Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 03-16-2005, 05:08 PM   #1
JRciv
Default I finally did it!!! Knock sensor bypass!! Woot! Woot!
Man, it feels so good getting rid of that CEL. Now I can pass smog!
So if anyone ever needs to bypass their knock sensor without tripping a CEL, here is what you need to know.
First of all, you can't ground it out or replace it with a resistor. The knock sensor is not an electrical load, it actually produces it's own voltage. Your ECU is looking for a variable voltage from the sensor.
So what you want to do is mimic the voltage output. Here is a guide of what to do:
1. First, go to Radioshack and buy a piezo transducer, part #273-073. You will find it will all the buzzers because that it's intended for. It costs $1.99.
2. Flip to the back of your haynes and look at the chassis electrical pages. Find which wire going into your ECU is for the knock sensor. If you have a 96-00 civic, it is the Red wire with a blue stripe. MAKE SURE YOU DON'T MISTAKE IT FOR THE BLUE WIRE WITH A RED STRIPE. That's for your AC system. Cut the wire about 6" from the ECU.
3. Tape the transducer to your fuel rail.
3. Weave a single wire from your fuel rail back to your ECU.
4. Connect the speaker wire to the (+) wire on the transducer.
5. Connect the other end of the wire to the Red/blue wire on your ECU.
6. Connect the (-) wire on the transducer to a good ground.
So basically, the positive wire of the transducer goes to the ECU and the negative wire goes to ground. I taped the transducer to the fuel rail because that's where I found it made the most voltage (most vibration).
The transducer only makes about a half a volt at 4k rpms and the ECU usually sees about 1.5 volts. So if you try this and it doesn't work, you will have to find a better location to tape the transducer or you will have to add a second transducer to bump up the voltage.
JRciv is offline   Reply With Quote
Old 03-16-2005, 08:51 PM   #2
EF-EF
EF-EF's Avatar
damn how'ed you figure that out????
EF-EF is offline   Reply With Quote
Old 03-16-2005, 08:54 PM   #3
Bspec18
Bspec18's Avatar
Default Re: I finally did it!!! Knock sensor bypass!! Woot! Woot! (JRciv)
your ECU was picking up a knock signal ? if you wanted to remove the CEL why don't you just unplug it ?
Since the Knock is a piezo-electric it does produces its own voltage.
J's Racing [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
Camp1320.com [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
Bspec18 is offline   Reply With Quote
Old 03-16-2005, 09:41 PM   #4
turtle-eg
turtle-eg's Avatar
Did you ever just try to plug in a stock knock sensor or did you not have one handy?
'95 EG
81.5mm GSR
522whp 350tq
turtle-eg is offline   Reply With Quote
Old 03-16-2005, 11:35 PM   #5
joetrisman
joetrisman's Avatar
Send a message via AIM to joetrisman
Default Re: I finally did it!!! Knock sensor bypass!! Woot! Woot! (turtle-eg)
I disabled in in uberdata and desoldered the board Click the image to open in full size.
joetrisman is offline   Reply With Quote
Old 03-16-2005, 11:59 PM   #6
JRciv
Default Re: I finally did it!!! Knock sensor bypass!! Woot! Woot! (joetrisman)
Ok, here is what happened.
When I put my JRSC on, I smashed the sensor. When the sensor is broken or removed, it tells the ECU that your knock sensor "circuitry" is bad because it no longer gets the required variable voltage input. That means constant CEL.
Normally, not a problem. When I'm boosting I'm rockin' the P28/uber so the CEL isn't on. But to pass smog, I ziptie the bypass open and swap in my P2P. The CEL used to come back on when I did the swap, now the problem is fixed.
And I was about one day away from cracking and buying a new knock sensor for $60. And to answer the above question, I really don't know how I eventually figured this out. Probably because I did waaaay too much research and already tried just about everything else. Good thing I persevered. Everyone else said this couldn't be done.
Old 03-17-2005, 04:21 AM   #7
mrbsponge
mrbsponge's Avatar
Send a message via AIM to mrbsponge
good job, another hacker is born!
the only time where false knock is good knock!
Lexus SC300 B/W S366 9.51@146 Drag Radial Street Car
Top Dead Center Performance(www.tdcperformance.net)
Mobile Alabama, 251-661-6067, Neptune Dealer/Tuner
mrbsponge is offline   Reply With Quote
Old 03-17-2005, 10:07 AM   #8
xenocron
H-T Basic Sponsor
xenocron's Avatar
Send a message via ICQ to xenocron Send a message via AIM to xenocron
Default Re: (mrbsponge)
Do you notice if the ECU is retarding timing based on this fake "knock" you are getting from the piezo?
Xenocron Tuning Solutions - http://www.xenocron.com - 845.504.5340
Chipped ECUs, Injectors, Fuel Pump, Harnesses, DIY Parts, Widebands, and More
Hondata, eCtune, Neptune, Haltech, Precision Turbo, Injector Dynamics
EFI University Instructor, www.efi101.com
xenocron is offline   Reply With Quote
Old 03-17-2005, 11:01 AM   #9
g2turbo
g2turbo's Avatar
g2turbo
Default Re: (xenocron)
I thought he was simulating normal sensor readings to eliminate the computer from throwing a CEL?
edit: i see what you are asking...
