Old 04-29-2005, 09:11 AM   #1
CRXified
CRXified's Avatar
Send a message via ICQ to CRXified Send a message via AIM to CRXified
Default Axel nut and ball joint crown nut torque specs *searched*
what are they on a 93 cx. i got a b16 swap but that shouldnt matter
TIA H-T peeps
93CXB16 <--- R.I.P http://images.honda-tech.com/set1/smile/emthdown.gif
92Si-B <----up and running http://images.honda-tech.com/set1/smile/emthup.gif
http://www.lowmotion.org <---Atlantic Canadas Import Comunity
<U>Good sellers</U>
Redlite, omniman, 00'py-itr, RaceInspired
Originally Posted by dornon13
its so low his wheels are hitting his hood and pushing it up http://images.honda-tech.com/set1/smile/emsmilep.gif
CRXified is offline   Reply With Quote
Old 04-29-2005, 09:23 AM   #2
Aphelion
Aphelion's Avatar
Default Re: Axel nut and ball joint crown nut torque specs *searched* (CRXified)
I'm almost totally sure the axle nut is 134. I know it's between 130 and 140, but I can't remember the last number. The ball joint.... I'm not too sure that it matters. I would just make sure it's 30 or so, and make sure the cotter pin is installed correctly - it's the most important part.
94 EG Si w/ABS
D16Z6 w/15g @ 5psi
Exedy Stage 1 Racing
Fidanza 7.5lb
ARP Headstuds
Apex'i N1 with Magnaflow Cat
14" Honda rims (99-00 opt)
Bridgestone Potenza RE950s
20% Madico Charcoal tint
Aphelion is offline   Reply With Quote
Old 04-29-2005, 09:31 AM   #3
Jericho
Jericho's Avatar
Send a message via AIM to Jericho
Yes, just want itterate Aphelion, use new cotter pins and install them correctly. I reused mine and it ended up going out on me in traffic sending me slamming into a curb, cost me 400 or so to fix and almost my life.
Jericho is offline   Reply With Quote
Old 04-29-2005, 09:44 AM   #4
CRXified
CRXified's Avatar
Default Re: (Jericho)
i seen what happens whne 1 of those ******* let go and i dont want that to happen, my cousin wrote of a 91 civic up over a pile of rocks. if i coudl fit 2 cotter pins i would lol
93CXB16 &lt;--- R.I.P http://images.honda-tech.com/set1/smile/emthdown.gif
92Si-B &lt;----up and running http://images.honda-tech.com/set1/smile/emthup.gif
http://www.lowmotion.org &lt;---Atlantic Canadas Import Comunity
<U>Good sellers</U>
2001, 2005, accord, axel, ball, crown, crv, delsol, honda, joint, nut, pin, specifications, specs, torque
