Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 01-21-2002, 08:39 PM   #1
B18C-EJ1
Guest
Posts: n/a
Default Oversized pistons, what in MM does .xx mean??
I'm trying to get the exact size of my pistons.
So what is each one in mm?
10 over?
20 over?
25 over?
You get the idea. Is there a formula I could use?
Thanks
Old 01-21-2002, 08:51 PM   #2
earl
earl's Avatar
Send a message via AIM to earl
Default Re: Oversized pistons, what in MM does .xx mean?? (B18C-EJ1)
1 mm = .03939 inches
10 over = .010 inches larger
81 mm x .03939 = 3.19059 diameter in inches
earl is offline   Reply With Quote
Old 01-21-2002, 09:15 PM   #3
vhd
vhd's Avatar
you can also use this formula to change mm to inches or vice versa
X (mm) divided by 25.4 = X (in inches).....i.e. 81.5mm divided by 25.4 = 3.209"
or
X (inches) times 25.4 = X (in mm).......i.e. 3.209" times 25.4 = 81.5mm
vhd is offline   Reply With Quote
Old 01-21-2002, 09:45 PM   #4
B18C-EJ1
Guest
Posts: n/a
Default Re: Oversized pistons, what in MM does .xx mean?? (vhd)
So, If I used 25 over pistons, they are 81.64mm?
Is that right?
81mm = 3.189
25over = 3.214
3.214= 81.64mm
I'm rounding to .xx digits.
Old 01-21-2002, 10:00 PM   #5
sgT
sgT's Avatar
Send a message via ICQ to sgT Send a message via AIM to sgT
Most people that refer to 25 over mean .25mm overbore.
Stephen Sakai
1997 Integra R
http://www.sgt-racing.com
sgT is offline   Reply With Quote
Old 01-21-2002, 11:44 PM   #6
B18C-EJ1
Guest
Posts: n/a
Default Re: Oversized pistons, what in MM does .xx mean?? (sgT)
So that would make it 81.25mm?
Old 01-22-2002, 09:17 PM   #7
vhd
vhd's Avatar
you had it right, your bore would be 3.214" or 81.63mm with the .025"/.635mm over
Old 01-22-2002, 09:48 PM   #8
earl
earl's Avatar
Simply stated, .5 mm overbore equals .020 inches overbore
20, 25, 3189, b18c, cp, honda, inches, mean, mm, overbore, oversize, oversized, piston, pistons, ti
