93 civic front speaker size? (coupe)
Old 06-12-2005, 08:27 PM
NoahOneill's Avatar
Default 93 civic front speaker size? (coupe)
Anyone know the speaker measurement for the front speakers in a 93 civic coupe?
Old 06-12-2005, 08:30 PM
DISROK1's Avatar
Default Re: 93 civic front speaker size? (NoahOneill)
6 1/2 (6.5)
Old 06-12-2005, 08:31 PM
NoahOneill's Avatar
Default Re: 93 civic front speaker size? (DISROK1)
Thanks, and backs are the same, correct? i cant get anyone to give me a straight answer and i'm having a little trouble busting the back speaker covers off.
Old 06-12-2005, 08:34 PM
dohcdelsol's Avatar
my 92 hatch was 5 1/4 fronts..... it depends on what bracket you have in there though
Old 06-12-2005, 08:35 PM
DISROK1's Avatar
REARS SHOULD B 5 1/4
Old 06-12-2005, 08:36 PM
NoahOneill's Avatar
thanks, i'll attempt to bust em off again tomorrow to double check.
Old 06-13-2005, 08:44 AM
doughboy_88's Avatar
i had trouble finding a definite answer here on H-T as well, so i went ahead and took it apart during the install.
6.5" coaxials will fit if you cut the back-end of the basket out so that the magnet clears. the front-end, meaning the distance from the woofer/tweeter to the speaker panel, is sufficient to clear.
the rear, in my '93 Si hatch, are 5.25". with a bit of tweaking, you can run 6.5". i'd stick to 5.25" for a direct bolt on.
goodluck.
Old 06-13-2005, 10:16 AM
kleanlscivic's Avatar
try the crutchfield website they will tell you what fits
Old 06-13-2005, 10:18 AM
northkai3's Avatar
Default Re: 93 civic front speaker size? (kleanlscivic)
i took out my rear mounts cut them up and made custom 6x9 mounts!
feava510
04-12-2009 08:15 PM
Midori Green
31
07-07-2007 07:58 AM
5thgencivicr
07-23-2005 05:38 PM
NoahOneill
06-04-2005 08:32 PM
Quick Reply: 93 civic front speaker size? (coupe)
