| Welcome to Honda-Tech! | ||
#1 |
I purchased a used 96 Civic Dx which has no power door lock from factory. The owner had a alarm w/ power door lock installed. My problem is the passenger side is stuck on the "lock" position. I tried forcing the unlock tab and opening the door at the same time but it just will not open?! I tried disconnecting the battery and I still can not open the door. I guess the power door lock actuators is dead?
#2 |
| Garage is empty, add now |
there is usually a lead or soft metal bracket that fastens the accuator rod to the factory lock rod, sometimes that peice gets jammed or slipps. take the door panel off and check it out. it will probably be a quick fix. goodluck with the lock
"the never ending project" [img]http://images.honda-tech.com/set1/smile/emhammer.gif[/img] [img]http://images.honda-tech.com/set1/smile/embeer.gif[/img] [url="http://www.staytunedaudio.com"]http://www.staytunedaudio.com[/url]/ |
#3 |
problem is I can not even open the door to remove the door panel
#4 |
2002 Honda Accord |
Can you unlock it with the key?
Like sunflower seeds? Want some GREAT seeds? Save 10% off your order by using coupon code jclanton at http://www.zotes.com! =W= |
#5 | |
#6 |
2002 Honda Accord |
Hmmm... Maybe you can remove the door handle/lock bezel (one screw) and/or the door handle cup and reach inside the door and manually move the lock rod?
Can you feel the door lock and unlock? You know, how they sortof click when you operate it by hand? What happens when you try to unlock the door via remote? Can you hear the actuator moving? If so, it may not be the lock that's giving you problems... It may be that the latch itself is frozen... Dunno what to do if that's the case.. :shrugs:
#7 | |
#8 |
my door got stuck like that (open though) and just wriggling the bar for the lock reset it... so Im guessing what was said above, taking that lock peice off the door and wiggling that bar all ways until it is loose should work... you will have more mobility and the ability to disconnect it to move as needed as well... (disconnect from plastic lock unlock switch) though I dont know how to do that in that position.
Current project '99 Civic Si (aka "The Maintenance Money Pit") '00 Civic EX coupe (stolen and stripped... First car I ever bought and liked) '96 Ford f-150 (sold) '92? Buick Skylark (sold) Honda-Tech is the l33t shiznipples!!! Rock On! LOL Atari was allot more complex than a honda ecu....ask any tuner.. - tempsohc |
#9 |
2002 Honda Accord |
Updates?
#10 |
lol ... can't open it up cause it's stuck closed
![]() Sorry, no ideas ... just thought that was funny
Love is beautiful. |
#11 | |
Old Fart
94
You get what you pay for. Nothing is impossible, the impossible takes longer and costs more money. |
| Tags |
| 94, 96, accord, car, del, door, frozen, handle, honda, latch, lock, odyssey, open, position, skylark, sol, stuck |
