solving the rear bumper drag problem
Old 02-08-2005, 09:41 AM
PbFoot's Avatar
Default solving the rear bumper drag problem
A lot of people are cutting holes in their rear bumper to "diffuse" the high pressure and drag. A far better solution is to weld a sheet metal piece to the bottom of the car (at the back of the rear footwell). Then rivit it to the bottom of the rear bumper cap. Cut out the area for the rear suspension and tires.
I would also weld in some braces to hold it up off the ground. If done correctly this setup will produce some serious downforce at the rear. Ideally the sheetmetal will angle up at about 7 degrees to the rear bumper.
I did a setup like this a while ago. It only cost about $40, and 4 hours. Saved over 3 tenths in the 1/4.
Later,
PbFOOT
Old 02-08-2005, 10:21 AM
DSRxCandyh2bEG's Avatar
Default Re: solving the rear bumper drag problem (PbFoot)
Cant really do that on a street car thats driven everyday... seen that on a few drag cars. good idea though.
Old 02-08-2005, 10:37 AM
DEVIOUS_EG*'s Avatar
great idea, can you post some pic's..
Old 02-08-2005, 10:46 AM
tnsxsear1's Avatar
Default Re: solving the rear bumper drag problem (DEVIOUS_EG*)
pics, good thing I saw this, I was about to cut some holes in my rear bumper.
Old 02-08-2005, 10:51 AM
poorguy's Avatar
Default Re: solving the rear bumper drag problem (tnsxsear1)
wtf, are you guys stuck in the 90's? this isn't a great idea, everyone's been doing this for years.
Old 02-08-2005, 11:25 AM
Karterguy13's Avatar
Default Re: solving the rear bumper drag problem (poorguy)
If everyone has been doing it for years(since the 90's) why isn't it a good idea?
Old 02-08-2005, 11:32 AM
SuperTeg95's Avatar
Default Re: solving the rear bumper drag problem (Karterguy13)
Isn't this bad if your going over like 125mph on the interstate(racing). Might cause the rear to get loose/light. Drag car good, street car not so good.
Old 02-08-2005, 01:14 PM
StunnaBen's Avatar
Default Re: solving the rear bumper drag problem (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't this bad if your going over like 125mph on the interstate(racing). Might cause the rear to get loose/light. Drag car good, street car not so good.</TD></TR></TABLE>
correct.
Old 02-08-2005, 01:42 PM
poorguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">If everyone has been doing it for years(since the 90's) why isn't it a good idea?</TD></TR></TABLE>
i meant it's not a new idea.
Old 02-08-2005, 02:09 PM
99blackcivicSi's Avatar
uhmmmmmmm
92-95 Civic Vx
nuff said
Old 02-08-2005, 02:22 PM
FormulaGSR's Avatar
Default Re: solving the rear bumper drag problem (99blackcivicSi)
where is that this thread is useless without pics thing.
dont understand why this would be bad on the street. why would the *** get light.
Old 02-08-2005, 04:19 PM
Engineer Guru's Avatar
Default Re: solving the rear bumper drag problem (FormulaGSR)
The angle of the underbody tray can be changed to set up the amount of downforce.
Look into any cacecar aero book. It will tell you what to do. The F1 guys started this back in the '60s.
Old 02-08-2005, 04:26 PM
redboost10's Avatar
Default Re: solving the rear bumper drag problem (Engineer Guru)
does anyone have any pics of this sheet metal mounted? preferably on an ek? thanks guys
Old 02-08-2005, 06:08 PM
HR-1320's Avatar
Default Re: solving the rear bumper drag problem (tgh99si)
Theres really not that many cars done correctly. A couple of pro fwd cars have it done nice like Levon eisles , Lisa Kubo , Team GM , Shaun Carlson and so on. I'm not even sure that those are correct for down force . but they look real nice as far as smooth air flow. Hotrod cars that have been half backed have just a flat piece from the b post back, but they don't appear to have any angle to them.
