Need a new starter?
#51
Re: Need a new starter? (schuey10101)
just did the rebuild and everything worked perfectly. Only difference was one of the black plastic piece under the power wire. SO i used the old one and starter is like new. Thanks for the info.
#53
Re: (reno96teg)
back from the dead, cause im sure alot of people are having this problem such as myself. anyone on h-t selling these kits? or know where to get em?
#54
Re: (markEj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markEj »</TD></TR><TR><TD CLASS="quote">back from the dead, cause im sure alot of people are having this problem such as myself. anyone on h-t selling these kits? or know where to get em?</TD></TR></TABLE>
I got the parts from a local Toyota dealer. I can't remember if they had them in stock or if they had to order them. Just use the part numbers listed by BSQ on the first page of this thread.
#55
Re: (PatrickGSR94)
back from the dead again. just rebuilt my starter, and put everything back in, but something shorts. when i take the wire from the starter off, no short, but i can turn the key and it will click. what am i doing wrong?
#56
Lifesaver of a post... Starter kept cranking after starting the other day then it stopped. It was intermittent with starting since then. Tonight I got home, shut the car off and tried to start it again and the solenoid got stuck so the car kept cranking until i disconnected the battery. Found this post via google, made my way into the solenoid. Had to pry it out because it was stuck, odd for a car with 68k miles. But anyways, I cleaned the plunger, reinstalled and it worked like a charm. Going to order those new contacts though just to be safe.
#60
everything lines up perfectly, except you have to reuse that black piece, on the starter rebuild kit that black piece is different. hope that helps
#63
just did it and took about 40 mins from opening my hood and replacing everything and starting it...it starts faster and fixed my problem that it would only start randomly
#65
Old Fart
Best bet and easiest, is to pull yours, go to your local starter/alt. shop and pick up a set, about $10 or less.
The ones listed on this tread are used in a lot of starter motors, [makes and models of cars] Toyota and Honda/Acura are only two of them, so it may well be the same ones for you, but to be sure just take them to a starter/alt. shop, you can probably find them at most car parts stores also, your paying through the nose from a Toyota dealer, or any dealer for that matter. 94
#66
Just another random bump and thank you to this thread. Car has been sitting due to this random not starting problem. Installed a new ignition switch and cleaned up a bunch of old wiring that looked like a car phone setup from the 90's. Car still wouldn't start and while searching I found something that said to tap the starter. I did and it started right up. These contacts are $9 on ebay so it's definitely worth a try.
#67
Hey guys! Bumping this because my starter is acting up again. Hard to believe it's been almost TEN YEARS since I started this thread and rebuilt my starter with the Toyota parts. Well now my car has 130K+ more miles since then, at 334K miles, and I think it's time for another starter rebuild. Glad to see the parts are pretty much the same price!
#68
Jack Murphy
06-21-2017 06:23 PM
JPerkMr954
06-09-2013 08:51 PM
