Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 04-26-2005, 03:52 AM   #1
JOHN WAYNE
JOHN WAYNE's Avatar
iTrader Rating: (1)
Send a message via AIM to JOHN WAYNE
Default Spring Rate Conversions kg/mm - lb/in
I dont know if this is a repost, so I apologize if it is.
Google's new units conversion tool is pretty handy so I went ahead and did some metric to standard conversions for spring rates:
Metric to Standard
1 (kg / mm) = 55.9974146 pounds / in
2 (kg / mm) = 111.994829 pounds / in
3 (kg / mm) = 167.992244 pounds / in
4 (kg / mm) = 223.989658 pounds / in
5 (kg / mm) = 279.987073 pounds / in
6 (kg / mm) = 335.984488 pounds / in
7 (kg / mm) = 391.981902 pounds / in
8 (kg / mm) = 447.979317 pounds / in
9 (kg / mm) = 503.976731 pounds / in
10 (kg / mm) = 559.974146 pounds / in
11 (kg / mm) = 615.971561 pounds / in
12 (kg / mm) = 671.968975 pounds / in
13 (kg / mm) = 727.966390 pounds / in
14 (kg / mm) = 783.963804 pounds / in
for just about any conversion you want, just type in "x units in y units" in the google search box. example: "14 kg/mm in lb/in"
Two white cars, and a silver one too
ima Close dis Bitch..and get it tuned for fun
JOHN WAYNE is offline   Reply With Quote
Old 04-26-2005, 06:32 AM   #2
AnToNy
Default Re: Spring Rate Conversions kg/mm - lb/in (JOHN WAYNE)
It is a repost, as a matter of fact I've been reading on suspension all morning.
Its still a good post, some very helpful info to all. Click the image to open in full size.
AnToNy is offline   Reply With Quote
Old 04-26-2005, 06:38 AM   #3
DsITR
DsITR's Avatar
Send a message via AIM to DsITR
Another spring calc
http://www.dfaulknersprings.com/convert.htm
D
97 ITR #262
vouch thread http://www.honda-tech.com/zerothread?id=628329
DsITR is offline   Reply With Quote
Old 04-26-2005, 06:52 AM   #4
JOHN WAYNE
JOHN WAYNE's Avatar
iTrader Rating: (1)
Default Re: Spring Rate Conversions kg/mm - lb/in (FunctionMotoring)
i was thinking that maybe there should be some sort of FAQ thread kept as a sticky that held some of this type of information.
Old 04-26-2005, 06:56 AM   #5
MattD@Stoptech
MattD@Stoptech's Avatar
Do you really need a post on how to multiply by 56?
LEARN ABOUT BRAKES HERE:
[url="http://www.stoptech.com/tech_info/tech_white_papers.shtml"]http://www.stoptech.com/tech_i...shtml[/url]
'97 M3
'06 F650
MattD@Stoptech is offline   Reply With Quote
Old 04-26-2005, 07:01 AM   #6
Mike_C
1993 Honda Civic
My Garage
Mike_C's Avatar
Default Re: Spring Rate Conversions kg/mm - lb/in (El Pollo Diablo)
but you don't get the decimal places with that method! the decimals are important!
http://www.iammike.org
XBOX: iammikeDOTorg
Current: 93 Civic, 05 TCR2, 09 1x1, 09 Scale 29er, 10 GTI
Past: 86 Delta 88, 91 Accord, 95 Integra, 97 VFR, 01 Big Sur, 01 S2000
Mike_C is offline   Reply With Quote
Old 04-26-2005, 07:04 AM   #7
JOHN WAYNE
JOHN WAYNE's Avatar
iTrader Rating: (1)
Default Re: Spring Rate Conversions kg/mm - lb/in (Mike C)
ha ha ha...geez go easy on a guy Click the image to open in full size.
10, 13kg, 14, 14kg, 6kg, conversion, convert, inlb, kgmm, lb, lbin, pound, pounds, rate, spring
