92-96 prelude wiring harness h22
i'm looking for a 92-96 h22 usdm wiring harness. had h23 and swapped h22 but getting alot of problems using h23 distributor.
Re: 92-96 prelude wiring harness h22 (b18cvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cvtec »</TD></TR><TR><TD CLASS="quote">i'm looking for a 92-96 h22 usdm wiring harness. had h23 and swapped h22 but getting alot of problems using h23 distributor.</TD></TR></TABLE>
What kind of car is this in?
What kind of problems?, any cel's?
Are you sure it isn't a timing issue?
Re: 92-96 prelude wiring harness h22 (red92s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92s »</TD></TR><TR><TD CLASS="quote">If I'm not mistaken, the H22 and H23 distributer is the same</TD></TR></TABLE>
Yes, they are the same.
Re: 92-96 prelude wiring harness h22 (AndyD)
The wiring harnesses are the same other than there isn't a VTEC and VTEC oil pressure switch..
Dizzy's are the same too.. Unless its a 1996 one your using...
Can you explain a little more about "Dizzy's are the same too... Unless its a 1996 one your using. " just wondering because i have a 96 h22a vtec in a 93 prelude si
brad225
04-07-2008 05:42 PM
