| Welcome to Honda-Tech! | ||
#1 |
How do you reset the engine light on 2000 accord?
yes I already used the search function [Modified by 89civicdx, 8:18 PM 1/7/2002] [Modified by 89civicdx, 9:24 PM 1/7/2002] |
#2 |
err the check engine light??
well its a 2000 so hook that heavy **** up to a scanner find the problem fix it and then reset the ecu or have the scanner reset it.
[email]furyEEL@yahoo.com[/email] |
#3 |
No the question is HOW do you turn off the light? What is the method used?
#4 |
| Garage is empty, add now |
you must use a scan tool to reset light
#5 |
Do u mean engine light or the maintaneance required light?
CA18DET 240sx 2002 Civic Si |
#6 | |
my gsr has a button right under the dash and i push it in... i felt around on my accord but couldn't find anything. |
#7 |
I believe you hold down the reset button for 10-15 seconds while the key is in the ignition but in the OFF position, then after 10-15 seconds you turn your key (finger still on reset button) to the first position for about 5 seconds and then let go of the reset button. See if that works.
#8 |
I called the dealer yesterday and asked the parts department... here's what he told me. Evidently, it worked. My light isn't flashing anymore
With the car off, key off, etc... Push and hold down the trip reset button, turn the key just so the dash lights come on, keep holding the trip reset button down, the maintenance required light will flash several times and then it will go off, once the light goes off, release the trip reset button, then turn the key off. voila! |
#9 |
make sure this gets archived, thanks for sharing lilmikey
#10 | |
#11 |
Resetting the Maintenance Light is somewhere in our owners manual. I read it long time ago.
| Tags |
| 2000, 2001, accord, check, dash, ecu, engine, hold, honda, light, lightaccord, lights, reset, resetting, turn |
