Old 07-25-2005, 09:15 AM   #1
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Default Need a new starter?
My car has exhibited some trouble starting at somewhat random times over the past couple of months, but in the past week or two it's become pretty regular, like pretty much every morning, and other times, as well.
When I turn the key to start the car, all I get is a click. Sometimes it takes several tries, and then finally it will start, no problem. When it finally does start, it's not slow to start at all (not like a drained battery). It will start just fine, it just takes several tries turning the key to get it to finally start.
So I'm thinking I need a new starter. I'm still on the original starter at nearly 210K miles. Where would you all suggest I get a starter, probably remanufactured, preferably OEM (Denso I think)? Should I get one from a local store like AutoZone or Advance or NAPA, or should I get one from an online retailer?
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 07-25-2005, 09:20 AM   #2
LSvtec03
LSvtec03's Avatar
Send a message via AIM to LSvtec03
Default Re: Need a new starter? (PatrickGSR94)
i would go ahead and get one from autozone. the duralast have a ltd lifetime warranty. Click the image to open in full size.
it'll probably be around 150 bucks and i'm sure you could find a used one for a lot cheaper, but it won't come with any warranty. Click the image to open in full size.
Search, spelling and grammar Nazi.
BUY MY CRX!!
devltuning.com-buy your parts here!!!
LSvtec03 is offline   Reply With Quote
Old 07-25-2005, 09:26 AM   #3
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Default Re: Need a new starter? (LSvtec03)
dang that's not too much less than brand new... Acuraparts247.com has them new for $225.
member #0001
Old 07-25-2005, 10:07 AM   #4
allmotorteg_96
Send a message via AIM to allmotorteg_96
a buddy of mine is selling one http://www.honda-tech.com/zerothread?id=1318776
allmotorteg_96 is offline   Reply With Quote
Old 07-25-2005, 10:11 AM   #5
5 Speed AP2
5 Speed AP2's Avatar
Send a message via AIM to 5 Speed AP2
Click the image to open in full size. Click the image to open in full size.
Pull out your starter and take it to autozone, kragen, places of such, and they can test it for you free of charge. Takes just a few seconds.
I'd go with a new one instead of a remanufactured.
5 Speed AP2 is offline   Reply With Quote
Old 07-25-2005, 10:20 AM   #6
xteg95
xteg95's Avatar
Send a message via AIM to xteg95
Default Re: Need a new starter? (5 Speed Dc2)
ya definately the starter...you can usually find a used one for around 50 bucks, id check a junkyard and pull it from there.
08 Audi TT 3.2 / 03 350z (sold) / 01 VMB Integra (sold) / 95 EBP Integra (smashed)
xteg95 is offline   Reply With Quote
Old 07-25-2005, 10:21 AM   #7
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Well if it's so easy to get off the car, then I might as well get a reman. one with lifetime warranty. If it ever goes bad I'll just pick up another one for free.
member #0001
Old 07-25-2005, 10:23 AM   #8
solareclipseauto
solareclipseauto's Avatar
SOLAR ECLIPSE AUTO PERFORMANCE AND TINT
507 G AVE NATIONAL CITY CA 91950
(619)474-0060
solareclipseauto is offline   Reply With Quote
Old 07-25-2005, 10:27 AM   #9
BSQ
BSQ's Avatar
Instead of purchasing a rebuilt starter (~$135), you can rebuild your starter for less than $20. The part that wear out in the starter are the copper contact points. Honda does not sell the contact points, BUT Toyota does. Honda starters are made by Nippondenso and so are Toytota (as well as other manufactures). Toyota sells the contact points in a starter rebuild kit. The parts that you will need are 28226-74070 ($11.89) and 28226-64370 ($6.32). These Toyota starter parts are identical to the Honda starter parts.
If you can remove your starter, you can replace the starter contact points. You should also clean the plunger magnet switch with some sand paper (see photos below).
Here is a picture of the Toyota parts.
Here is a picture of the new Toyota parts installed.
Here is a picture of the plunger switch before being cleaned.
Here is a picture of the plunger switch after being cleaned.
Bret - '94 GS-R
http://www.geocities.com/bretq (or my mirror site http://www.geocities.com/bretq2)
BSQ is offline   Reply With Quote
Old 07-25-2005, 11:41 AM   #10
Mordeki
Abusing my rights one day at a time.
Mordeki's Avatar
Default Re: Need a new starter? (BSQ)
^^^very nice info Click the image to open in full size.
PS - I bought one here on H-T for $20 Click the image to open in full size.
Patrick, my car did EXACTLY what you are talking about.......some weeks it was fines, others it took 10-30 clicks before starting. It def. is your starter or your starter solenoid, but they should come together so it doesn't make a difference. If you want to check if it's just your solenoid, PM and I will tell you how.
Mordeki is offline   Reply With Quote
Old 07-25-2005, 11:48 AM   #11
aeon
aeon's Avatar
Send a message via AIM to aeon
When my starter went out, I had to buy a new one. I went to napa though and asked the guy about rebuilding my starter and he said you can't do it so I just went ahead and spent over 200 on a new starter. Oh well, I needed one bad so I just went ahead with it.
<U>DB Squad #22</U>
aeon is offline   Reply With Quote
Old 07-25-2005, 11:57 AM   #12
DanMan1464
DanMan1464's Avatar
Yeah sounds like the problem my LS400 had.
