Old 04-01-2005, 07:00 AM   #1
90AcuraIntegra04
90AcuraIntegra04's Avatar
Default 90 integra transmission fluid
Where is the easiest area to fill the transmission fluid on a 1990 Integra with a ls mosot. I heard the sppedometer cable area? Thanks
90AcuraIntegra04 is offline   Reply With Quote
Old 04-01-2005, 07:09 AM   #2
G-bonic
Hijacked
Send a message via AIM to G-bonic
Default Re: 90 integra transmission fluid (90AcuraIntegra04)
hope this one will help.. http://www.team-integra.net/se...D=644
G-bonic is offline   Reply With Quote
Old 04-01-2005, 07:12 AM   #3
purplegsr
purplegsr's Avatar
You can use the VSS, it's located on top of the tranny casing toward the top right (although you may have to move your intake hose out of the way if the stock one is still in there). You should see a kinda bulky looking thing with a bolt in it, loosen the bolt, lift it out, and that hole goes directly into your transmission.
I never do it that way however. I tend to just do it the traditional way, so I can see the fluid drip out of the fill hole. I use a longish clear extension hose attached to a funnel by a zip tie.
here is a pic of it from this write-up (for a Civic, but it's the same):
http://www.honda-tech.com/zerothread?id=382416
purplegsr is offline   Reply With Quote
Old 04-01-2005, 07:14 AM   #4
purplegsr
purplegsr's Avatar
Default Re: 90 integra transmission fluid (Stock_LS)
Wrong write-up, he wants to change his tranny oil, not replace his clutch fluid.
Old 04-01-2005, 07:23 AM   #5
G-bonic
Hijacked
Default Re: 90 integra transmission fluid (purplegsr (Exospeed))
ooppss my bad, there u go man Click the image to open in full size. thanks for head up ! Click the image to open in full size.
http://www.team-integra.net/se...D=301
view page 2 Click the image to open in full size.
Modified by Stock_LS at 8:37 AM 4/1/2005
Old 04-01-2005, 07:27 AM   #6
purplegsr
purplegsr's Avatar
No problem, it's frickin early, us Cali people need our coffee before posting.
Old 04-01-2005, 07:38 AM   #7
G-bonic
Hijacked
that for sure Click the image to open in full size. have some coffe break, hit starbucks Click the image to open in full size.
Old 04-01-2005, 07:51 AM   #8
chriskona
chriskona's Avatar
Send a message via AIM to chriskona
thats how i do mine, so much easier than the cable way ;P
Tri-State event Coverage / http://www.AutoRush.com
My 93 Integra Project
DA Squad Member #256
bf2: blue.m&m
xfire: chriskona
chriskona is offline   Reply With Quote
Old 04-01-2005, 10:37 AM   #9
Racermech
Racermech's Avatar
Default Re: 90 integra transmission fluid (chriskona)
So you can pull the speed sensor out of any B seriers tranny?? Wow that looks much easier then trying to fill it throught the fill hole.
But as you are filling it from the top cant you over fill the tranny? Or do you need to be carefull and actually measure out 2.3qt
Originally Posted by twentyhurtz
last but not least, the best, how do i keep rats from getting under the hood and quit chewing on my 80 dollar accel wires and vac lines? its pissing me off.
Racermech is offline   Reply With Quote
Old 04-01-2005, 10:41 AM   #10
Toadfart
2005 Honda CBR600RR
My Garage
Toadfart's Avatar
Default Re: 90 integra transmission fluid (Racermech)
Make sure your car is level and take out the fill bolt. Fill through the VSS until the oil starts to flow out of the fill hole. That's it!
Dan
Proper Prior Planning Prevents Piss Poor Performance.
Toadfart is offline   Reply With Quote
Old 04-01-2005, 10:43 AM   #11
purplegsr
purplegsr's Avatar
It is slightly easier, you can either measure out the perfect amount (~2.3) or leave the fill hole open and let it dribble out when full. Since they are on different sides of the tranny, it won't spill out until you're done, so you don't have to keep the fill bolt in while filling from the VSS. I think it's a pain though, I still use my hoses, zipties, and a funnel, I am too lazy to undo an extra bolt.
Old 04-01-2005, 12:04 PM   #12
Racermech
Racermech's Avatar
Ok thanks, I missed the part about pulling the fill bolt when you fill from the VSS
90, 93, bolt, change, changing, check, fill, fluid, fluids, integra, location, trans, transmission, type, vss
