Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 04-10-2005, 06:26 PM   #1
HatchBox
Skoobie no more...
HatchBox's Avatar
Send a message via AIM to HatchBox
Default how long does it take for gas to 'go bad'.
Well my car was on the road a few months ago, and while it was i filled it up, well i went to start it and it runs like crap. Im not sure if its bad gas or not.
So typically how long does it take. Its 93 octaine if that plays any role.
HatchBox is offline   Reply With Quote
Old 04-10-2005, 06:34 PM   #2
disabled
disabled's Avatar
i dont think it can go bad, it just evaporates
disabled is offline   Reply With Quote
Old 04-10-2005, 06:35 PM   #3
HatchBox
Skoobie no more...
HatchBox's Avatar
Default Re: (disabled)
Well when it evaporates what does it leave? A less combustable fluid?
Old 04-10-2005, 06:51 PM   #4
spyderracing
spyderracing's Avatar
Send a message via AIM to spyderracing
Default Re: (HatchBox)
If it's within the gas tank it would probably just condense on any surface it can (aka it would just turn back into gas.)
I need eg front LCA's (w/ bushings) and Half shafts!
http://www.hondamarketplace.co...id=68
spyderracing is offline   Reply With Quote
Old 04-10-2005, 06:52 PM   #5
Veritas-Aequitas
Grumpy Old Man
Veritas-Aequitas's Avatar
Don't listen to these idiots.
Gas goes bad after a few months. Try to give your gas tank a smell you'll know if it's bad.
Contrary to the cliche, genuinely nice guys most often finish first or very near it.
Malcolm Forbes
Veritas-Aequitas is offline   Reply With Quote
Old 04-10-2005, 06:55 PM   #6
HatchBox
Skoobie no more...
HatchBox's Avatar
Default Re: (RebornGSR)
Hmmm, i thought gas went bad. haha
Is it not as potent as regular gas?
Old 04-10-2005, 06:58 PM   #7
Veritas-Aequitas
Grumpy Old Man
Old gas looses its octane rating and forms big gooey polymers.
If it really smells like varnish and bad Parmesan cheese you will probably need to drain the tank and change the fuel filters.
If it still smells somewhat good you can probably get away with adding 104+ Octane boost because that will help boost the octane back up and it also contains detergents that will dissolve minor polymer deposits.
Malcolm Forbes
Old 04-10-2005, 06:59 PM   #8
Veritas-Aequitas
Grumpy Old Man
Next time just add fuel stabilizer and let it run through the system before you leave it sitting Click the image to open in full size.
Malcolm Forbes
Old 04-10-2005, 07:00 PM   #9
HatchBox
Skoobie no more...
HatchBox's Avatar
Hmm, i just went to take a wiff, and smells like gas.
that NOS stuff is 104 right?
yeah i will just drain the tank and put that 'bad fuel' in my buick Click the image to open in full size.
Old 04-10-2005, 07:06 PM   #10
Veritas-Aequitas
Grumpy Old Man
I dono I just copy this **** from someone else who knows what the hell they are talking about Click the image to open in full size.
Malcolm Forbes
Old 04-10-2005, 07:06 PM   #11
HatchBox
Skoobie no more...
HatchBox's Avatar
Cheater, haha
ok well im just gonna put the gas in my beater then fill the civic up with pump gas Click the image to open in full size.
Old 04-10-2005, 07:08 PM   #12
del_parker
del_parker's Avatar
Default Re: how long does it take for gas to 'go bad'. (HatchBox)
I just drain the bad gas and put it into my dad's F150. Runs like a champ on it. Click the image to open in full size.
del_parker is offline   Reply With Quote
Old 04-10-2005, 07:12 PM   #13
HatchBox
Skoobie no more...
HatchBox's Avatar
Default Re: how long does it take for gas to 'go bad'. (del_parker)
im sure my buick wont mind the gas, hell i put stewart gas in it. (shitty)
Old 04-10-2005, 08:01 PM   #14
civickiller
1996 Honda Civic
civickiller's Avatar
Send a message via AIM to civickiller
my car, 91 civic dx 1.5 dpfi, sat for 3 years. after 3 years, started it up. drove to a gas station and filled up. it ran fine to the gas station. then i drove lot within the next couple days to bring it down to E then i filled it up again. most of the gas should be gone.
i wouldnt do this with a performance motor like a b16 but with a stock sohc motor, its all good
Originally Posted by Turbo-LS View Post
Boost is like crack cocaine of the automotive world.
Diagnosed w/MS June '06
civickiller is offline   Reply With Quote
Old 04-10-2005, 08:07 PM   #15
The Phil
Send a message via AIM to The Phil
Default Re: how long does it take for gas to 'go bad'. (civickiller)
Um yeah Click the image to open in full size.
The Phil is offline   Reply With Quote
Old 04-10-2005, 08:28 PM   #16
marsbike
marsbike's Avatar
Location: Salt Lake City, Chicago at heart, UT or IL, USA
Send a message via AIM to marsbike
Default Re: how long does it take for gas to 'go bad'. (xthephilx)
hmmm...I guess I gotta drain the tank in my benz...It's been sitting for a little too long...so...umm....yeah...(five years...no sta-bil) It still runs...kinda...but, I don't exactly want to take it out with the brakes being in the condition they're in anyways...
Marshall
04 Subaru Forester XT Daily!
http://www.wasatchviolins.com
TUNA
marsbike is offline   Reply With Quote
Old 04-11-2005, 12:31 AM   #17
civickiller
1996 Honda Civic
i mean as a motor that uses 91 octane vs a stock sohc 1.5 that could probably use lower than 87
Old 04-11-2005, 01:00 AM   #18
1998hondaaccord
1998hondaaccord's Avatar
It takes 30 days to go bad.Try to use fuel stabilizer if your going to let it sit.
Most problems with lawn equipment is due to people lettting old gas sit in the tank and carb for months.It causes the carb to gum up and not fuel pass. Not crappy equipent just poor care.
My car-1998 Honda Accord 4cyl,auto trans
Wifes car-2000 Accord V6 auto trans
1998hondaaccord is offline   Reply With Quote
87, 91, 93, bad, calif, car, fuel, gas, gasoline, long, octane, regular, sitting, tank, years