Would just make a "ClicK" nothing else...became more regular as time went by. Lexus told me it was the starter...$950 Click the image to open in full size.
DanMan1464 is offline   Reply With Quote
Old 07-25-2005, 12:28 PM   #13
Keno20
Keno20's Avatar
Send a message via AIM to Keno20
Default Re: (DanMan1464)
In the mean time give the starter a couple of taps with a spanner or something. This usually solves the problem for a while.
Keno20 is offline   Reply With Quote
Old 07-25-2005, 02:43 PM   #14
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Man that's cool, thanks. Do Toyota dealers usually stock this stuff or will I have to order and wait for it to come in?
member #0001
Old 07-25-2005, 06:39 PM   #15
BSQ
BSQ's Avatar
I called 2 Toyota dealerships when I was looking for the parts and they both said that they stocked the parts.
BTW, I replaced the starter contact points back in February and since then I haven't had any issues with the starter (ie. "clicking" noise). My car starts on the 1st turn of the key now.
Bret - '94 GS-R
Old 07-25-2005, 06:44 PM   #16
JDM-EJ1
Imperious: Mod of Valor
JDM-EJ1's Avatar
Definitely sounds like the starter to me, I would spend the couple extra bucks and get the one from Acura, although does it have a warranty on it?
JDM-EJ1 is online now   Reply With Quote
Old 07-25-2005, 09:07 PM   #17
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Default Re: Need a new starter? (JDM-EJ1)
Couple? hmmm $225 vs. $20... think I'll rebuild mine myself. Click the image to open in full size.
Thanks everyone. Click the image to open in full size.
member #0001
Old 07-25-2005, 10:56 PM   #18
BolivianDc2
BolivianDc2's Avatar
Send a message via AIM to BolivianDc2
I was reading about this on T-I.net but didn't see any pics of people who actually did it. Click the image to open in full size. I have the same problem with my starter, it happens at the most random times
[img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
BolivianDc2 is offline   Reply With Quote
Old 07-26-2005, 05:18 AM   #19
Duane_in_Japan
Duane_in_Japan's Avatar
Look at the PICS that were posted for the Toyota starter, this is a famous pattern failure and is easy to fix at home, one of the two L shoped copper contacts gets papper thin and doesnt make contact very well with the round plunger to transfer power to the starter motor itself.
Here in JDM Land, the Toyota Ace family vans have this problem serious like on these gear reduction type starters, DIY and save big, an hour in and out tops.
Duane in Japan, sonataauto uses Hotmail
Tools to do the job, Training in the skills necessary to be more effective, Technology to be efficient and maximize the time spent, Support the efforts and challenges the business and staff face daily.
Duane_in_Japan is offline   Reply With Quote
Old 07-26-2005, 05:25 AM   #20
Duane_in_Japan
Default Re: Need a new starter? (Duane_in_Japan)
See how the contact on the left is half moon shapped, this is the one to go bad, this is where the power comes in from the battery, it always wears out first, if you buy a kit that is not exactly the correct one you may need to modify the copper contact so that it does not come too close to the large round opening for the plunger, it will short out against the solenoid housing hole just on the edge of the red paper.
Make sure the L contact is all the way down against the red paper when tightening it down snug. There is probably a piece of white paper in the kit, sometimes you wont see the old one, its covered with dust and dirt, scrape it out and pay attention how it is installed, this is insulating paper.
Old 07-26-2005, 09:41 AM   #21
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
cool man thanks for the pointers Click the image to open in full size.
member #0001
Old 07-26-2005, 10:22 AM   #22
chrisnova
chrisnova's Avatar
Yes, I agree with BSQ. I've had to do this on Toyota starters. It is usually just 2 copper contacts. You can sometimes get them at alternator shops for $5 - $10 and avoid waiting for Honda to get them for $20-30. They are probbaly worth 25-50 cents. I would call a reliable alternator shop. They should be able to take careof you quickly. Anyway it takes about 15-30 minutes to disassemble the alternator and put the new contacts in. Basically these contacts function as th ebrushes of a DC motor. Your starter is typically a 1 KW DC motor. Good luck all. Save yourself hundreds of dollars!!!!!!!!!
PS It is normal for these contacts to wear out after 100K-200K miles on the car.
chrisnova is offline   Reply With Quote
Old 08-03-2005, 09:59 PM   #23
BolivianDc2
Default Re: Need a new starter? (chrisnova)
I just put the new toyota contacts in my starter and am still having the same problem. There is a 1 click from the starter, just like before. Is it the starter solenoid?
should I even bother running the tests in the helms, or just get a new starter?
Old 08-04-2005, 03:42 AM   #24
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Default Re: Need a new starter? (BolivianDc2)
Dang that sucks.... I just replaced the ones in mine the other night and it's working great.
member #0001
Old 08-11-2005, 09:57 AM   #25
Zaraki_21
Zaraki_21's Avatar
did you have to do any modifications to the toyota connectors at all when you installed them? I'm looking at having to do this myself also, but wasn't sure if I should or not or just go buy a new starter. Let me know if you had to do any other work like sanding anything else down ... etc....
Zaraki_21 is offline   Reply With Quote
2822674070, acura, clicks, disassembled, honda, integra, intergra, problems, rebuild, rebuilding, replace, replacing, solenoid, starter, toyota
