how can i push caliper piston back in?
Old 07-04-2005, 06:18 PM
  #26
ibe2fly's Avatar
Default Re: (1TurboHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TurboHatch &raquo;</TD></TR><TR><TD CLASS="quote">check and make sure you didnt bend the backing plate so its rubbing on the rotor.</TD></TR></TABLE>
yea im thinking that skinny piece of metal behind the rotor is rubbing against it ... should i just go in there n try to bend it away from the rotor?
Old 07-04-2005, 06:20 PM
  #27
DeadVet's Avatar
Default Re: (ibe2fly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibe2fly &raquo;</TD></TR><TR><TD CLASS="quote">
Yup just bend it back so its not hitting the rotor.
Old 07-04-2005, 06:45 PM
  #28
ibe2fly's Avatar
thanx hopefully that's what that noise is ... gonna do that n try to rebleed tomorrow thanx HT-ers
Old 07-06-2005, 04:42 PM
  #29
ibe2fly's Avatar
well i figured out what the noise was ... the bottom retaining clip on my caliper bracket was rubbing against my rotor ... i took it off bent it to fit better onto the caliper bracket and then put back on pads, rotor n caliper ... nice n quiet now to rebleed ... ill do that manana
Old 07-06-2005, 05:56 PM
  #30
1995Ex_Sedan's Avatar
I had a tiny tiny, TINY rock get inbetween that metal dust flap and the left front rotor. Holy crap it sounded like I was killing a cat or something.
Old 07-07-2005, 01:57 PM
  #31
ibe2fly's Avatar
Default Re: (1995Ex_Sedan)
can ur rotors get damaged like that? it's not on the actual surface of the rotor but it's the outer edge of it ... seems to me like they'd become weakerand have a smaller radius / diameter after time
Old 07-07-2005, 04:04 PM
  #32
briq4's Avatar
I would suggest using a c-clamp and using the old brake pad over the piston to press it back in for the simple reason that you want the piston to go in nice and even, using channel locks could **** the piston slightly and cause damage to the caliper. Might take a few seconds longer to use the c-clamp but seems a bit faster than changing out calipers. Just my .02.
Old 07-07-2005, 04:09 PM
  #33
JDM-97CX's Avatar
Default Re: how can i push caliper piston back in? (ibe2fly)
Buy a new caliper.
Don Dempsey
Honda CR-V & Element
01-21-2013 07:28 AM
kidcool1977
11-30-2008 05:42 AM
92civicx
10-24-2007 04:20 AM
Mohsin
Suspension & Brakes
12-22-2006 08:47 AM
DC2 to AP2
07-28-2004 11:15 AM
Quick Reply: how can i push caliper piston back in?
