Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 07-25-2005, 05:04 PM   #1
85mm LS VTEC
85mm LS VTEC's Avatar
Default How to test alternator?
I have a 90 hatch DX and I was wondering if there is any way to test the alternator while it's in the car? The car has no brakes, so I can't take it to Autozone. Thanks for the help. Click the image to open in full size.
85mm LS VTEC is offline   Reply With Quote
Old 07-25-2005, 05:15 PM   #2
CRX Toad
Moderator
CRX Toad's Avatar
Default Re: How to test alternator? (85mm LS VTEC)
Unfortunately the best things to do is remove it and take it in to a parts place.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
1990-1993 Accords parting out
1991 CRX HF parting out
PM me for any parts
EG Sedan Tail Lights $60 shipped
CRX Toad is offline   Reply With Quote
Old 07-25-2005, 06:05 PM   #3
loodood
loodood's Avatar
i believe you can simply start your car up.....disconnect the negative battery terminal, and if the car dies, then you have a problem with your alternator.
"putting the get in ghetto"
loodood is offline   Reply With Quote
Old 07-25-2005, 07:20 PM   #4
Tyson
Tyson's Avatar
the PROPER way to test the alternator is to measure the voltage at the top of the alternator (under the rubber cap) and ground (any body part). it MUST read about 14.4-14.6V to be working properly.
it should not be 13.2 or 16.0. both of which will fail the disconnecting battery test (giving a false positive)...
that disconnecting battery test really doesnt tell you anytihng you shouldnt already know. you need to also test the voltage across the battery to properly confirm the alternator is the charging problem culprit.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline   Reply With Quote
Old 07-25-2005, 08:13 PM   #5
Kryogen
Kryogen's Avatar
Why test it, get a used alternator from the Junkyard..OEM..for like $20 go to a Honda and get alternator brushes for it, and your set....as long as you know how to install them which is pretty straight forward.
Kryogen is offline   Reply With Quote
Old 07-25-2005, 08:28 PM   #6
Suck my DX
Suck my DX's Avatar
Default Re: (Kryogen)
are u seriously saying that ud rather spend more time and money going to a junkyard and buying one that u dont even know is good then to just test the current one...whats the logic behind that
good parts for sale in SO CAL
http://www.hondamarketplace.com/show...6#post36857056
Suck my DX is offline   Reply With Quote
Old 07-25-2005, 11:20 PM   #7
ef92b
ef92b's Avatar
Default Re: (Suck my DX)
and what about the built-in IC regulator??? Click the image to open in full size. Click the image to open in full size.
Tyson & Suck my DX Click the image to open in full size. Click the image to open in full size.
EF Squad Member #35
CRX build
ef92b is offline   Reply With Quote
Old 07-26-2005, 12:30 AM   #8
michael O
michael O's Avatar
Send a message via AIM to michael O
I'm stumped by the logic in that one too. Click the image to open in full size.
88 Crx Dx
B16A-->B18a-->B16A-->B18a
michael O is offline   Reply With Quote
Old 07-26-2005, 03:02 PM   #9
Kryogen
Kryogen's Avatar
well maybe not go to the junkyard,
but the Brushes for it are like $15, takes 10 mins to install and usually when the alt. starts not putting out Volt, its USUALLY the Brushes, but people do not think about it and go to local parts store and buy a POS alternator for 70-150 bux, and have come out only slightly better than they were to begin with and out of a whole lot more money.
Old 07-26-2005, 03:04 PM   #10
Tyson
Tyson's Avatar
ive actually tried to find a place that sell rebuild brushes for my crx alternator. nobody seems to sell em individually anymore, other than bulk amounts for rebuild shops. do you know where i can get some?
Old 07-26-2005, 03:04 PM   #11
Kryogen
Kryogen's Avatar
and it was past Midnight for me when I posted that so..yes I may have been lacking a little brain power for that 1st post...lol...some of us have to get up early (4:30am) ya know.
Old 07-26-2005, 03:05 PM   #12
Kryogen
Kryogen's Avatar
Only Honda has them.
Old 07-26-2005, 04:13 PM   #13
knwldge54
knwldge54's Avatar
knwldge54 knwldge54 knwldge54
I'm sure you know SOMEONE with a car. Jack that car up, pull the alternator and get it tested at AutoZone or AdvanceAutoParts (or a store like on those near you). Take the battery with you and get it charged up also. Chances are, if your alternator ain't working anymore the battery is dead or on it's way. Charge it up before it goes too far.
'11 IS250
knwldge54 is offline   Reply With Quote
alternator, brushes, ca, crx, false, honda, jose, junkyard, positive, quick, sale, san, showing, tech, test
