im a retard, ran car without oil, what now?
Old 02-22-2005, 12:14 AM
vdub08's Avatar
Default im a retard, ran car without oil, what now?
dude, i did a routine oil change to my car and i think one of my lines broke and killed the oil supply. after driving it for a day, i come home and smell hella smoke comign from the engine. i go to take a look, and i see my axles alternator and a buncha other parts drenched in oil. and i take out the dip stick and its bone dry
what am i supposed to do now?
Old 02-22-2005, 12:45 AM
h22John's Avatar
Default Re: im a retard, ran car without oil, what now? (tofu9000)
figure out why for sure. Sounds like a bad oil filter seal or a punctured oil filter.
Old 02-22-2005, 01:10 AM
DC 2's Avatar
Default Re: im a retard, ran car without oil, what now? (h22John)
add oil and pray that bastard didnt seize up.
Might as well change the filter again, or use brake cleaner...
clean everything off and find out where the oil is coming from once youve filled it back up.
Old 02-22-2005, 01:13 AM
RangerDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22John &raquo;</TD></TR><TR><TD CLASS="quote">figure out why for sure. Sounds like a bad oil filter seal or a punctured oil filter.</TD></TR></TABLE>
Hey John.
If you still have the old filter check to see if it still has a gasket on it. If it doesnt then you just doubled up on gaskets and the oil just leaked out.
Id probably fill it back up with oil crank it a couple times (make sure you disable the car from firing) then drain the oil (not required but why not) drain the oil then refill it and run a comp check. If it was still running ok before you shut it off more than likely the damage is minimal.
Oh yeah and change the filter.
Old 02-22-2005, 01:37 AM
Imadisgrace's Avatar
Default Re: im a retard, ran car without oil, what now? (RangerDan)
Was your oil light on? if it was and you kept driving then I would be worried. What they said earlier about the oil filter gasket sounds to be the most logical problem. You should always check that the old filter gasket has been removed when you remove the oil filter. Also if the drain plug washer/gasket isn't in good shape it will cause leaks. What I would do in this situation would be: Fill the engine up to the proper level with oil, start the engine and check for leaks, do what you have to do to stop the leak. If your oil warning light is operational and never came on while you were driving then don't worry about if you damaged anything, fix the leak and be happy you diddn't catch your car on fire. Next time you change your oil start the car and CHECK FOR LEAKS!!!!!!!!!!!!!!!!!!!!!!! peace~
Old 02-22-2005, 01:45 AM
RangerDan's Avatar
Default Re: im a retard, ran car without oil, what now? (SloDelSol)
See I was thinking if he did even the slightest damage to fill drain and refill to get out any particles that might not have drained into the filter.
Old 02-22-2005, 03:22 PM
vdub08's Avatar
alright ima try to do that tommorrow, cuz i got my wizdom teeth taken out today and im a little drugged up
so what ima try to do tommorrow is,
check the oil filter gasket.
if all good, fill it up with oil then check for leaks?
is there any other possibilities of the cause of this problem?
and i did not check to see if the oil light was on
Old 02-22-2005, 03:32 PM
Combustion Contraption's Avatar
dun dun dun
another one bites the dust
Old 02-22-2005, 03:45 PM
RangerDan's Avatar
Default Re: (tofu9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">alright ima try to do that tommorrow, cuz i got my wizdom teeth taken out today and im a little drugged up
and i did not check to see if the oil light was on</TD></TR></TABLE>
Yeah there could be other problems but concentrate on the high percentage/cheapest fix first.
So do you look like a chipmunk now?
Old 02-22-2005, 03:53 PM
h22John's Avatar
Default Re: (RangerDan)
hah, thanks Dan, i'm bad at detail. Yeah like he said oil filter first because if it sprayed everywhere it prob had some pressure behind it and that isnt from the drain plug, but check that too. I had an oil filter gasket leak on me at work once. it got pinched somehow and when I started the car after about 5 seconds I had spray EVERYWHERE. Luckily it was my uncles car and I didnt get in trouble lol.
