| Welcome to Honda-Tech! | ||
#1 |
This is for everyone, I made this torque spec thread since I and many others here always ask about torque specs. Plus I myself, find myself looking trough all my Haynes and Chilton books for torque specs while I know I can make a list like this one to make it easier. I hope this can be some help and it can be made a sticky on these boards.
These torque specs are straight from the Chilton and Haynes manuals. I might also add some ARP torque specs as well. I still need to add more as you can see Ive been a little busy so as soon as I can I will add more. I would also be cool if others can add to it as well. ALL TOQUE SPECS ARE IN FT-LB. A/T Tranny Drain plug......................... 29 M/T Tranny Drain and fill plug..............30-40 Wheel Lug Nuts....................................80 Fuel Filter Banjo Bolt............................................16 Service Bolt.........................................9 Clamp Bolt...........................................9 Valve cover Bolts...................................7 Spark Plugs..........................................13 Cam Gear Bolt.......................................27 Cam cover crown nuts.............................7 Crank(vibration) damper bolt...................119 Cylinder Head Studs....................1st step..22...2nd..49 Flywheel Bolts M/T................................76 Drive Plate bolts for A/T........................54 Header Bolts to Cylinder Head................22 Header to downpipe bolts.......................33 Intake Manifold Bolts..............................16 Oil Pan bolts...........................................9 Oil pick up tube bolts..............................17 Oil Pump to engine block bolts/nuts...........9 Oil Pump Screen bolts..............................8 Oil pump cover Screws.............................5 Oil filter Housing Bolts..............................9 Rocker arm shaft pedestal bolts................16 Rocker arm shaft end caps bolts................9 Timing belt adjstment bolt.........................31 Rod Bolts............................................. ....23 Main Bearings cap bolts Separate caps and bridge..........................48 One piece cap assembly............................33 Water pump pulley bolts.............................9 Thersmostat housing bolts..........................9 Water pump attaching bolts.........................9 Fuel injection service bolts 88-90................................................ ......9 91up.............................................. ..........11 Throttle Body nuts.....................................16 Fuel Rail nut..............................................9 Manual Transmission Countershaft locknuts................................65 End cover bolts.........................................9 Selector arm holder bolts...........................9 Tranny case to Flywhee housing..................20 Tranny to engine bolts 4 speed............................................. ........33 5 speed............................................. ........50 Clutch pressure plate bolts...........................19 Release fork bolts........................................22 Driveaxle/hub nuts.......................................134 Brake hose to caliper banjo bolts (front/Rear)...25 Master Cylinder Mounting nuts.......................11 Brake Booster mounting nuts.........................9 Modified by SOHCEK-Turbo at 2:37 AM 10/21/2006 |
#2 |
Nice
#3 |
| Garage is empty, add now |
excellent job. prime sticky material.
#4 | |
#5 |
#6 |
teh best rite up evar
http://www.halffastmotorsports.com |
#7 |
I did something like this a while back for B series motors.
Just a little FYI 1 FT/LB equals 12 IN/LB, so if you want to use a beam type wrench which are almost all IN/LBS take your FT/LBS and multiply by twelve to get IN/LBS. This is good to know because for any bolt requiring 20 ft/lbs or below, you should convert to in/lb because it's a little more accurate. Also when tightening bolts that you absolutely, positively do not want to break such as cam cap bolts whether its for B or D series, you should use a beam type torque wrench with IN/LBS and NOT a clicker type torque wrench which are usually FT/LBS. |
#8 | |
#9 | |
Here is my thread, which I did a little different: B SERIES COMMON TQ SPECS |
#10 | |
#11 |
up
#12 |
Nice thanks for the info! I will need it soon
#13 | |
just what i was looking for!
_______________________ 91 DX w/sohc zc VOUCHES: J98CX,Blackstar,spatula,Robster Craw,darksoul, CRX Toad,gotboostedvr6,keithv |
#14 |
bump this
http://www.honda-tech.com/zero...age=1 EF security thread http://images.honda-tech.com/set1/smile/emthup.gif |
#15 |
EagleTrucking.Co I need Class A Teams to Run 48 states (53ft reefer) or Run the LA and Long Beach Ports with a TWIC CARD $25.65 each container |
#16 |
Moderator
We all love you long time.
Hondworks Need a write up on how to fix your CRX cracked climate control, PM me 1990-1993 Accords parting out 1991 CRX HF parting out PM me for any parts EG Sedan Tail Lights $60 shipped |
#17 |
nice post
#18 |
where is the pressure plate tq specs?
#19 |
needed this thanks
EJ8 B20VTEC XBOX Live: JDM SPUD215 http://www.facebook.com/profile.php?id=1471830060 |
#20 |
So..the headstud specs...u do it in any order? Any specific sequence or simply 1 full torque down at 22 lbs, then another run at 49?
R.I.P. KILLS My dead C-SS will tear up your Type-R/Healthcare Member #Alpha
#21 |
very nice post! thx
EFSS #182 http://images.honda-tech.com/set1/smile/emsmile.gif Rust sucks! http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif http://www.flickr.com/photos/d0mm3y Nikon D40 user http://images.honda-tech.com/set1/smile/emsmile.gif |
#22 |
Where are the ARP head studs spec? I see the 22, 49 in two steps. Is this for ARP or Stock?
Thanks. |
#23 |
Anyone know? One sticky from http://www.d-series.org/forums....html says the following Cylinder Head Bolts for D16Y8 step 1(bolts 1-10)....15ft lbs step 2(bolts 1-10)....36ft lbs step 3(bolts 1-10)....49ft lbs step 4(bolts 1 & 2)....49ft lbs Cylinder Heads...All D ARP Studs Step 1......15ft lbs Step 2......30ft lbs Step 3......62ft lbs |
#24 |
Wow guys ty so much for the info. I'm going to blot my tranny up tonight now that i have the right TQ for the flywheel bolts and PP, Thanks a bunch>Kov
#25 |
you rock. thanks so much for all this usefull info. i wish everything were this easy
There's only 3 types of people in the world, those who can count, and those who cant. http://honda-tech.com/showthread.php?t=2574429 my build thread |
| Tags |
| 1990, 2006, 91, bolt, bolts, brake, civic, crx, head, honda, settings, si, spec, specifications, specs, torque |
