Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 02-05-2005, 05:13 PM   #1
EKB18BPR3
EKB18BPR3's Avatar
Default 94 Ford Explorer Stereo wiring diagram please
i have a pioneer i wanna install into my 94 ford explorer but im having trouble with it. searched google, yahoo...all gave me no info (i swear!). if anyone here KNOWS the color for each speaker or know where I can definitely find the answers, please let me know. NONE of the 8 speaker wires match in colors (ie: white and white/black, grey and grey/black). i bought a harness from BestBuy AND Walmart and for some reason they dont work. so I have to cut the harness from the truck off and splice them. please dont post if ur gonna start a Chevy VS Ford thread. and like always, thanx for ur answers!
98 hatch, 99-00 conversion, Si interior/gauge cluster, 15 inch Motegi, B18B1, p&p head, GSR tranny, Skunk2 Pro IM, hondata IM gasket, GE block guard, PR3 Pistons, Eagle rods, race ACL bearings, prelude injectors, 255 Walboro fuel pump, fidanza 7.5 flywheel, test pipe, OEM everything else.
EKB18BPR3 is offline   Reply With Quote
Old 02-05-2005, 05:16 PM   #2
chris_c
chris_c's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (98B00STED)
before you go cutting, i bought a harness kit from circuit city and it works perfect. 1991 ford explorer here.
check explorerforum.com too
http://images.honda-tech.com/set1/smile/emwink.gif
YJ-7: wrangler frame and tub, cj-7 front clip, scout II dana 44's, 350hp 327ci corvette engine, no tranny, no t-case...
chris_c is offline   Reply With Quote
Old 02-05-2005, 05:20 PM   #3
EKB18BPR3
EKB18BPR3's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (chris c)
both the walmart and bestbuy harness came with two ALMOST identical harness, one for the power and stuff and one for the speaker wires. the one for speaker wires dont fit the OEM ford explorer harness because the OEM one is square-ish shape and the walmart/bestbuy harness is long rectangle shape. do u remember what ur circuit city harness looked like?
Old 02-05-2005, 05:24 PM   #4
chris_c
chris_c's Avatar
man, it was two years ago. if i can find the stupid things to pull the deck out i'll take a picture for you tomorrow.
Old 02-05-2005, 05:25 PM   #5
TurboBumblBee
i worked in the install shop at a circuit city for almost 2 years and i know that early 90 fords are tricky when it comes to getting the right harness.. if i were you i would just drive up there, shop the install guy what plugs u have behind the radio and have him get you the right harness.. alot of older fords needed a converter harness that was a little more expensive then the standard harness that is needed with other fords. i do not remember the model numbers but i believe the amplifer harness was about 40 bux.. hope that helps..
but remember, dont go cutting wires cause that will only make your job tougher to install it and later on if you ever sell the car and want to put the factory radio back in
TurboBumblBee is offline   Reply With Quote
Old 02-05-2005, 05:28 PM   #6
EKB18BPR3
EKB18BPR3's Avatar
thanx chris and turbobumblebee....i may just give up the idea and put the old one back on...i just had a pioneer laying around that i took off my civic when i gutted it out. anyways thanx again to both of u
Old 02-05-2005, 05:31 PM   #7
SirRevvs
SirRevvs's Avatar
You should be able to find a Ford wiring harness anywhere (Wal-Mart for example) and I'm not totally sure if the 94 is factory amplified so try popping the speakers with a 9 volt battery before you wire everything up. If they don't pop you need a amplifier bypass harness and the amp is in the pass side rear plastic panel.
Cen-Tex JDM
SirRevvs is offline   Reply With Quote
Old 02-05-2005, 05:36 PM   #8
chris_c
chris_c's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (SirRevvs)
i have a jbl system [originally from ford] with the amps and subs and i am using a regular harness and running the alpine door speakers off the stock amp and my jl audio 10 off the original subs amp. idk, it's been working fine for me for 2 years.
Old 02-05-2005, 05:38 PM   #9
jdmotorsports
jdmotorsports's Avatar
Send a message via AIM to jdmotorsports
if the speaker plug is grey and square its the amplified system. you have to get the right piece then pull the rear quarter trim off and bypass the amp back there.
you can use the metra 70-5511 and use the factory amp.
heres the pic
David
XBL:david0415
jdmotorsports is offline   Reply With Quote
Old 02-05-2005, 05:44 PM   #10
88DXCRX
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Send a message via AIM to 88DXCRX
http://www.installdr.com
that site might have the info you need..
living that automotive dream
88DXCRX is offline   Reply With Quote
Old 02-05-2005, 05:46 PM   #11
Audio28
Audio28's Avatar
Default Re: 94 Ford Explorer Stereo wiring diagram please (88DXCRX)
12volt.com
Audio28 is offline   Reply With Quote
1991, 94, amp, amplifyer, bypass, code, color, diagram, dont, explorer, ford, jbl, oem, speaker, wiring, work
