Torque specs on 1.6 VTec head.
Old 01-09-2005, 09:35 PM
socaly4life's Avatar
Default Torque specs on 1.6 VTec head.
Does anyone know what the torque specs are when replacing a head gasket on a '94 EX?
Thanks.
Old 01-09-2005, 09:41 PM
Street Ghost's Avatar
Default Re: Torque specs on 1.6 VTec head. (socaly4life)
for head bolts?
Old 01-09-2005, 09:43 PM
Default Re: Torque specs on 1.6 VTec head. (_Edge.ONE)
Yes, and it's a single cam.
Old 01-09-2005, 09:49 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">6. Tighten the cylinder head bolts in two steps, working your way from the inside bolts to the outside bolts.
-Step 1: 22 lb ft
-Step 2: 53 lb ft</TD></TR></TABLE>
Taken from BauleyCivic's mini me write up
https://honda-tech.com/zerothread?id=635580
Old 01-09-2005, 09:51 PM
Default Re: Torque specs on 1.6 VTec head. (chowmien)
Thank you very much. I'll hit you back once I'm done.
Old 01-09-2005, 09:56 PM
most hood white kid
.BigSexy's Avatar
tighten them in the sequence in the haynes or helms manual to about 23 lbs. then go back throught the same sequence and tighten them to 54 lbs.
Old 01-09-2005, 10:22 PM
skunk2finatic's Avatar
if you don't want it too leak, 23ft lbs , then 65ft lbs
Old 01-09-2005, 10:39 PM
most hood white kid
.BigSexy's Avatar
Default Re: Torque specs on 1.6 VTec head. (skunk2finatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2finatic &raquo;</TD></TR><TR><TD CLASS="quote">if you don't want it too leak, 23ft lbs , then 65ft lbs
if you do this and when you break a headbolt, or when you warp the head, you are gonna wish you hadnt listened to this guy
Old 01-09-2005, 10:44 PM
_Cyclone_'s Avatar
Default Re: Torque specs on 1.6 VTec head. (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">tighten them in the sequence in the haynes or helms manual</TD></TR></TABLE>
Indeed, stick to specs, don't overtighten the bolts because it won't leak if you tighten them to spec.
Old 01-09-2005, 10:52 PM
most hood white kid
.BigSexy's Avatar
Default Re: Torque specs on 1.6 VTec head. (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">
Indeed, stick to specs, don't overtighten the bolts because it won't leak if you tighten them to spec.</TD></TR></TABLE>
indeed
brainglow
12-17-2007 09:57 PM
2SLO
04-14-2006 07:31 PM
BrightRedOne
10-24-2004 09:45 AM
lintegras
10
12-03-2003 08:54 AM
G-reX
10-06-2003 04:55 PM
Quick Reply: Torque specs on 1.6 VTec head.
