> Honda CRX / EF Civic (1988-1991)
Old 07-05-2005, 09:31 AM   #1
CBURKE
CBURKE's Avatar
Send a message via AIM to CBURKE
Default NEED MAJOR HELP WITH ZC TIMING BELT!!!
I am dooing a swap as we speak, but cant seem to find the right t-belt for the DOHC ZC i have been through 4 no and no luck. Does anyone know ?
What up?
CBURKE is offline   Reply With Quote
Old 07-05-2005, 09:37 AM   #2
Bunger
Bunger's Avatar
Default Re: NEED MAJOR HELP WITH ZC TIMING BELT!!! (CBURKE)
1988 Prelude 2.0 Si ???
88 CRX Hf • D15Z1 • 70+ MPG
www.zealautowerks.com • The Honda Compression / Horsepower / Transmission Calculator
Bunger is offline   Reply With Quote
Old 07-05-2005, 09:40 AM   #3
Jasond
Jasond's Avatar
Send a message via AIM to Jasond
Default Re: NEED MAJOR HELP WITH ZC TIMING BELT!!! (Bunger)
Bingo thats the one you want.
Originally Posted by VegasEFHB
The last I checked this is America where people are innocent until proven guilty (or I catch them keying my $hit, then I can beat them with a baseball bat)
Jasond is offline   Reply With Quote
Old 07-05-2005, 09:42 AM   #4
EP3_05
EP3_05's Avatar
Send a message via AIM to EP3_05
1988 Prelude 2.0 Si 14400-PK2-004 (DOHC ZC)
1991 civic 4dr
B16a
2005 Honda Civic Si
Satin Silver Metallic
EP3_05 is offline   Reply With Quote
Old 07-05-2005, 09:47 AM   #5
CBURKE
CBURKE's Avatar
i think i tryed that one but my boy just went down to see if he can get one.
What up?
Old 07-06-2005, 01:11 PM   #6
CBURKE
CBURKE's Avatar
Ok got the belt on and there is a little slop, is this normal?
What up?
Old 07-06-2005, 01:15 PM   #7
EP3_05
EP3_05's Avatar
Default Re: (CBURKE)
There shouldn't be any slop. If there is it will not stay timed properly. Did you tension the belt according to the service manual?
Steps to tension belt:
1. Set crank pulley so #1 piston is at TDC
2. Loosen timing belt tensioner
3. Turn crank pulley so the cam gears move 3 teeth in the counterclockwise direction
4. Tighten the tensioner
Modified by 91civic at 8:01 PM 7/6/2005
1991 civic 4dr
B16a
2005 Honda Civic Si
Old 07-06-2005, 02:10 PM   #8
CBURKE
CBURKE's Avatar
I have been reading alot about the zc and from what i have been reading it is like that beacuse we have to use the lude timing belt and not a zc. The belt even seems to be bigger.
What up?
Old 07-06-2005, 02:20 PM   #9
Sikocivic
Sikocivic's Avatar
I am using the Prelude belt on my DOHC ZC and it fits fine, no slop.
Econ Racing
Its not a tuner shop, its a lifestyle
Sikocivic is offline   Reply With Quote
Old 07-06-2005, 02:25 PM   #10
Jasond
Jasond's Avatar
Default Re: (Sikocivic)
It will seem sloppy until you turn the crank per the manual.
Old 07-06-2005, 02:46 PM   #11
CBURKE
CBURKE's Avatar
I don't really understand this (3. Turn cank pulley so the cam gears move 3 teeth in the counterclockwise direction)
What up?
Old 07-06-2005, 03:58 PM   #12
HumanResource
depends on what ZC
the 1st gen is basically the D16A1 unit with the smaller cam gears
the 2nd gen ZC (88-91) is the prelude unit with bigger cam gears
check the belt route
did you miss any pulleys?
HumanResource is offline   Reply With Quote
Old 07-06-2005, 06:24 PM   #13
Crx Jimmy
Crx Jimmy's Avatar
count the teeth in the belt to see if the same- duh!
Crx Jimmy is offline   Reply With Quote
Old 07-06-2005, 08:06 PM   #14
jlicrx
jlicrx's Avatar
Default Re: NEED MAJOR HELP WITH ZC TIMING BELT!!! (HumanResource)
not true - the 2nd gen ZC is not a Prelude unit - it is a unique engine - all DOHC ZCs have same diameter cam gears as B-series or H-series - 34 teeth (timing marks are different, but they are the same size) - the 88 Prelude 2.0 Si timing belt and the DOHC ZC timing belt are identical and have the same part number 14400-PK2-004 - the belt has 124 teeth with 9.5mm pitch
ZCspeed Racing
jlicrx is offline   Reply With Quote
Old 07-07-2005, 05:20 AM   #15
CBURKE
CBURKE's Avatar
Ok i think i got it. I looked over the book and i think i see what's up. But, the belt is almost or well it tuches the motor mount. The belt tenchiner bolt is at the bottom so it can't get any tighter. The belt say's 184 on the top. Maybe it's the wrong belt. Lets go for belt #5!!!
What up?
Old 01-04-2006, 09:55 AM   #16
legendboy
legendboy's Avatar
sorry to bump an old thread buy won't a Tbelt from an 89 integra work on a DOHC ZC?
edit: and yes i have looked thru all the archived posts
legendboy is offline   Reply With Quote
Old 01-04-2006, 12:58 PM   #17
jlicrx
jlicrx's Avatar
Default Re: (legendboy)
no, the DOHC ZC timing gears are smaller than the Integra - DOHC ZC cam gears have 34 teeth and crank gear has 17 teeth - the Integra cam gears have 40 teeth and the crank gear has 20 teeth - Integra belt is too long
ZCspeed Racing
14400pk2004, 20, belt, camshaft, codes, dohc, engine, honda, mark, marks, motor, replacement, set, teeth, timing, zc
