| Welcome to Honda-Tech! | ||
#1 | |
i just found out that the tps sensor from a D15 is the same as a D16. I heard that u just cant swap it there a certain to install it if not the idle will be off. Is there an easy way to do it?
94<FONT COLOR="blue">EJ1</FONT> sold http://images.honda-tech.com/set1/smile/emsad.gif 99<FONT COLOR="red">EJ8</FONT> new whip http://images.honda-tech.com/set1/smile/emsmileo.gif <FONT COLOR="aqua">M.I.L.F.</FONT> s.q.u.a.d. vouches: handa,impound u can have one of these on me http://images.honda-tech.com/set1/smile/emhammer.gif Quote:
#2 | ||
drill out rivet in your old one and rivet new one on
#3 | |
http://www.knology.net/~jediklc/ Go to the HOW-TO section |
#4 |
and use screw bolts
H M O N G S T R O N G |
#5 |
I use studs with nuts on them, this way its easier to get a open end wrench back there, all you do is loosen the nuts and adjust. If you use screws, its hard trying to get a screw driver in there.
#6 |
use a dremel with a flat disk to make a cut into the bolt thing holding th sensor on the T/B. then use a flat head to unscrew it.
#7 |
1991 Acura IntegraMy Garage |
When the car jerks or stutters (when off the pedal) while coasting, is this a bad tps. Usually happens around 2000rpm.
'89 Civic Sedan LX / '91 DA9 / '92 DB1 |
#8 | |
#9 | |
Location: hittin corners so hard you can taste my rims..
beautifully said.
2007 Element EX, 2004 CBR 600 F4i. |
#10 | |
'93 EG5/ITR - Solo2 racer, weekend canyons '94 DC2/ITR - destroyed by uninsured driver .......'00 Hayabusa - Landspeed racer |
#11 | |
Thanks guys!
So i have to get near .5 or is it .45 when closed throttle? How about open throttle how do u calibrate the tps or it doest matter?
#12 |
I don't get why honda didn't just use regular screws...when i changed my tps..I had to hacksaw that bitch like there was no tomorrow just for me to unscrew it...wtf is the point of making use make our own indentations!?
[ EM1 Crew ] 99' FBP EM1 |
#13 |
some jdm t/b have torx bolts to fasten tps.... if u ever wanted to know??
#14 | |
#15 |
DC SQUAD #0207 KANTOT SQUAD #06 VOUCHES:Diverse/RoaringTurtle/Diverse[714]/[626]96-GSR/akhom/Blitzed/Integra N Civic/stockdc2/CivicFreak/civicflnum1/jennifermike/98DC2R/NA-Cutie/stuck209/diversegsr/DC2_TypeR/SilverCIVIC96/TheGSRGuy/mark_is_gay/nezfotnemom/b20eg9/Sicarius82/ONEhb2NR |
#16 | |
- 00 Honda Civic HB (Flamenco Black) - 05 Honda S2000 (Moonrock) |
| Tags |
| 00, 2004, b16, b16a, body, civic, honda, instal, install, installing, percent, s2000, sensor, throttle, tps |