Old 02-22-2005, 04:10 PM
RangerDan's Avatar
Default Re: (h22John)
We were changin the oil in the cars before heading down to race In Washington last year and John changed my oil...anyways the seal got messed up and upon start up every drop of oil was on the floor in what seemed seconds lol....what a freakin mess.
Old 02-22-2005, 04:16 PM
delslo93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan &raquo;</TD></TR><TR><TD CLASS="quote">
If you still have the old filter check to see if it still has a gasket on it. If it doesnt then you just doubled up on gaskets and the oil just leaked out.</TD></TR></TABLE>
Exactly this same thing happened to me once and all my oil ran out. Luckily i didnt drive on my motor like this. Hopefully everything is alright internally.
Old 02-22-2005, 04:18 PM
adictionbass's Avatar
Default Re: im a retard, ran car without oil, what now? (delslo93)
pull the drain bolt and see if there is any oil actually still in the motor.
Old 02-22-2005, 05:09 PM
wannarunthateg's Avatar
that sounds like a double gasket too me.check the old filter. make sure the drain plug is tight.and hope it didnt seize up.
Old 02-22-2005, 05:25 PM
93egSIboi's Avatar
Default Re: im a retard, ran car without oil, what now? (DC 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC 2 &raquo;</TD></TR><TR><TD CLASS="quote">add oil and pray that bastard didnt seize up.
if it did seize up, what exactly was the damage done due to this? is the engine salvageable or fixable or would you be better off buying a new motor?
Old 02-22-2005, 07:29 PM
vdub08's Avatar
Default Re: im a retard, ran car without oil, what now? (93egSIboi)
it shouldnt be that bad, it looked alright to me and i only drove it probably a total of 45 mins after
So do you look like a chipmunk now? </TD></TR></TABLE>
alright thanks, im pretty sure its a double gasket cuz i checked the onld filter and its missing the gasket.
and the doctor used nitrous on menso no to the novacaine. i look normal
Old 02-22-2005, 08:40 PM
95sihb's Avatar
if it's not the double gausket, then it's most likely your oil filter. If you happend to use one of those "old school " oil filter wrench to tighten your filter ,you most likely pinched a small hole or traked the filter. I did the samething when i changed my oil, but for some reason I felt the wrench move a little more , when i turned on the car oil sprayed everywhere. the hole was so small too( actual size ---&gt; "~" )
Old 02-22-2005, 09:10 PM
JDM_Armenian's Avatar
Default Re: im a retard, ran car without oil, what now? (95sihb)
replace motor heh.
nub.96ek's Avatar
See if it will run w/o gas too...
You most likely double-gasketed your filter.
Old 02-22-2005, 09:57 PM
Bond's Avatar
Default Re: im a retard, ran car without oil, what now? (nub.96ek)
Not to hijack the thread but I am new to the import motors and was wondering do civics come standerd with D series in north america or can you get a B series in a civic. A lot of you guy's have B series engines and was wondering if that is aftermarket. Here in Canada I have never seen a civic come with a B series. Also is B series engines made in north america or are the from Japan? I know I am a newbie. Please help
Old 02-22-2005, 10:09 PM
SIcivicHATCH's Avatar
find out why there is oil over everything. Happened to me already oil pressure gauge solenoid busted out and oil went everywhere. Clean up the oil put new oil in and run the car. If it knocks its killed.
Old 02-22-2005, 10:11 PM
Global Moderator
Jimmy's Avatar
Goodluck man
Old 02-22-2005, 11:02 PM
poison's Avatar
The oil seal on the oil filter probably fell off w/o you realizing it. Check that area.. shouldn't be a big problem as long as you didn't drive it for a while.
Old 02-23-2005, 08:29 AM
[thread jack] Brandon, where the hell you been??! [/thread jack]
Old 02-23-2005, 10:30 AM
vdub08's Avatar
yea guys i got it it was the double filter and i did use an old school wrench too so it coulda been both those problems.
ima put the next one on by hand cuz im just buff like that
and new motor, maybe if i have to, i'll do another d though cuz i dont wanna open up my hood and see something different....ahhaha
Quick Reply: im a retard, ran car without oil, what now?