97 Coupe 11.06@129 @16psi - 6765 T3 - SOLD
94 Integra GSR - Time Capsule
98 Civic Hatch - 560/350, getting ready for track
g2turbo is offline   Reply With Quote
Old 03-17-2005, 01:57 PM   #10
JRciv
I'm pretty sure the ECU doesn't pull timing until the voltage reaches about 3v. I can't imagine this transducer putting out more than 1v at WOT.
I'm not positive though.
Old 03-17-2005, 02:11 PM   #11
Sonny
Sonny's Avatar
Send a message via AIM to Sonny
Default Re: (JRciv)
Nice work, man.
If you're only using this setup temporarily to get past smog, it doesn't really matter if it is pulling timing as long as the CEL stays off.
I broke that sensor before, too. It sucks. Click the image to open in full size.
Sonny
2000 Civic Si (Boosted, sold, not missed) | 1987 CRX Si Turbo hybrid (SOLD)
11 sec soup/Turbo/1st Gen Tech -- Here
Sonny is offline   Reply With Quote
Old 03-17-2005, 02:38 PM   #12
dornon13
dornon13's Avatar
Send a message via AIM to dornon13
Default Re: (Sonny)
i broke that sensor too lol but i went obd1 so it didnt matter
dornon13 is offline   Reply With Quote
Old 03-17-2005, 05:59 PM   #13
iimengii
iimengii's Avatar
Send a message via AIM to iimengii
Default Re: (dornon13)
damn good info Click the image to open in full size.
iimengii is offline   Reply With Quote
Old 03-18-2005, 07:31 AM   #14
tealbubble
tealbubble's Avatar
Default Re: (iimengii)
just went and bought the part thanks!
bump for good knowledge
90 CRX /97 Civic Sedan LX-Vtec.... *RIP* buddy you took hearts
93 EX Coupe From D to B to D to B TO SOLD / 92 DXHBTEAL 12.9@109 2.19 60' 195/60R14
06 Ridgeline RTL / 93 DXCOUPE - Bone Stock/Completely Rebuilt
tealbubble is offline   Reply With Quote
Old 03-18-2005, 08:01 AM   #15
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Send a message via ICQ to Muckman Send a message via AIM to Muckman
Default Re:
Would a CEL be triggered if the knock senser was left plugged in but was not in the block?
Integra GSR 13.5:1 GT30R 597hp build
Evo9 MR SE
Muckman is online now   Reply With Quote
Old 03-18-2005, 09:23 AM   #16
xenocron
H-T Basic Sponsor
xenocron's Avatar
Default Re: Re: (Muckman)
Probably after a while if it didnt see any voltage, it would think something is up...
Old 03-18-2005, 10:48 AM   #17
dustin
Default Re: Re: (slow poke)
The stock honda knock sensing system isn't useful with a boosted car... heh.
dustin is offline   Reply With Quote
Old 03-18-2005, 10:58 AM   #18
Brodie Bruce
Brodie Bruce's Avatar
Default Re: Re: (dustin)
Yes, it will
I have experienced it
[B]LAKERS[/B] [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
Brodie Bruce is offline   Reply With Quote
Old 03-18-2005, 11:15 AM   #19
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Default Re: Re: (xavenged7x)
Just wondering, bc you can pull the oil pressure sensor out of the block and it wont trigger the oil light if its still plugged in. Thx
Evo9 MR SE
Old 03-18-2005, 11:24 AM   #20
dustin
Oil sender doesn't go to the ECU.. just the dash light. It gives ground when there is no oil pressure. So if you disconnect it from the block (ground), the light is not gonna show up hehe.
Old 03-19-2005, 03:24 AM   #21
p3lon21
p3lon21's Avatar
do a d16z6 comess with knock sensor
p3lon21 is offline   Reply With Quote
Old 03-19-2005, 05:27 AM   #22
Zakar
Zakar's Avatar
how accurate are the honda knock sensors?
obviously EGT/WB is the only way to go
Originally posted by Raoul Duke
Few people understand the psychology of dealing with a highway traffic cop. Your normal speeder will panic and immediately pull over to the side. This is wrong. It arouses contempt in the cop-heart. Make the bastard chase you. He will follow.
Zakar is offline   Reply With Quote
Old 03-19-2005, 12:07 PM   #23
JRciv
Default Re: (Zakar)
No, the z6 does not have a knock sensor.
And from what I've read, stock honda knock sensors are a joke. They only detect knock under certain circumstances, like certain RPMs or something.
Old 03-19-2005, 01:44 PM   #24
Flr Power
Flr Power's Avatar
They work very well thank you.
Woo-ooo
Flr Power is offline   Reply With Quote
Old 03-20-2005, 07:19 AM   #25
tealbubble
tealbubble's Avatar
Default Re: (Flr Power)
why do you have to put it in the engine bay? isnt the least movement better but i tried it and its turning on but still throwin the code but mine is still in the car....
accurate, adding, bypass, d16z6, h22, honda, knock, p2p, remove, s2000, sensor, sensors, v6, voltage, wire
