what will happen if you hook up jumper cables wrong??
Old 06-06-2005, 09:11 AM
hatchinprogress's Avatar
Default what will happen if you hook up jumper cables wrong??
i have a da teg and the bat. was dead so i had a friend pull up his car to jump start mine well put the cables on my bat. and when i went to put the other end of the cables on his car there was a spark(from his bat) i looked at my car and the wires were on wrong (neg. on pos.) and when i corrected the issue the car still will not start....... so what happenend i need to know if i have another problem or if the cable situation will cause a car to not start up????? thanks for any help
Old 06-06-2005, 09:30 AM
dragoncoach's Avatar
Default Re: what will happen if you hook up jumper cables wrong?? (hatchinprogress)
Check the fusable links in the engine compartment. After that check ALL the fuses to make sure they are not blown as well.
Old 06-06-2005, 09:31 AM
Default Re: what will happen if you hook up jumper cables wrong?? (dragoncoach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragoncoach &raquo;</TD></TR><TR><TD CLASS="quote">Check the fusable links in the engine compartment. After that check ALL the fuses to make sure they are not blown as well. </TD></TR></TABLE> thanks! now could this cause anything major to the car? or will it just blow a fuse???
Old 06-06-2005, 10:07 AM
PandaBear's Avatar
could be major problem, depends on your luck.
Lucky your battery didn't explode and you are here standing.
Old 06-06-2005, 10:25 AM
solareclipseauto's Avatar
usually its the fusable links in the fusebox in he engine bay
Old 06-06-2005, 10:32 AM
Default Re: what will happen if you hook up jumper cables wrong?? (PandaBear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">could be major problem, depends on your luck.
Lucky your battery didn't explode and you are here standing.</TD></TR></TABLE> damn i hope nothin major..but thats how my luck is(bad)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">usually its the fusable links in the fusebox in he engine bay</TD></TR></TABLE> man i hope thats all it is...thanks for all the help guys
Old 06-06-2005, 07:22 PM
hey i fixed it nothin major happened, and thanks for the help
b20racer
08-11-2008 10:39 PM
JSPECJUSTIN
04-05-2007 01:11 PM
redheadcivic
06-01-2004 11:00 AM
daidilus
05-27-2004 08:59 AM
JDMlyfestyle
22
01-09-2004 10:36 AM
Quick Reply: what will happen if you hook up jumper cables wrong??
