Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Motorcycles
Old 03-27-2005, 01:39 PM   #1
JOJO0420
JOJO0420's Avatar
Default 04 Cbr 600 rr laid down wont start
Is there a rest somewhere on the ecu or a breaker switch of some sort on the bike????
JOJO0420 is offline   Reply With Quote
Old 03-27-2005, 01:56 PM   #2
typeeg
typeeg's Avatar
Default Re: 04 Cbr 600 rr laid down wont start (JOJO0420)
Try push starting it. After my R6 fell down I couldn't get it to start so that's what I did. After a nice ride it was fine.
typeeg is offline   Reply With Quote
Old 03-27-2005, 02:20 PM   #3
JOJO0420
JOJO0420's Avatar
it is not getting power
Old 03-27-2005, 02:47 PM   #4
typeeg
typeeg's Avatar
Default Re: (JOJO0420)
explain?
Old 03-27-2005, 02:50 PM   #5
hybridreams
hybridreams's Avatar
Default Re: (Reckless636)
try banging on the tail a little. if i remember correctly, there's a ball somewhere in there that tells the bike if it's on its side, and shuts the bike off if laid down. sometimes the ball gets stuck.
somebody back me up on this or tell me im crazy.
Will | '05 Nissan Frontier | '07 Suzuki GSX-R600
hybridreams is offline   Reply With Quote
Old 03-27-2005, 03:05 PM   #6
Veritas-Aequitas
Grumpy Old Man
Veritas-Aequitas's Avatar
Default Re: (hybridreams)
You're not crazy, it's the tipover sensor.
When the bike leans to far to one side the circuit is completed and the bike shuts off. Not quite the ball rolling around in the tail that you make it out to be Click the image to open in full size.
They are usually in the tail of the bike somewhere Click the image to open in full size.
Maybe a 600rr owner will chime in on exactly where it is on your bike.
Contrary to the cliche, genuinely nice guys most often finish first or very near it.
Malcolm Forbes
Veritas-Aequitas is offline   Reply With Quote
Old 03-27-2005, 03:16 PM   #7
EG8R
EG8R's Avatar
Default Re: (RebornGSR)
If you are talking about a "bank angle sensor" it located towards the front, maybe in the nose section? I don't know exactly where, sorry. Wire harness leads towards the rear...
95 Civic LX-C5 powered -- Ferio EG Squad #39 - SOLD
90 Civic SiR - Yes a REAL EF9! -- Sh!tbox EF9 Squad #1
06 Civic LX-right $h!tty
EG8R is offline   Reply With Quote
Old 03-27-2005, 03:18 PM   #8
JoshRambo
JoshRambo's Avatar
Send a message via AIM to JoshRambo
Default Re: (skelly ed666)
Maybe a stupid question. But did you hit the kill switch when you laid it down?
2002 VW GTI 1.8T
2004 Candy Blue CBR 600RR
- Jardine FULL Exhaust(Jardine Video Clip)
- BLING! BLING! Gold Rims
- Renthal 15/45 Sprockets
- D.I.D VM2 Chain
- PC III
- BMC Race Filter
Former Owner of:
2001 NightHawk Black ITR 01-0310
JoshRambo is offline   Reply With Quote
Old 03-27-2005, 03:20 PM   #9
Ag-Eng
Ag-Eng's Avatar
Take of side panel
Un-hook (-) of battery
Wait a minute
Re-connect battery
Turn RUN switch to "RUN"
Put bike in neutral
Put UP side stand
Pull clutch lever in
Press start button
VIOLA!! You're bike should start
Ag-Eng is offline   Reply With Quote
Old 03-27-2005, 03:37 PM   #10
hondab1015
hondab1015's Avatar
The bank angle sensor is in the upper that the front most part. I installed mine upside down when switching upper, prevented the bike from starting. I felt like a jackass once I figured it out.
2004 Mustang Cobra
580HP 630TQ
2007 Civic Si
200HP 143TQ
hondab1015 is offline   Reply With Quote
Old 03-27-2005, 05:14 PM   #11
ArmyGreenITR
ArmyGreenITR's Avatar
Send a message via AIM to ArmyGreenITR
Default Re: 04 Cbr 600 rr laid down wont start (hondab1015)
Ive put my RR down twice an its started on the first try both times.Does it reset it self?
ArmyGreenITR is offline   Reply With Quote
Old 03-27-2005, 05:16 PM   #12
m.
m.'s Avatar
Send a message via AIM to m.
yea what reborn said, it's prolly your tip over switch aka fuel cut off causing your bike not to start back up. just wait a few mins the start her back up again. idk how hondas tip over are like but suzuki you would have to wait til the magnetic pendulum gets to its vertical position.
m. is offline   Reply With Quote
Old 03-27-2005, 09:21 PM   #13
.Ash
.Ash's Avatar
tilt sensor is in between the headlight lenses behind the upper. it is interesting you have this problem; a friend laid his 04 down and after a while, he held the throttle wide open and kept on cranking. started eventually... you can also bypass the tilt sensor for test purposes but if you can hear your fuel pump you are all set.
THINK
.Ash is offline   Reply With Quote
Old 03-28-2005, 10:55 AM   #14
TurboDX
TurboDX's Avatar
Default Re: (usdmPC3)
well they say you learn something new everyday...thanks...i will need to know this for when it happens to me since there are only two riders...i have not been down but will keep trying not to...
Proud owner of..
Dx-T
600RR
Atima 99
03 Pathfinder
TurboDX is offline   Reply With Quote
Old 03-28-2005, 11:46 AM   #15
Racer_XX
Racer_XX's Avatar
Send a message via AIM to Racer_XX
is your bike in gear while you are trying to start it?
[I]"Be like water making its way through cracks. Do not be assertive, but adjust to the object, and you shall find a way round or through it. If nothing within you stays rigid, outward things will disclose themselves.
Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot it becomes the teapot. Now, water can flow or it can crash. Be water my friend."[/I] --Bruce Lee
Racer_XX is offline   Reply With Quote
2003, 600, 600rr, angle, bank, cbr, laid, reset, rr, sensor, start, switch, tilt, tip, wont
