Stripped oil plug.
Old 05-14-2005, 04:58 PM
Slipjack's Avatar
Default Stripped oil plug.
I just bought a '93 Civic HB and when I bought it home to give it an oil change I found that the oil plug is stripped out. I might be able to unscrew it if I try hard enough, I just wanted to know if anybody knew any tricks that I don't know about to get it off.
Old 05-14-2005, 05:00 PM
Lmgrcivic's Avatar
Default Re: Stripped oil plug. (Slipjack)
weld something to it and unscrew it and get a new one
Slipjack's Avatar
Default Re: Stripped oil plug. (Lmgrcivic)
Not bad, will need to drive it to my Dad's for a welder. Any other ideas before I go do that instead?
Old 05-14-2005, 05:12 PM
Electrician
Deemeetree's Avatar
Get a grinder, knotch a groove in the center, get your biggest/heaviest flathead, try from there. You can try Vise-Grips.
Old 05-14-2005, 05:18 PM
Slipjack's Avatar
Default Re: (Dimitri_EG8)
That'll work. Thanks. Tried the vicegrips. They just slipped around on the plug like the wrench did. Someone did a real number on it, multiple times.
If whoever did this was stupid enough to not only strip the oil drain plug, but to keep using it and stripping it more and more each time -- now I have to look at every single facet of this car to see what other stupid crap might have been done to it.
Old 05-14-2005, 06:00 PM
Hurricane's Avatar
Default Re: (Slipjack)
Worst case senario, you have to pull the oil pan while its full ($#@%$#@mess) and replace it with one that has a good plug.
Old 05-14-2005, 06:41 PM
extra cam needed's Avatar
Location: americas finest, calee fourn ya, united states
Use a plumber's pipe wrench
Old 05-14-2005, 07:09 PM
TurboTagTeam's Avatar
Default Re: (extra cam needed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 &raquo;</TD></TR><TR><TD CLASS="quote">Get a grinder, knotch a groove in the center, get your biggest/heaviest flathead, try from there. You can try Vise-Grips. </TD></TR></TABLE>
Or use a dremal or something
Old 05-14-2005, 07:10 PM
SOHC4life 96's Avatar
You could get a socket that is smaller than the plug bolt right now and hammer it on there and then see if that works. The socket should be expendable though.
Old 05-14-2005, 08:43 PM
H-T White Ops
Frozen E's Avatar
Pick one up at your local hardware store. $4-10 TOPS.
Old 05-15-2005, 07:33 AM
tuphatt's Avatar
get a strip bolt remover from Sears. It is like $20. Make sure you buy the metric version.
worked for my stripped bolted on the CAT.
Good Luck
Old 05-15-2005, 08:33 AM
00supercivic's Avatar
yeah i would try the pipe wrench casue i had the same problem, and it came of in the first try. or if you have to you might have to get a bolt extractor form auto zone. and as far as gettin a new one you can get it from honda with a new crush washer for like 4 bucks, thats what i did. good luck
Old 05-15-2005, 09:00 AM
peiku's Avatar
Default Re: Stripped oil plug. (tuphatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuphatt &raquo;</TD></TR><TR><TD CLASS="quote">get a strip bolt remover from Sears. It is like $20. Make sure you buy the metric version.
Good Luck</TD></TR></TABLE>
i would suggest this too. i bought a set and have never regretted it. i have taken out many stripped bolts.
Old 05-15-2005, 09:34 AM
nocturnaldragon's Avatar
Those things are pure <U>****</U>. Get a pipe wrench.
Old 05-15-2005, 09:45 AM
T4eg's Avatar
Default Re: Stripped oil plug. (nocturnaldragon)
I just ran into the same problem. I took the pan off and drilled out the hole and welded a 3/8" pipe fititng in. (flush with inside pan) then using a 3/8 pipe plug as a drain plug
Old 05-15-2005, 02:02 PM
kkim's Avatar
Default Re: Stripped oil plug. (T4eg)
pipe wrench should work. just be sure to have a replacement plug on hand when you finally get the stripped one ut.
jokellum
Honda Civic (2001 - 2005)
01-13-2015 02:18 PM
hydengr
06-11-2013 03:50 PM
NOOdS
13
11-28-2011 02:56 PM
dwn2earth922
05-03-2007 08:30 PM
AB16A2T
14
04-04-2002 11:32 PM
Quick Reply: Stripped oil plug.
