| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
Hey guys,
my car had been in storage for the past month or so and I just brought it back out this weekend. My car had been tuned to run on 94 octane gas. When I first brought it out, the car seemed a lot slower than before. Could it be because of the old gas in the car? I am currently running hondata, adjustable fuel pressure regulator...could anything have gone wrong with them during my storage? another question is whether different temperatures would cause changes to a car's air fuel ratio? for example, if the air is colder outside, there would be more oxygen in your combustion chamber and therefore require more fuel to combust. If you keep the same amount of fuel, then the car would run lean. Is there anything wrong with my reasoning? TIA
"It's not how hard you push along the way; it's having something in you to finish." -Michael Jordan Jun III Cams / Valve Springs / Retainers / Spoon Cam Gears CTR Pistons Jun Header / Renault Cat / T1R B-Pipe / Spoon N1 Exhaust AJR Ported TB / Comptech Icebox / K&N Air filter Hondata S100 T1R Lightweight Battery Fidanza Flywheel / Exedy Clutch / Endless Na-M Break Pads / SS Brake-lines 15" Racing Hart CP-035 / Falken Azenis / Buddy Club Racing Spec Dampers |
#2 |
Yes gas does start to lose it's octane rating after about 2 weeks. When storing a car it's a good idea to go to any auto store and purchace a bottle of Sta-bil. It is a fuel stabilizer and will help keep the gas "fresh" for I believe the bottle says 12 months
http://www.defcon-racing.com 1999 K24/K20A DC2 roadrace car......driver/owner 2000 Honda Civic Hatch roadrace car.....co-driver |
#3 |
go with the sta-bil as suggested.
92 Civic Si '00 FBP ITR #1526 rockin' the JDM front-end. sold |
#4 | |
R Less http://images.honda-tech.com/set1/smile/emsad.gif |
#5 |
LOL
Opie, sits back and waits for formula
#6 |
No way its 2 weeks, i would say more like 2 months.
#7 |
Gasoline life varies on where it's stored, how much is stored, and weather conditions...Gasoline can last around 3-6 months..depending on those variables...so if you plan to store you car, just run your car down to a 1/4 tank...do a double dose of STABIL Fuel Stablizer and you won't have to worry about stale or gummy gas...
double dose will allow the gas to stay fresh for 2 years.. Since you car seems sluggish, just go fill it up and run it down to 1/2 tank and refill it again...it should dillute the old gas...hope that helps...
95' MILANO RED GSR - R.I.P. 4-29-04 01' NIGHTHAWK BLACK PEARL ITR 01' KAISER SILVER METALLIC K20A2 POWERED ITR.... MY KAAA [url="http://www.honda-tech.com/garage?cmd=viewcar&id=2276"]http://www.honda-tech.com/gara...=2276[/url] |
#8 | |
Well the formula is X molecules and Z temperature...LOL J/K I've heard that it starts to loose it's rating after 2 weeks, guess I was wrong LOL
#9 |
thx for the reply guys
is there anyone who could answer the second part of my question?
#10 |
...octane is lost when light hits it for a large amount of time.
you will loose more octane storing your gas in a container than while in your gas tank. as far as air fuel ratio goes...colder fuel = denser fuel so yes, you will run a tad more richer when colder, but colder fuel with colder air will almost equate out to equal the same air fuel ratio. stock computers have this compesation mapped out into its computer, so you should have around the same air fuel regardless of temp. maybe a difference of 0.1 or 0.2 air fuel when its colder outside or you have colder fuel.
-barry |
#11 | |
#12 | ||
Charles' Law: V/T = k .. so absolute temperature decrease means volume decreases (proportionally) The difference between a hot (30 C) day and a cold (0 C) day is a 10% reduction in volume for the air, the density is higher by about 10% too. The gas will contract a LOT less than that (when's the last time you saw a 5 gallon container of gas shrink to 4.5 gallons in the winter? Me neither, but I've seen it happen to empty containers.
Chris Fries - #117 H1 Prelude - now with more VTEC (Thanks [url="http://kingmotorsports.com"]King![/url]) 2007 and 2008 Midwest Honda Challenge H1 Champion Go to Estrada Customs in Libertyville, IL! Great place for any body work! |
#13 |
Wow, a lot of ppl w/ a lot of damn OPINIONS and a ton of misinformation.
#14 | |
#15 | |
#16 |
If you're worried about octane, you can toss a gallon or two of Toluene/Xylene in your gas tank (about 118 octane) from a paint store. You can find it for $5-$6 a gallon if you look.
That is, if you're too impatient to burn off your current tank ![]() http://www.honda-tech.com/zerothread?id=1032265 -Chris
| Tags |
| bil, decrease, fuel, gal, gas, it, loose, lose, losing, octane, sta, stabil, storage, time, winter |
