Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 04-23-2005, 01:35 PM   #1
IloveNewt
IloveNewt's Avatar
Default Very fine red/rustish looking dust inside distributor cap???
As the subject states, there is this very fine redish/rustish looking dust covering the inside of my cap. Is this OK? Normal? Anyone else have this? My ignition setup is stock except for a msd blaster coil.
IloveNewt is offline   Reply With Quote
Old 04-23-2005, 03:37 PM   #2
non-VTEC
1995 Acura Integra
non-VTEC's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (MordecaiPSI)
i do belive that redish dust/rust is coming from your distributor bearing. its on it's way out......you should be replacing it soon. $$$
95 Integra Turbo - SOLD
2014 Toyota Corolla S
non-VTEC is offline   Reply With Quote
Old 04-23-2005, 04:03 PM   #3
BlueSi2k
BlueSi2k's Avatar
Send a message via AIM to BlueSi2k
Default Re: Very fine red/rustish looking dust inside distributor cap??? (non-VTEC)
you may be gettin some moisture inside the cap. How did you run the wires from the external coil? Have you washed under your hood lately?
00 EBP Civic Si Turbo - sold http://images.honda-tech.com/set1/smile/emsad.gif
01 SSM S2000 - current http://images.honda-tech.com/set1/smile/emsmile.gif
BlueSi2k is offline   Reply With Quote
Old 04-23-2005, 08:14 PM   #4
IloveNewt
IloveNewt's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (BlueSi2k)
I am not sure what you mean by running the wires from my external coil. You know the H23 came with an external coil stock correct?
Are you sure this is a sign of the distributor going out? Dont dizzies make weird knocking sounds when they start going bad?
Old 04-23-2005, 08:48 PM   #5
EE_Chris
EE_Chris's Avatar
Utzz_
They nicknamed it "Red Death" for a reason - your distributor bushing is about to go. You have to replace the sub-assembly.
EE_Chris is offline   Reply With Quote
Old 04-23-2005, 08:58 PM   #6
FredoSP
FredoSP's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (EE_Chris)
what exactly is the distributor bushing?
400+ Whp Club
Arturbo, Earl, Stan, Len, Boostfed.com http://images.honda-tech.com/set1/smile/emthup.gif
"I rather be tried by 12 then carried by 6" P.O. Diaz, NYPD
FredoSP is offline   Reply With Quote
Old 04-24-2005, 01:38 AM   #7
havok hybrid
havok hybrid's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (FredoSP)
IF you happen you be running a MSD cap .. the red dust is from the glue/filling its breaking down.....
Or its the bushing it you have stock cap.. or both
*www.RACEFWD.com--- The So Cal Scene
*www.steenchassis.com
*www.DoitDyno.com - Compton Rob special PM me.
havok hybrid is offline   Reply With Quote
Old 04-24-2005, 05:01 AM   #8
EE_Chris
EE_Chris's Avatar
Utzz_
Its what the distributor shaft spins on.
Old 04-24-2005, 07:50 AM   #9
mrDFWmechanic
mrDFWmechanic's Avatar
Send a message via AIM to mrDFWmechanic
so when u see this " red death " you have to replace the whole dizzy then
02 Civic EM2 -- sold
98 Eclipse GSX -- sold and blew engine the same day
01 Rhd GD3 Fit -- new toy for next couple of years.
mrDFWmechanic is offline   Reply With Quote
Old 04-24-2005, 08:25 AM   #10
IloveNewt
IloveNewt's Avatar
Default Re: (iROCKtheSOHC)
Damnit.......this distruibutor is less than 5,000 miles old. Anyone know where to get a new OEM dizzy thats not an arm and a leg?
Old 04-24-2005, 04:17 PM   #11
BlueSi2k
BlueSi2k's Avatar
Oh, my bad. On b series you have to run the wires out from the internal coil.
accord, bearing, bushing, cap, civic, corrison, death, distributor, dust, fine, honda, inside, red, replacement, rust
