Clarify the ABS mystery please.
Right then I picked up a 94 accord for my wife and it has an ABS fault. The ABS light goes of after I start the engine and then comes on as soon as I pull away. On inspection I found the previous owner had filled the ABS header to the brim. I extracted the excess until it was on the Max line but the ABS light is still coming on.
I have read that a 2 pin blue plug puts it into diagnostic mode and then when you turn the key the ABS light will flash out the error code. My questions are
1) The only 2 pin blue plug I can find is under the glove box on the very outside of the car but a previous post says I am looking for one behind the radio and there isn't one there?
2) Might it just need reseting after I put the fluid level back to normal and if so how do I reset it?
Thanks in advance for your time.
Re: Clarify the ABS mystery please. (mark48)
nope you had the right plug, its the 2 prong blue plug. pull the connector and jump it with a paper clip. Search for the codes and other information on abs, there has been a ton of talk on it lately
Re: Clarify the ABS mystery please. (propwdialogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...81838 </TD></TR></TABLE>
MES connector for an ABS problem???
Re: Clarify the ABS mystery please. (jbkiksass69)
That was the diagnostic plug and good as gold the ABS light flashed out 4-8 (Left hand rear wheel sensor)
Saved me £40 for the diagnoistics, now all I have to do is fix it
Thanks everyone for the pointers.
lucky yours was just a sensor... on both ex accords mine was the pump buzzing away until it finally quit, it had a leak in pressure somewhere... i htink i have a wheel sensor layin around somewhere, but i would hafta go digging for it...
Well the left rear sensor was reading 500K so it was faulty, I swapped it for one that reads 634 Ohms (with the 600 - 900 Ohms range) and it still gives the same 4 - 8 erro ?????
Is this simply a logged fault that now needs reseting or something else. Your thoughts and suggestions will be greatly appreciated................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark48 »</TD></TR><TR><TD CLASS="quote">
Is this simply a logged fault that now needs reseting or something else. </TD></TR></TABLE>
Did you try reseting it?
Re: Clarify the ABS mystery please. (Chiovnidca)
Well if you mean disconnecting the battery for 5 mins then yes but if there is another way then I don't know how.
Cheers
Mark
Cheers
Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark48 »</TD></TR><TR><TD CLASS="quote">Well if you mean disconnecting the battery for 5 mins then yes </TD></TR></TABLE>
That should do it. Time to start looking for other causes.
Undercover_Skank
03-15-2004 07:13 AM
