ingalls camber kit adjust
ok can someone plz tell me how i can adjust my ingalls camber kit for the front, my friend did it but kind quick driver side is still kinda in and the passenger is out
is this hard or what?
Re: ingalls camber kit adjust (TURBODC4TEG)
you need to go get an alignment.........when i did mine, i adjusted the camber kit to the middle of the slider, tightened it, installed it, then drove 2 miles down the road to get a 4 wheel alignment( i put washers in the rear behind upper arm mounts, ghetto, but works fine), and they did everything else, camber, toe, etc......
When I set mine I just put them both on the lowest possible setting, this left me with about -0.5 degrees which is fine for me because I wanted some negative camber. You will definately need an alignment though
This may give you some info: http://www.integra.orcon.net.nz/camber
Dirty Octopus
28
02-20-2010 05:47 AM
itsJDMyo
13
01-07-2005 10:40 AM
