Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2002 Acura TL Type-S CD changer malfunction error "ERE1" can't play CD's! Can't load/unload! Nothing
Old 05-10-2005, 11:42 PM
Johnny916's Avatar
Default 2002 Acura TL Type-S CD changer malfunction error "ERE1" can't play CD's! Can't load/unload! Nothing
Hi, my CD changer/player stopped working. I have the 6-disk cd changer in the dash and every time I press the CD button the changer tries to do something but then just gives me this error ere1. Shoudl I attempt to take the CD changer out somehow? My car is not under warranty anymore so I'm basically SOL if the changer is bad. Can somebody please help?
Old 05-11-2005, 06:43 AM
timmy8151's Avatar
Default Re: 2002 Acura TL Type-S CD changer malfunction error "ERE1" can't play CD's! Can't load/unload! Not
Are you using burned CD's?? I've read that this may lead to ERE1 errors
Old 05-11-2005, 08:22 PM
Johnny916's Avatar
Yes, but I can't even eject now! What should I do? A 02 Acura shoudl be able to read burned CD's shouldn't it!
Old 05-11-2005, 08:26 PM
timmy8151's Avatar
Check out this thread: http://www.acurazine.com/forum...=ere1
Old 05-13-2005, 12:22 AM
tommy d.'s Avatar
Hey there, same thig happened on my '01 cl-s. i didn't have any burned disc's loaded. usually the error code would clear if i shut the power off then back on. after a couple of months it wouldn't reset so... i used the tried and true method of a good smack on the console to get the cd player working again. then had the radio replaced under warranty.
i've seen quite a few posts regarding the same complaint. it's probably like the tranny problem "only a matter of time until failure"
Old 05-13-2005, 12:23 AM
tommy d.'s Avatar
Old 04-14-2011, 08:44 AM
fraziercara's Avatar
Mine had this ErE1 problem--I had three discs in there, two that were burned & one from the library with a label on it. Could not see any disc stuck trying to come out when I looked, so I tried hitting (and kicking!) the right side and pushing power and eject repeatedly, which someone suggested. Then I read somewhere else to disconnect the black battery cable, pump the brake to drain the power, then turn the car and radio on and enter the radio code, which I found on a card with my owner's manual. DON'T DO THIS UNTIL YOU MAKE SURE YOU HAVE THE RADIO CODE FIRST. It worked!! I pushed eject and all three discs came out.
chepeleh
11-02-2019 02:58 PM
Dennis Melnyk
03-15-2019 08:57 PM
temps73
Honda Civic (2001 - 2005)
04-14-2006 04:11 PM
derictolen24
Acura TL, RL & ZDX
08-31-2005 10:13 PM
Jason W
01-05-2004 08:36 PM
Quick Reply: 2002 Acura TL Type-S CD changer malfunction error "ERE1" can't play CD's! Can't load/unload! Nothing
