Stalling problems
Stalling problems
I have a 90 integra GS. It has about 168,000 miles on it. I just changed the alternator about a month ago. The car died on me twice in the middle of driving the other day. I put a new battery in it and tested the alternator. All is fine. Then it died on me again. It happened both times when I was coasting with the clutch in. I pulled the plugs and check them. They are fine. What do you think it could be? Fuel filter. I tried pulling it off but man are the hoses connected tightly. I am a strong guy and couldn't break them loose. I drove it a short distance tonight with no problems. What do you think it could be?
Re: Stalling problems (Soku1kcivic)
Bat terminals are tight and clean. Battery is new. Alternator is new. Why would the car shut off when driving? I pull over and crank the key. It starts again. The first time is started right away. Second time took a while. I had to crank it quite a few times. I then changed the battery and tested the alternator. All was fine. I drove it about another 15-20 miles and when I was coasting the car died again. Started up right away. I drove it another ten miles and everything seemed fine. I just don't want this to continue and be stranded some where. I am narrowing it down to dirty injectors, bad fuel filter or pump. What do you think?
earl2727
06-27-2013 03:15 AM
philkehn
13
09-07-2006 03:58 PM
