zc sohc block with pm7 pistons and a y8 head, ????????
Old 04-12-2005, 11:19 PM
civtegra_hybrid's Avatar
Default zc sohc block with pm7 pistons and a y8 head, ????????
hey I need to know quick I putting this set up, on a zc block (sohc) with pm7 pistons (89 integra), on a y8 head. dose any one know if it will clear???? do I have to advan or retard the timing at all???? is any one running this set up.? pls help building block tommorrow, (spun a rod bearing on old block) pls bump if you check it out, thanks
Old 04-12-2005, 11:22 PM
Default Re: zc sohc block with pm7 pistons and a y8 head, ???????? (civtegra_hybrid)
bump
Old 04-13-2005, 06:17 AM
bump anyoone?????????????????
Old 04-13-2005, 06:44 AM
JIDUM_Undercover's Avatar
haha wow that was the exact same setup i was running in my ef a while back before i realised how much i love bseries. But regarless slap it together torque everything right and roll out, its a pretty quick motor i beat gsr's and si's.
Old 04-13-2005, 06:49 AM
egizzle8
Guest
Posts: n/a
Default Re: (JIDUM_Undercover)
knology.net is your friend
Old 04-13-2005, 07:49 PM
thanks bro there was not prob with the clearance ?
Old 05-26-2005, 11:28 AM
MiG-21 superfan
builthatch's Avatar
Default Re: (civtegra_hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtegra_hybrid &raquo;</TD></TR><TR><TD CLASS="quote">thanks bro there was not prob with the clearance ?</TD></TR></TABLE> this is old but just to clarify---
no. there is no issue with clearance- you can even run a hefty cam with p29 piston/ y8 head and have no issues (as long as the head has not been milled extensively (more than .010) and the block hasn't been decked more than .010
vtechsauce
11-08-2010 12:34 PM
xymantec
06-13-2010 01:22 PM
Dante Civic
02-11-2008 10:42 AM
CivicRaping
03-19-2005 04:57 PM
the jdmchop
02-03-2004 10:12 AM
Quick Reply: zc sohc block with pm7 pistons and a y8 head, ????????
