removing vtec oil passage plug in head
Old 05-18-2005, 08:10 PM
bambbrose's Avatar
Default removing vtec oil passage plug in head
I've got a b16 head that was previously setup for LS-vtec. It has a fitting in the oil port, and then some of that quik-steel **** over the fitting. I'm kind of stuck trying to figure out how to remove the ****. Should I just drill it? and if so do I have any room for error? any other ideas?
Old 05-19-2005, 04:38 AM
DelSeeYa's Avatar
Default Re: removing vtec oil passage plug in head (bambbrose)
if it was done right it should screw right out, maybe with a lilttle force since that quicksteel **** is on there, if it was a ls/vtec kit fitting then i believe it's a 13 or 14 mm to take it out, and if it wasn't then i'm sorry but i can't help there without a pic, and i wouldn't try doing anything to it till u know for a fact if u have any room for error or not... hope this helps.....
Old 05-19-2005, 05:21 AM
bambbrose's Avatar
I'll try to get a pic up tonight after work
Old 05-19-2005, 09:48 AM
PURPLETERROR aka BIGMATT's Avatar
small drill bit, then use an easy out
a1320honda
04-27-2007 11:13 AM
pK1spooled
02-13-2005 04:23 AM
VXpride
06-13-2002 05:05 PM
Quick Reply: removing vtec oil passage plug in head
