Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 03-15-2005, 04:21 AM   #1
ZygSpeed
Default Should you check the oil hot or cold?
Cold ... car hasn't been started and all the oil is in the oil pan (will read relatively higher).
Hot ... car was running and oil will be throughoutthe motor and head (will read relatively lower).
How much of a measured difference is this?
ZygSpeed is offline   Reply With Quote
Old 03-15-2005, 04:27 AM   #2
Chris F
Chris F's Avatar
Send a message via AIM to Chris F
Default Re: Should you check the oil hot or cold? (zygspeed)
I never have seen a measurable difference, not like you can get 0.1 quart resolution on your dipstick Click the image to open in full size. I'd guess the levelness of the car would make a bigger difference. Thermal expansion of the oil makes a difference too.
I try to check it hot, like when filling gas etc.
Don't check it while its running Click the image to open in full size.
Chris Fries - #117 H1 Prelude - now with more VTEC (Thanks [url="http://kingmotorsports.com"]King![/url])
2007 and 2008 Midwest Honda Challenge H1 Champion
Go to Estrada Customs in Libertyville, IL! Great place for any body work!
Chris F is offline   Reply With Quote
Old 03-15-2005, 04:28 AM   #3
Chris F
Chris F's Avatar
Default Re: Should you check the oil hot or cold? (Chris F)
http://www.ehow.com/how_103_check-oil.html
Edit to avoid three-in-a-row...
http://www.advanceautoparts.co....html
There is an ongoing argument as to whether or not it is better to check your oil when the engine is hot, or when the engine is cold. The cold crowd will argue that when the engine is cold and at rest, all the oil is in the pan, and therefore the dipstick will give the most accurate reading. The hot crowd will argue that oil expands when hot, so the best time to check the oil is when the engine is warm.
Old 03-15-2005, 04:31 AM   #4
ZygSpeed
Do you know what the owner's manual recommends?
I've noticed a substantial difference between hot and cold readings in the past, and most recently when I changed the oil "accidentally" overfilled it a good bit ...
Old 03-15-2005, 04:34 AM   #5
Chris F
Chris F's Avatar
I'm sick, in my PJ's and don't feel like leaving the appartment to check my glove box/doorjamb. Click the image to open in full size.
Lazy bastard. I swear it's supposed to be measured hot, but I have been known to be wrong.
Old 03-15-2005, 04:37 AM   #6
ZygSpeed
haha ... I did go to the store yesterday around 4:30 pm, at which time I cheched the doorjam, which said : 35 F 33R cold.
I'll go grab the owner's manual some time this afternoon. Click the image to open in full size.
Old 03-15-2005, 04:47 AM   #7
revvin9k
revvin9k's Avatar
Chris, I love your blunt honesty. Click the image to open in full size.
OCD ISN'T A DISEASE, IT'S A LIFESTYLE.
revvin9k is offline   Reply With Quote
Old 03-15-2005, 04:52 AM   #8
Chris F
Chris F's Avatar
Default Re: Should you check the oil hot or cold? (S(J)O(D)L(M))
It was actually a direct quote from another thread, but I figured I'd pull that out for this one Click the image to open in full size.
Old 03-15-2005, 04:55 AM   #9
RedR
RedR's Avatar
I start the car for 5 seconds, turn it off and check the level.
b00sted
RedR is offline   Reply With Quote
Old 03-15-2005, 05:33 AM   #10
Bbasso
Bbasso's Avatar
I check the oil when ever I have too Click the image to open in full size. ...
But every morning I check the oil before I start it and for some reason it's always low Click the image to open in full size.
Bbasso is offline   Reply With Quote
Old 03-15-2005, 05:57 AM   #11
vtec.dc2
vtec.dc2's Avatar
oil is all over the place after the car has been moving, although i don't notice much difference if any other than its easier to read when cold because it changes color.
vtec.dc2 is offline   Reply With Quote
Old 03-15-2005, 06:53 AM   #12
baonest
Send a message via AIM to baonest
Default Re: Should you check the oil hot or cold? (vtec.dc2)
i try to let it sit for a few minutes after it has been motor has been running.
as long as it is near that top dot. im good to go.
98R 121000 miles. still holds oil. Click the image to open in full size.
lude
baonest is offline   Reply With Quote
Old 03-15-2005, 07:31 AM   #13
Jon D
Jon D's Avatar
i religiously check mine after i have turned off the car and let it sit for approximately 15 minutes. That way the amount of hott oil circulating has settled and you'll have an accurate reading. I will also check it cold, but only if the car has sat for sometime and i simply have not checked it as regularly as i usually do.
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m
....Camino del éxito!
Jon D is offline   Reply With Quote
Old 03-15-2005, 07:39 AM   #14
cryptikman
cryptikman's Avatar
Default Re: Should you check the oil hot or cold? (Jon D)
I check my oil level whenever I get gas. So when it is hot.
cryptikman is offline   Reply With Quote
Old 03-15-2005, 01:57 PM   #15
Utilitarian
Utilitarian's Avatar
Default Re: Should you check the oil hot or cold? (cryptikman)
That makes two of us.
Unless it's cold, raining, and windy when pumpin' gas.
2001 NBP ITR #0613 | 2003 Black Onyx IS300 5MT w/ LSD
gone but not forgotten... 1997 CW ITR #0050 | 2000 FBP ITR #0055
Utilitarian is offline   Reply With Quote
Old 03-15-2005, 02:06 PM   #16
mugenracer
mugenracer's Avatar
Send a message via AIM to mugenracer
This same topic came up on a UK honda forum not solong ago, someone said that honda's official word on this was to check it about 5 minutes after switching off the engine...so when its hot. I check mine when regularly, sometimes its hot, sometimes cold, sometimes luke warm...whatever...my car never uses oil anyway so i always get the same reading. I dont think it makes a whole lot of difference, there may only be a millimeter difference on the dip stick between hot and cold, just so long as its registering well up on the dip stick who cares if its hot or cold.
mugenracer is offline   Reply With Quote
Old 03-15-2005, 02:06 PM   #17
v-attack
v-attack's Avatar
Location: First in Flight, Type Rs of East Coast, NC, FL
iTrader Rating: (1)
Default Re: Should you check the oil hot or cold? (baonest)
Even with mad v-attacks.......... Click the image to open in full size. Click the image to open in full size.
WTB: USDM Phoenix Yellow Type R front end body parts, WTB: B Series JDM ITR trans with LSD + 4.7 FD, WTB: B Series or K Series Type R Swapped Civic Hatch,
FS: Integra LS 5spd. Cluster, 2 LS Cylinder Heads and Intakes
v-attack is offline   Reply With Quote
accidentally, car, check, civic, cold, engine, honda, hot, hybrid, oil, overfilled, pilot, subaru, tsx, warm
