Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 05-23-2005, 01:26 PM   #1
SirThelin
SirThelin's Avatar
Default Turbocharging my CRX
Hey
Ive got a Crx with an D16z5 DOHC
Really itchy for a turbocharger.
Searched at Sportscompactonly.com and found a kit for d16a1.
U think it will work?
SirThelin is offline   Reply With Quote
Old 05-23-2005, 02:06 PM   #2
Mach69
Mach69's Avatar
Send a message via ICQ to Mach69 Send a message via AIM to Mach69
Default Re: Turbocharging my CRX (SirThelin)
I have no idea what a D16Z5 is! I am not sure if it exists. However, you mentioned that it is a DOHC engine, and the only D-series DOHC engine was the ZC. Is that a D16z5?
If you are talking about the ZC dohc, then that is a great engine to turbocharge. You can piece together a hmt kit.
http://www.homemadeturbo.com/
2008 True Red Mazdaspeed 3
Mods: CPE Nano, Dashhawk, AWR Rear Motor Mount, Forge BPV, Cobb RSB, Spin-on Oil Filter, AQ DP, CPE Inlet Pipe, Denso ITV22, CPE TMIC, SU Boost Tubes, Hypertech Tune
Mach69 is offline   Reply With Quote
Old 05-23-2005, 07:39 PM   #3
HiProfile
HiProfile's Avatar
Default Re: Turbocharging my CRX (Mach69)
A kit for a d16a1 will fit any mpfi d16 (has same exhaust manifold, and nearly the same t-body placement). Eigher you have a ZC DOHC or a SOHC D16z6, either way it will work. The only reason it wouldn't work 100% is bacase the a1 is from an 86-87 teg, and I'm sure teh charge piping would be different. Regardless, the a1 swaps right into a crx, so I'm sure you'll be fine.
94 Del Sol (F2B F22), 95 Civic EX (turbo D16Z6), 94 Integra LS (H2B H23A in progress)
PM me for matched 370cc-1000cc injector sets!
HiProfile is offline   Reply With Quote
Old 05-23-2005, 09:11 PM   #4
Mach69
Mach69's Avatar
Default Re: Turbocharging my CRX (HiProfile)
It swaps in, yes. But not right in. It is a really pain to get the A1 into the crx body, or so I have read. Its not the 'drop-in' like a z6 or ZC engine is.
As far as exhaust manifold and throttle body placement, those are probably the same.
Old 05-23-2005, 09:18 PM   #5
markdman
the a1 actually drops right into the 84-87 crx's. the 88-91 a little fab is needed
markdman is offline   Reply With Quote
Old 05-23-2005, 09:20 PM   #6
markdman
oh yeah, if your not sure it will work, buy a d16a1 exhaust gasket and see if it will fit on your z5
Old 05-28-2005, 08:09 AM   #7
SirThelin
SirThelin's Avatar
I didnt know that my D16z5 existed before i checked my papers and doublechecked on th block.....It really exist.
So I can bolt on the turbo that fit on the a1 and zc then?
Old 05-28-2005, 03:45 PM   #8
juice91si
juice91si's Avatar
you have a z5, it was only available in europe, thats why you confused the ppl above. like already mentioned too, everything should bolt up fine. its a d-series so the ex mani will work fine, it is very similar to the jdm zc.
1999 Mercedes-Benz C43 AMG
2006 Subaru WRX STi
former EF Squad Member #11
juice91si is offline   Reply With Quote
charging, crx, d16z5, hmt, honda, turbo, turbocharing
