JDM Climate Control Sensors location and air mix motor question
Hi, I would like to know if someone have a draw or pictures of where the different sensors are located on a 4th Gen JDM Prelude.
Also, is it hard to install the Air mix motor ? I was thinking of install it like it should be on JDM cars (I know I would have to enter a hot temp to get cold air).
Will it work fine inverted ? So air mix motor install will be easier.
Thanks
Thanks
Re: JDM Climate Control Sensors location and air mix motor question (Siegfried)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siegfried »</TD></TR><TR><TD CLASS="quote">No one with JDM climate control on 4th gen ?</TD></TR></TABLE>
Ive got a 1992 SiVTEC 4g with the digi AC.
I dont understand why the mix motor would work opposite way round (when its from a JDM car, isn't it??) but if you do install it so its backwardss then you'll have rendered the 'AUTO' function useless as when it detects its too hot it'll turn the heat UP! and vise-versa.
is the air mix motor JDM?
Re: JDM Climate Control Sensors location and air mix motor question (forgotmypassword!(OTT))
Yep I bought a digital climate control and receive every parts needed for the swap but before I install it I wanted to know if I can install the air mix motor the way it should be on JDM cars.
I don' t know how the climate control work, I ask this in case I'm not able to do the mod done on jrcormier.com; so I' ll install it on like on JDM cars.
All I want to know is if there is a manual setting where I'll choose my temp, then I'll set a hot temp and I'll get cold air as the motor will be inverted.
yes there is manual setting also but I still dont understand why it will be the opposite way around, if you have the full JDM assewmbly, air mix motor, controller etc Then why would it be in revervse? mounting positions??
Re: (forgotmypassword!(OTT))
The air mix motor is for RHD so it' s located on the left instead of the right so it works on the opposite way.
When I' ll install it like on JDM cars it' ll work inverted so when I'll set cold air it should send hot air.
The mod looks a little hard to do so in case I can' t do it I'll install it normaly, so it' ll work but inverted.
youknow if you ever put it on auto you'll end up cooking yourself lol. SHould be pretty good when finished, but cant you just use a USDM air mix motor to solve that issue??
There is no air mix motor on USDM cars,
there' s only a mode control motor.
Modified by Siegfried at 9:02 AM 1/26/2005
omer
09-14-2013 02:47 PM
