-22-2005, 06:14 PM
ej8hybrid's Avatar
bump bump bump it up
Old 08-22-2005, 06:48 PM
EG6R's Avatar
84mm vs 81mm? B20V
..until someone who never owned a B20 tells you that the sleeves are weak.
Old 08-22-2005, 09:14 PM
Propulsion's Avatar
Default Re: ls vtec vs. gsr (EG6R)
GSR for reliablity, also prices have come down so you are not saving any money building LSVTEC.
displacement difference is negligable.
Old 08-23-2005, 02:12 AM
Icey112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Depends on your budget and what u want ta do to the motor. Ls/vtec's are some strong *** motors if built properly, but gsr motors can produce some big hp #'s also. So it really depends on your budget and hwtau want.</TD></TR></TABLE> keep what you have poor mans type r ...
Old 08-23-2005, 06:02 AM
Natural Aspirations's Avatar
GSR block and LS crank. doesnt cost as much as you would think. you can pick up a complete GSR block for 400 and ad ls internals and you have the best of both worlds. PLus you dont have to mess around with the conversion. Total cost is prety close when you factor in the vtec conversion parts.
Old 08-23-2005, 07:44 AM
mehdiR's Avatar
purpose?
Old 08-23-2005, 09:18 AM
allmotorteg_96's Avatar
Default Re: ls vtec vs. gsr (mehdiR)
i run ls/vtec but i think you would be better off keeping what you have now. i dont think all the extra money you will spend on swaping a ls block in would be worth the little amount of gains you will see
Old 08-23-2005, 09:47 AM
92Jspec's Avatar
keep the poormans r and invest in some tuning, headwork, cams, good header.......just my 2cents.....but good luck with your decision
Old 08-23-2005, 09:09 PM
1heavy4dr's Avatar
i agree, keep your r, well said and done
duck22krazy
11-03-2008 10:36 AM
jxhxb
10
12-03-2007 03:37 PM
AIWFCIATR
11-19-2004 02:34 AM
EFin' Kyle
10-11-2004 04:01 PM
youngwon22
10-27-2003 04:12 PM
Quick Reply: ls vtec vs. gsr
