Old 05-16-2005, 01:13 PM   #1
snouka
snouka's Avatar
Send a message via AIM to snouka
Default Srs light codes meaning
My srs light lit up yesterday, I checked the ecu codes and I had the code 20(second oxygen sensor failure) and the other is 2(ELD). I really don't know why I have these codes since it's the srs light that is on and not the check engine? Why is it not the check engine that is telling me that my O2 sensor is bad since its part of the engine???
snouka is offline   Reply With Quote
Old 05-16-2005, 01:31 PM   #2
snouka
snouka's Avatar
Default Re: Srs light codes meaning (snouka)
ttt
Old 05-16-2005, 01:33 PM   #3
snouka
snouka's Avatar
i'm sorry I have noted that the codes that the srs is telling me aren't ecu codes even if I have to jump the Ecu, it's the dtc codes right???
Old 05-16-2005, 02:10 PM   #4
Chiovnidca
Chiovnidca's Avatar
The SRS should flash a code shortly followed by a sub-code. Knowing the year and model would be a help also.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 05-16-2005, 02:14 PM   #5
snouka
snouka's Avatar
Default Re: Srs light codes meaning (Chiovnidca)
Yeah I have 2 long flashes followed by two short ones so it's the 2-2 code. I have the service manual and I checked the dtc chart and this code means that the dummy resistor that I have in my civic cx 97 without passenger is probably wrong but I cannot find this resistor, does anyone know where it is located
Old 05-16-2005, 02:39 PM   #6
snouka
snouka's Avatar
I would like to know where is the dummy resistor for the passenger air bag that I don't have, I know it is connected on the srs unit but I know where it is
2002, acura, chart, civic, code, codes, dtc, honda, light, meanin, meaning, meanings, resistor, srs, tl
