Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 02-17-2002, 12:13 AM
Powered by Honda
2003 Honda S2000
My Garage
Powered by Honda's Avatar
Default crap! what to do about spilled brake fluid inside engine bay...
damn, pretty pissed. I was adding some brake fluid into the brake and clutch reservoir and some of it accidentally spilled into my engine bay right below the brake reservoir area, and I can't freakin' reach it to clean it up. Now I know brake fluid is a highly effective paint remover and damager so what can I possibly do to lessen the damage, if any? Does brake fluid actually strip paint to the metal or just visibly damages it a little? I was under the impression that the paint manufacturers use inside the engine bay is different than the kind they use on the exterior of the car so maybe the brake fluid won't affect that area at all? Anyone think a steam clean will do the trick? there is just no human way possible for me to reach the areas that got spilled on in the engine bay...thanks for any advice!... Click the image to open in full size. Click the image to open in full size.
[Modified by MugenHondaFormula1, 9:18 AM 2/17/2002]
Powered by Honda is offline
Old 02-17-2002, 12:33 AM
irev210
Send a message via AIM to irev210
Default Re: crap! what to do about spilled brake fluid inside engine bay... (MugenHondaFormula1)
dude, its no biggy
go to pepboys autozone etc type store, buy some engine degreeser, spray it all around. take a hose and rinse it off
no big deal
keep water off ur distributor and valve cover
MY VOUCH THREAD
Click to see my vouch thread
irev210 is offline
Old 02-17-2002, 12:46 AM
Powered by Honda
2003 Honda S2000
My Garage
Default Re: crap! what to do about spilled brake fluid inside engine bay... (sirhatchback)
thanks for the reply man, is there any specific degreaser you recommend or use?
Old 02-17-2002, 05:32 AM
non-VTEC
1995 Acura Integra
non-VTEC's Avatar
hose it off with the garden hose.........
95 Integra Turbo - SOLD
2014 Toyota Corolla S
non-VTEC is offline
Old 02-17-2002, 05:33 AM
DragII
DragII's Avatar
Sk8 P
Default Re: crap! what to do about spilled brake fluid inside engine bay... (non-VTEC)
wipe it up.
DragII is offline
Old 02-17-2002, 06:08 AM
G
Wash with water ASAP....
G is offline
Old 02-18-2002, 11:57 AM
martini
Send a message via ICQ to martini
Default Re: crap! what to do about spilled brake fluid inside engine bay... (G)
rinse it off with water asap..
then go to the auto store and pick up some engine degreaser (simple green, Engine brite, whatever..it doesn't really matter..though some are biodegradable, you might want to try for those.) Spray it all over, and rinse it off. You might as well clean the entire engine bay with degreaser while you're at it.
martini is offline
Old 02-18-2002, 12:00 PM
rtype11
rtype11's Avatar
brake parts cleaner will take care of it.
Your car is so slow, who built it Gippetto?
96 LS T60-2 powered nightmare
02 SUZUKI GSXR 600 - RIP Aug 22/03
rtype11 is offline
Old 02-18-2002, 12:51 PM
typer_801
typer_801's Avatar
Default Re: crap! what to do about spilled brake fluid inside engine bay... (rtype11)
Rinse with water immmediately. Then if greasy use Simple Green or any other cleaner like that to remove the residue.
I've also had very good luck with "Coastal Cleaner" from AutoZone. While it says not to use on aluminum (I think Simple Green does too) it works exceptionally well at degreasing engines, just don't let it sit long on anything. Spray on, the brush problem areas quickly and high pressure spray off. Then for rubber items (after cleaning) I'd recommend some sort of silicon to relubricate them so they don't dry out and fail prematurely.
Jeff B
07 Civic Si Sedan
98 ITR #801 - SOLD
typer_801 is offline
Old 02-18-2002, 03:32 PM
McLaren
I would use some engine degreaser to clean those, and you better clean them fast!!
Brake Fluid would eat you paint!! Trust me, they will make your paint pill off!! I had that happened b4!!
[Modified by McLaren, 4:33 PM 2/18/2002]
It don't matter how fast the car is... it's the driver who makes all the difference.
"DO YOU HAVE A HONDA!?"
McLaren is offline
Old 02-20-2002, 07:39 AM
Powered by Honda
2003 Honda S2000
My Garage
Default Re: crap! what to do about spilled brake fluid inside engine bay... (McLaren)
Wow, thanks for all the replies guys. What I ended up doing was using pretty much a can of WD-40 to saturate the area that got stained on, let it sit for a bit and rinsed with a lot of water. It worked awesome! Before I did anything, the paint around that area was discoloring pretty quickly to a brownish poo stain but after the WD-40 and water rinse, the black color of my paint came back....whew. I also used the WD-40 to relubricate a coupe plastic hoses that were victims of the spillage as well. I guess you can add WD-40 to the list of effective brake fluid removers...thanks again for the quick help everybody...
[Modified by MugenHondaFormula1, 4:40 PM 2/20/2002]
Old 02-20-2002, 12:40 PM
Mike K
Mike K's Avatar
Send a message via AIM to Mike K
Brake cleaner. Spray dat chit.
Honda/ASE Certified Technician
2004 Element EX 4WD, totally stock.
mikek@topshift.com
Mike K is offline
accidently, bay, brake, car, cleaning, engine, fluid, green, long, paint, poo, remove, rubber, sit, spilled