As far as that guy who picked up three tenths , hes full of ****. I haven't seen a fwd car going fast enough to benefit from that type of areodynamics be consistant enough to make a statement like that. A fwd car with that kind of power can fluctuate a hell of alot more than 3 tenths every run. Even team gm or bothwell wouldn't make statement like that.
Old 02-08-2005, 06:29 PM
Quik Chris's Avatar
Default Re: solving the rear bumper drag problem (2.0Coupe)
Great idea. You dont' really know what angle to place it at, because if its pushing down on the back, the front will come up, and vice versa. Rememer that if you create lift on one aspect, it also creates drag as a biproduct. I think if you're going to do this, do it to the front here, as seen on this skyline, taken from autospeed.com
...But it's underneath the car where the real action is. At the front is an undertray that extends the full width of the car prior to the wheels, then back under the engine. This smoothing of the airflow helps the front spoiler/splitter work, in addition to making the airflow passing under the rear undertray less turbulent. What rear undertray? you ask.
A full rear diffuser is fitted. This comprises a flat panel that is angled upwards towards the rear of the car. It is sub-divided into three areas of flow, with one path partially blocked by the protruding muffler and tailpipes. The idea of a rear diffuser is to accelerate the air around the throat - the part of the device that has the initial change from being flat to being tilted upwards. This higher speed flow creates a low pressure, pulling the car downwards.
Old 02-08-2005, 06:30 PM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PbFoot &raquo;</TD></TR><TR><TD CLASS="quote">It only cost about $40, and 4 hours.</TD></TR></TABLE>
drill bit $3.50 time ,5min.
You have a good idea,but my car is a beater,so looks mean nothing to me.
Old 02-08-2005, 07:19 PM
tony1's Avatar
Default Re: solving the rear bumper drag problem (91' LS-VTEC)
Here's some more pics... http://www.cardomain.com/membe...04189
Old 02-08-2005, 07:26 PM
JL
JL's Avatar
Default Re: solving the rear bumper drag problem (tony1)
wow.. that celica!
Old 02-08-2005, 08:15 PM
i HAS questions ?
.dave's Avatar
Default Re: solving the rear bumper drag problem (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">wow.. that celica! </TD></TR></TABLE>
Showcars...
Old 02-08-2005, 11:39 PM
Quik Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
I did see the post about the mold being made for the defuser on the Celica (https://honda-tech.com/zerothread?id=769081), though, I was somewhat supprised there are no fences (vertical stabilizers) running the length of the diffuser-- it seems as if the air pressure wouldn't be high enough as it is now for it to be as effective as it could be, but I know that Dejan is a pretty smart guy when it comes to aerodynamics.
Old 02-09-2005, 05:23 AM
tony1's Avatar
Default Re: solving the rear bumper drag problem (Quik Chris)
There needs to be vertical straights in it, but we haven't done it yet. We've been to busy getting the car ready for the track. Good eye! One a good note, in testing yesterday it went a 1.34 60' right out of the box, first pass! Things are looking good so far.
Old 02-09-2005, 06:10 AM
Turbocivic94's Avatar
That's nice tony
what did it run in 1/4
92-95 vx comes with that plastic on underneath
Old 02-09-2005, 06:31 AM
tony1's Avatar
Default Re: solving the rear bumper drag problem (Turbocivic94)
9.1 @ 118, 17psi and through 3 gears and coasting. The car is a 5 speed.
Old 02-09-2005, 06:42 AM
X-Mazda 3 Racer's Avatar
That thing is running Tony???? Yeeeeehhhaaawww! Let that mother rip.
Side note Tony, I have a price for your stuff. Hit me up on IM
Old 02-09-2005, 06:46 AM
tony1's Avatar
Default Re: solving the rear bumper drag problem (GoldenEagleMfg.com)
Yup, time to find the rest of the bugs! lol
I'm off to work, i'll call you today...
Quick Reply: solving the rear bumper drag problem
