Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 05-06-2005, 09:46 PM   #1
fubar
fubar's Avatar
Default Headlight keeps burning out
I have a 5th gen Prelude and my right low beam headlight has gone out twice in the past 2 months. I've had the car for about 2 years now and it didn't have this problem until the light burned out a couple of months ago, I replaced it, and now it's out again.
What are some general things I can look for to try and solve this problem?
(And yes, I was very careful not to touch the bulb while installing it)
Thanks in advance
fubar is offline   Reply With Quote
Old 05-06-2005, 09:55 PM   #2
prelude1897
prelude1897's Avatar
Send a message via AIM to prelude1897
Default Re: Headlight keeps burning out (fubar)
Are they aftermarket bulbs?
97 Prelude-wrecked
00 Prelude-Daily Driver
99 Prelude-RHD Prelude http://images.honda-tech.com/set1/smile/emwink.gif
98 Prelude-Parts Car-SOLD
<FONT COLOR="blue">Retrofit service/pics</FONT>
http://www.myspace.com/bceretrofits
prelude1897 is offline   Reply With Quote
Old 05-07-2005, 08:54 AM   #3
BB6racer
BB6racer's Avatar
aftermarket bulbs tend to burn out quicker on my 5th gen. are you wearing gloves when you install the new bulbs? and moisture from your hands on the bulbs will create hot spots on the bulb.
BB6racer is offline   Reply With Quote
Old 05-08-2005, 08:18 AM   #4
Kronn 98SH
Kronn 98SH's Avatar
Send a message via AIM to Kronn 98SH
had the exact same problem with my car....passenger side was burning out every 2 weeks....popped the hood and found that my positive battery cable had corroded through and it was barely connected....this was causing problems elsewhere like my alarm and stereo....fixed it and my aftermarket bulbs have lasted over a year now
1988 Prelude S - victim of an 80mph backflip
1998 Prelude SH - totaled 3/29/12
???? S2000 AP? - still searching
Kronn 98SH is offline   Reply With Quote
Old 05-08-2005, 08:31 AM   #5
LudeyKrus
LudeyKrus's Avatar
Send a message via AIM to LudeyKrus
My first guess would be the one headlight simply burned out, and then you replaced it by using your hands and getting the oils on them. If so, it will continue to burn out quickly until you start using gloves or a clean rag to install the bulb.
1992 Prelude w/ H23-VTEC...handbuilt by me / 1991 MR2 Turbo
1982 Suzuki GS450 - the Rat/Cafe / 1978 Suzuki GS750 - Cafe Racer in Progress / 1977 Harley Sportster - the Chopper
LudeyKrus is offline   Reply With Quote
Old 05-08-2005, 08:43 AM   #6
knightmarauder
knightmarauder's Avatar
i had a similar problem to Kronn. The previous owner's aftermarkey alarm system was hooked up on the headlight circuit. Carefully removed all the old wiring for the alarm and everything's ok.
93 SRV
knightmarauder is offline   Reply With Quote
Old 05-08-2005, 10:12 AM   #7
Kronn 98SH
Kronn 98SH's Avatar
Default Re: (LudeyKrus)
that doesn't seem to be the case....it's most likely electrical
Old 05-08-2005, 10:57 AM   #8
LudeyKrus
LudeyKrus's Avatar
Default Re: (Kronn 98SH)
Ah! Good eye, I missed that. Click the image to open in full size.
Old 05-08-2005, 11:11 AM   #9
Rad Racing
Rad Racing's Avatar
Check the wiring, it can be common to have some messed up wiring in the area of the headlight.
Rad Racing is offline   Reply With Quote
Old 05-08-2005, 02:33 PM   #10
Lude454
Lude454's Avatar
Default Re: (Rad Racing)
it could jsut be fault bulbs to not sure though
did you try zenons
Lude454 is offline   Reply With Quote
Old 05-08-2005, 03:05 PM   #11
limpmode
limpmode's Avatar
Default Re: (Lude454)
i do not know why either, but it is ALWAYS the pass side bulb for me. so i just went back to sylvanias and they never burn out.
[B]Don't Drink and Park... Accidents Cause People[/B]
01 BB6 Silver Prelude
limpmode is offline   Reply With Quote
Old 05-09-2005, 02:24 AM   #12
fubar
fubar's Avatar
Default Re: Headlight keeps burning out (Kronn 98SH)
I'll have to check that out. The car is a 99 with close to 90,000 miles so maybe there could be some corrosion going on.
Old 05-09-2005, 05:39 AM   #13
Sticky Tires
* B A N N E D *
Do a search on it under archives. This topic have been discussed numerous times.
The 5th gen are notorious when it comes to burning out aftermarket bulbs. Even if you installed it properly. I had the same problem when I had my 5th gen. I even had one blow up in my headlight. Click the image to open in full size.
The only ones that lasted a while was PIAA's or sylvannia silverstars (sp?) and Solaris.
My suggestion is, stay stock or invest in a HID kit. With all the money spent on burning out aftermarket bulbs, you're better off with an HID kit.
Even with aftermarket bulbs with 55w (stock), it'll still burn out. The 5th gens don't like aftermarket bulbs. I probably spent close to $300 experimenting aftermarket bulbs.
Sticky Tires is offline   Reply With Quote
Old 05-09-2005, 08:12 AM   #14
incubus
incubus's Avatar
Send a message via AIM to incubus
Default Re: Headlight keeps burning out (Sticky Tires)
if u are using xenon bulbs, the problem could come from you turning ur headlites on before starting the car. I have had this problem with my piaa's. The xenon gas in the bulbs burns at a high temperature to get the color of the bulb closer to sunlite. the problem with this is the xenon gas also protects the filament of the bulb. and a power fluctuation (ie. leaving an accessory on while starting the car)could mean lower temps of the gas which results in no protection for the filament, and ultimately a blown filament.
Since I have stopped turning my headlights on first, I have no longer had a problem with blowing bulbs.
Also if u use a colored bulb, they are higher wattage. Which will often times melt H1 harnesses leading to issues with blowing bulbs. I had this issue with my lude when I first got it. All 4 harnesses were melted. Its about $25 a pop to replace them with upgraded ones.
Information straight from the VP of PIAA. Click the image to open in full size.
'97 NM SH~
tokico Illumas w/ neuspeed springs, AEM intake, DCSports 4-2-1 header
Magnaflow cat, Greddy Evo2 cat-back, 17" 05 RSX-S wheels
Tru amps, QSD 3-ways, Boston SPG-555 sub, premier 980 h/u
http://www.trutechnology.com &lt;= world's best mobile amps
incubus is offline   Reply With Quote
Old 05-09-2005, 08:55 AM   #15
Sticky Tires
* B A N N E D *
Default Re: Headlight keeps burning out (incubus)
You do have a point. I did that for a while. Turn on the headlight after the car has been started and accessories are on. Then turn off the headlights before shutting off the car/accessories.
I got sick of that and bought me a HID kit. Problem solved.
Old 05-09-2005, 12:18 PM   #16
Kronn 98SH
Kronn 98SH's Avatar
i guess i'm out of the loop....i thought it was common sense to turn the lights on AFTER starting the vehicle
91, acura, aftermarket, blows, burning, burns, chopper, ga, gs, gs450, headlight, headlights, integra, passenger, suzuki, wattage
