#1 | |||||
Electrician
Aegean Wiring and Lighting dspanoudakis@hotmail.com E-mail me for all types of electrical work needed in the Tri-State area. K.G.K. Electrical Contracting |
#2 |
http://www.rsmotorsinc.com/ |
#3 |
I have a set of four that I would give to you really cheap.
#4 |
Write up isn't bad at all.
<(.*^) <(.*< ^(*.*)^ (>*.)> (^*.)><U>Car</U> ...shopping arounD |
#5 |
Electrician
Question for those of you who have aftermarket headers:
Driving down the block, I started smelling somethig funny. Nothing burning, no rubber melting or anything. I tucked the wiring away with zip ties so I know it's nothing of that nature. It's a funny smell. I'm leaning towards it being the coating on the header. Has this happened to anyone with an aftermarket header?
#6 | |
The smell will go away after a couple of days, it's normal. |
#7 | |
Electrician
One question, do you HAVE to use a new gasket? Since I'll be removing the header again, soon, will I need a new gasket or can I get by with the existing one?
#8 |
Great writeup, but imo butt connectors are better than soldering.. either way though,
#9 |
bump for a good usefull thread.
#10 | |
BUY MY TURBO D16 STUFF http://honda-tech.com/zerothread?id=1743695 ^^^^^^^^^^^^^^^^^^^ Garrett, Greddy, TIAL, APEX'I |
#11 | ||
Electrician
And summamabitch, there's a pinhead sized hole on the Y-Pipe flange where it connects to the bottom of the header. God damn exhaust leak. Guess you get what you pay for. Need to remove it this weekend and get that hole welded in.
#12 | |
soldering looks and is much cleaner
D-series TURDBO 300.8 whp/271.8 tq MY CAR FOR SALE http://www.hondamarketplace.co...40660 BOOST doesn't get you laid. Roofies and some creativity does however |
#13 |
Soldering can be unreliable sometimes.. I guess it depends on how good of a job one is able to do. With butt connectors you just pop the wires in and crunch it, where a bad solder spot can have a weak connection like if you burn the solder too long. On an O2 sensor where something as minute as wire length resistance has an impact on sensor readings, I'd trust butt connectors.. plus if you mess up soldering you gotta cut the wire instead of simply taking off the butt connector. It's really not that hard to solder though, and that rarely happens, that's why I said "either way
." I really don't want to argue over it because it's more personal preference I guess.
#14 |
Electrician
Indeed, wire length does make a difference on resistance, but what does soldering or butt connectors have anything to do with the resistance? Regardless, the length will be the same, just the connection is different.
Indeed, just personal preference. BTW, I can remove solder from a wires tip without cutting it. Heat the solder and wipe quickly with a damp sponge, off it comes.
#15 |
1994 Honda Civic |
u can reuse the gasket. just becarefull not to mess it up. i wouldnt re use any other gaskets though.
94 civic coupe |
#16 | |
#17 |
good write up
but shit.. if you can't figure this one out on your own, i think you need to stay in the kitchen
[DC Squad Member # 0501] |
#18 |
Good Write up, i use to have a write up a while back but i think all my pictures are on Photobucket so there up and down. Good job though
93 B18C-<FONT COLOR="red">T</FONT> DX coupe <FONT SIZE="2"><FONT COLOR="red">Janer Performance</FONT></FONT> <FONT COLOR="blue">-Engine Building-</FONT> -Turbo Install- <FONT COLOR="green">-General Mechanic-</FONT> -We Sell BDL http://images.honda-tech.com/set1/smile/emthup.gif - PM for good deals. http://images.honda-tech.com/set1/smile/emthup.gif Vouch Custom Clutch Lines RIP Earl Laskey 12.1.06 You will be missed! http://images.honda-tech.com/set1/smile/emsad.gif |
#19 |
Electrician
Sometimes n00bs on here have a hard time installing an intake. Leaning more towards them, so they won't ask anymore questions.
#20 |
Nice writeup. Keep them coming. I was gonna do a header install but changed my mind and sold it instead.
<FONT COLOR="Red">I am 96-98 converted http://images.honda-tech.com/set1/smile/emsmilep.gif</FONT> <FONT COLOR="Blue"><<<</FONT> |
#21 |
that is the most peice of garbage header ive ever seen...
and using a paper gasket over a metal one... tsk tsk tsk...
Once upon a time there were 300 horses. The End. |
#22 |
Electrician
Thanks.
#23 |
im not hating on you. you seem a very thorough person and detail oriented. nice write up, but the product is trash, and if it were me i would re-use the metal gasket.
#24 |
Nice write up. I think the hardest part for my install was breaking the bolts loose under the car. Taking out the o2 after you get the exhaust mani out is a good idea, much easier.
I reused my old gasket as well, no problems yet. It's been installed for 3 or 4 months now. |
#25 | |
They both have their places. Soldering wires that will hang loose can cause them to break at the point where the solder meets the wire, due to vibration and moving. You can use a strain relief at the end of a wire, i.e. where the wire meets a connector, but putting heatshrink over the connection in the middle of a wire is the best thing you can do to prevent breaking.
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction." -Albert Einstein |
| Bookmarks |
| Tags |
| 04, 2001, 94, 97, aftermarket, civic, dimis, headders, header, headers, honda, install, installation, o2, sensor, tointall |
