What happens when your timing belt skips
Old 02-05-2002, 06:05 PM
Ri5e's Avatar
Default What happens when your timing belt skips
What happens when your timing belt skips and your off by a few marks/ticks?
Does the car stall out when you idle? And is the car hard to start up?
Old 02-05-2002, 06:09 PM
bob01721's Avatar
Default Re: What happens when your timing belt skips (BG Boost)
Yep. And you'll lose power...
And all these things could be caused by a kazillion other things, too. What's up? What happened?
Old 02-05-2002, 06:26 PM
Ri5e's Avatar
Default Re: What happens when your timing belt skips (bob01721)
Well, I think thats what caused my motor to blow
I'm turboless now....
Old 02-06-2002, 12:58 PM
bob01721's Avatar
What happened? Were you driving the car at the time? Did you go out one morning and it wouldn't start?
Old 02-06-2002, 03:02 PM
forcefed's Avatar
on the cam!! one tooth is 11 degrees, i've seen one assembled before like that
and it ran fine but lost a lot of power. any more then that and your valves would hit your pistons. but your belt should NOT slip, they are made with a kevlar core
which hardly strechs over time and not enough to slip a tooth plus there is a tensioner in there too
dadrought6
02-18-2009 05:22 AM
EFin' Kyle
12
04-28-2006 09:07 PM
dunkd
05-27-2005 07:48 PM
integrasi
10-30-2003 08:12 PM
Spike2
03-11-2003 01:46 PM
Quick Reply: What happens when your timing belt skips
