SSR WHEEL PIC THREAD
#7856
Lip/wheel fitment question....
I have a pair of SSR MK3 that are 4x100 and some guy has some MK3 lips that are 1" bigger than my current lips and will make my wheels 7.5 but they're are off a 114.3 wheel. Do you think I will be able to use them?? Match etc.,? Not the whole barrels, just the lips.
Thank you!...yeah you. Thanks.
#7858
Re: SSR WHEEL PIC THREAD
Sweet. Yeah I'm trying to get the other barrels. I got my 15x7.5 4x100 SSR Reverse Mesh today. It wasn't MK3's, I didn't want to jinx myself, haha. I"m super stoked!
#7859
The centers are sandwiched between the lip and barrel on MK3's and the like, so they'd need to be cut apart to swap anyway.
Also, 15" Formula Mesh can be different face sizes to other 15" Formula Mesh, i assume same goes for Reverse/Full Reverse too. Very inconsistent face sizes.
#7862
Ok, but these are MK3's they are talking about. I have seen many a set split.
edit: on the MKI's...are you sure they were welded? Could you see the bead or were they just "really stuck"? I have taken apart a ton of wheels and I think SSR's are the biggest pain. They are usually stuck with old JDM crust, heh. I have a padded steel beam and a 5 pound hammer that I have to smash to get the faces off the really crusty wheels.
#7863
#7868
For the record...I never had MK3's. I actually had SSR REverse Meshies(cool story bro). Anyhow they're 15x7.5 +20's. I did a test fit on my car and they stick out about 1/2 past the fenders, and that's without my car lowered, no camber, etc. I think once I get my car lowered, different tires, and some camber/toe,pump the ol' fenders I should be good to go. I'm not hellaflush, but I'm not hellatrack either, I think I want to be somewhere in the middle lol. I'll post some pics when I get my fitment figured out. Form/function.
#7869
My Mk1's are 100% Welded and the bolts just sandwich the centre layers all together. Such a weird design but obviously stronger and you don't get any leaks!
#7871
Originally Posted by Captain Key!s
Yeah, all "3 piece" SSR's are welded barrels with a detachable face...pretty much a modular wheel. I wonder if the old MKI's ae welded or all generations are...
#7872
#7874
Recent additions. Thanks Fitting for the collection. Not sure those areo covers look good on my car. Also got a so cal barnyard find on super fins. They were so dirty I almost didn't get them. Took like a bottle of cleaner. Did a quick hand polish and starting to look better. spare Rings were extra dirty. Guessing at least 10 years of dust on them.
#7875
Nothing that exciting but while my Integra is out getting the body/chassis work done I decided to pull in my GF's EF project and install the modified 4x114.3 suspension. Finally the MK1's could go on and check for fitment issues. I'm happy I did as they needed a spacer to clear the ITR caliper. I had some spare 8mm spacers and they did the trick for the front. I'll see if I can get away with less but here are the pics.
Please keep in mind the wheels are as unfinished as the car . . . and NO, the headlights are NOT staying.
This is with the 8mm spacer installed so if I can't get away with less she's going to have to run some decent negative camber.
