The official H/F piston/rod/crank/block specs and CR thread
Old 01-29-2012, 12:54 PM
  #101
HONDA_CIVIC 1992_GR's Avatar
Default Re: The official H/F piston/rod/crank/block specs and CR thread
anyone know from what engine can i put a crankshaft rods for f20b block?with f20b pistons thanks
Old 04-01-2016, 01:30 AM
  #102
enzoferrari's Avatar
The C.R. of the DOHC F22B is higher than the other F22B's. Some say it's 9.3 and some say it's 9.5. Who knows the exact specification of this engine? Specially the rod specifications. Is it the same as other F22's (PT3) or different? (I want to know the rod/stroke ratio)
And, does this block have oil squirt like H22's or not?
Old 02-08-2017, 07:17 AM
  #103
Joshua Arnold's Avatar
The main bearing and rod bearing thickness lists are showing up as just codes and thicknesses.. It doesn't show to what block they're from.
Old 02-08-2017, 08:33 AM
  #104
Moderator
snobordboy's Avatar
The title of the thread states that, these are all for the H/F engines.
Old 02-08-2017, 12:39 PM
  #105
Stay with me here..
Every part listed on this states which block they're for..
Rods
F22:
F20B:
F23:
H22A:
Like that
All that it shows are font codes and colors then .xxxx thickness.. It doesn't say anything about which block it corresponds with..
Old 02-09-2017, 06:15 AM
  #106
Moderator
snobordboy's Avatar
Those are all 50 mm main blocks, so they are all the same....
JafarB
12-09-2013 08:41 PM
cplcueball
06-30-2012 10:06 AM
hdrider
08-05-2009 01:46 PM
jung4g
09-07-2005 06:21 PM
boostin4door
04-12-2005 10:56 AM
Quick Reply: The official H/F piston/rod/crank/block specs and CR thread
