#26 | |||||
#27 |
H-T White Ops
subscribing until I can find a place to print this thing out at.
to you for a great writeup.
#28 | |
#29 | |
You are correct! You will achieve some nice results after the cat because the inherent restriction the cat induces .... I'll respond later to other posts ... too many tonight at the bar...
#30 | |
#31 | |
Some concerns of mine: 1) You would need to use 2 separate catchcans. 1 in-line between the crankcase/Intake and 1 between the crankcase/Intake manifold. 2) I would run a check valve after the PCV valve because the PCV valve may leak under boost when the Intake manifold pressurizes. 3) In High vacuum in the Intake manifold the PCV valve would be slightly open thus the vacuum generated would be minimal in low load conditions(this is good). 4) You should also run a check valve(not PCV) in-line between the crankcase/ intake because in low load conditions the vacuum created in the intake manifold could possible draw air from the intake. The advantage this setup has to offer over simply using a slash-cut tube in the Intake (preturbo) is that it will provide some additional vacuum at idle and low load conditions. The disadvantage is that you will still contaminate your intake charge; now even more so because you have vacuum being drawn directly to the Intake manifold instead of trapping most of the contaminants in the Inter cooler piping and Inter cooler . Consequently you will get more contaminants in your Intake manifold also. Another disadvantage is that this setup is more costly and complex than the other method because you have to run 2 separate catchcans. PCV valves also tend to fail more often than regular check valves |
#32 | |
Placing the slashcut before the cat is a bad idea because the cat is so restrictive and creates a large amount of pressure which will sometimes fight its way up the evacuation line. After the Cat their is no such restriction. I could probably get better results to mimic yours if I placed my slashcut slight further down the exhaust and after my resonator. The moroso spiral flow resonator is not a true straight-through resonator and is slightly more restrictive. |
#33 |
1998 Honda Civic |
Finally a concrete write-up on this sh!t!
#34 |
Thanks for the insight dasher!
1990 Acura Integra GS-T 2.0L GSR/ITR, GT35R 11.180 @ 140.86mph - 545whp/383wtq - SOLD |
#35 | |
subscribing
JLB Motorsports PSN: BrokeAssPinoy Quote:
#36 | |
they also told me you don't want to run an electric vacum pump for street use. forgot the reasons, but I think it had to do with pump being on all the time... either way great write up!!
#37 | |
#38 |
Sorry if this is a stupid question:
when using the "intake slashcut" method, am I supposed to route both the PCV AND the valve cover breather to the compressor intake? |
#39 | |
Very nice write up. What is the most complete kit for the b series motor out there? I have a catch can, but it only has one port
http://www.hondamarketplace.com/zerothread/2168910 12.9 @ 108...9ibs |
#40 |
I like the electric brake booster pump idea. Seems like rigging a linear amplifier running off the map sensor voltage would be a great way to linearly increase vacuum with load. Just some heavy duty semiconductors...
'00 Honda Insight 5-spd - Commuter '94 Civic Sedan - D16Z6 *boosted* - Auto-x toy '04 Toyota Prius - Wife's Car |
#41 |
Damnit! I need more time to read this thread, sounds like something useful to know and to need. for my car.
Some cliffs notes on whats recommended? LOL!@ If not, fine, ill read..later on when i got time.
I <3 Boost! |
#42 | |
Any catchcan would work inline. The Moroso catchcan can be also used without the breather filter. If your catchcan is not baffled then add surface area inside the catchcan to trap more contaminants. |
#43 | |
Be a little more daring guys and try the slashcut exhaust method and slashcut wastegate method in tandem. I do! My lines running from the back of the block to my Moroso catchcan are mostly sucking in fresh air now. My oil stays cleaner and my car feels great. |
#44 | |
Have fun toying with this idea. I know I did. Then I began to realize that it is important to "Keep it Simple" when it comes to pulling vacuum from the crankcase. One mistake, one fluke, one electrical problem and your engines toast! |
#45 | |
1) Weld/Jb weld in a second port in the catchcan. 2) Only use one fitting on the back of your B series block. |
#46 |
dasher,
moroso offers a vacuum pump for $450 i believe. just tap your valve cover and run a belt to the crank pulley and attach a catch can to the pump. i was looking into this option. i stated before in a previous post about how v8 guys do this all the time to help reduce crankcase pressure and help seat the rings. other options include obtaining a air pump from a gm that was used to introduce air into the exhaust stream for emissions, but rather using that as a air pump to draw out the HC's from you crankcase. |
#47 | |
http://www.moroso.com/catalog/...17200 I'm sure if you are creative you can remove your Ac compressor, modify a custom bracket, pulley and belt and try and tune it so it pulls an appropriate amount of vacuum. Seems like alot of work to me. You do not want to run their original race pump either(part numbers 22640 and 22641) because they are only made to spin up to 6000 RPM maximum. When all is said in done your money would be much better spend at z10eng because they will prove you an off the shelf setup or custom one that includes a lot more than just a vacuum pump. |
#48 | |
#49 |
subscribed
done business with: Prelude1897, ssr h22, Laz's EP, lsvtecracer, importricer, drdisco im me for headlight retrofitting |
#50 |
I read a article in Hot Rod on this topic last year. They found a vacuum pump on a Ford Taurus. They where able to get 5 hp out of a v8 with the mod. I told my brother to look for the article since I didn's save it. He told me drag cars use vacuum on their cars. They weld a tube at 45 degree angle on the exhaust pipe and run a line up to there valve covers. The exhaust flowing by the tube creates a vacuum. It would be linear.
| Bookmarks |
| Tags |
| b16a2, breather, catch, chamber, civic, crankcase, evacuationturbo, excessive, filter, hook, hose, line, oil, pcv, pressure, turbo, wastegate, water |
