Old 01-01-2005, 01:32 PM   #1
lindy3080
lindy3080's Avatar
Default 92 Accord EX - How to change front headlights?
Does anyone out there know how to change out the front headlight BULB of a 92 Honda Accord EX? The owner's manual doesn't say, and after trying to fish around with my hands I'm afraid I will break plastic and be bummed.
Using a mirror, I can see behind the headlight assembly under the hood. There is a black circular ring around a white plastic piece. The ring has the words Open and Lock with opposite arrows next to either one. But the thing won't budge when I try to move it in either direction.
Anyone know what to do?
EDIT: I don't need to replace the whole headlight assembly. I only want to replace the bulb.....
Modified by lindy3080 at 3:19 PM 1/1/2005
lindy3080 is offline   Reply With Quote
Old 01-01-2005, 01:44 PM   #2
kevinm1981
2000 Acura Integra
http://www.facebook.com/profile.php?id=100000940424469 kevinmcclelland
Default Re: 92 Accord EX - How to change front headlights? (lindy3080)
you gotta remove the front bumper and bumper support
kevinm1981 is offline   Reply With Quote
Old 01-01-2005, 02:21 PM   #3
lindy3080
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (kevinm1981)
I just need to replace the bulb, not the assembly. I shouldn't have to remove the assembly to do that should I? On the rear of the assembly it appears as though I can unscrew a black plastic ring which will free the bulb to be removed from the rear. BUT, the ring will not rotate. Is there something else I need to do?
Old 01-01-2005, 02:28 PM   #4
darwinizm
darwinizm's Avatar
Send a message via AIM to darwinizm
wat he said
CHECK ME OUT!!!!
[url="http://www.hondaswap.com"]http://www.hondaswap.com[/url]
I learned how to put a vtech in my car there.
darwinizm is offline   Reply With Quote
Old 01-01-2005, 02:44 PM   #5
lindy3080
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (mysterious_2)
in order to replace a headlight bulb you have to remove the front bumper? surely not...???
Old 01-01-2005, 02:50 PM   #6
kevinm1981
2000 Acura Integra
it says Headlights, not headlight bulb, stupid girl
Old 01-01-2005, 04:40 PM   #7
jdmcb3
jdmcb3's Avatar
Send a message via AIM to jdmcb3
turn the black trim ring around the light bulb counter clockwise to unlock the bulb
[b]trikSPEED[b]
[b]team2to:::[b]
representing seatown
atlantis blue pearl 93 accord coupe
DU-MA
email-hdoubleduce@hotmail.com
aim-jdmcb3h22
jdmcb3 is offline   Reply With Quote
Old 01-01-2005, 05:20 PM   #8
Lostcb7
Lostcb7's Avatar
Send a message via AIM to Lostcb7
Default Re: 92 Accord EX - How to change front headlights? (jdmcb3)
You are correct. To get the trim ring to move you might need to use a flathead screw driver and a hammer to get the thing turning. Remember these things are probably on moved every few years, if that, so they are going to be a bit tight. On the bulb there are 3 flat tabs sticking out that will line up with the holes on the trim ring. Match them up and the bulb pops right out. Hope that helped.
Lostcb7 is offline   Reply With Quote
Old 01-02-2005, 02:04 PM   #9
lindy3080
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (Lostcb7)
Thanks, Lostcb7. I appreciate your kind and thoughtful reply. I was able to replace both bulbs using your tips. The plastic rim was on there very tight, and I used a flathead and hammer just like you suggested... without worrying that I was inadvertently going to break any plastic.
My husband and I just moved from Nashville to Atlanta, and I am not surprised that the nicest reply to my post came from there! It's a shame some people from Kent, Washington, are so desperate to feed their egos that they grovel with lame attempts to belittle others.
Thanks again for your helpful reply.
Old 01-02-2005, 03:09 PM   #10
Lostcb7
Lostcb7's Avatar
Your welcome, glad I could help Click the image to open in full size. I had to learn the hard way through trial and error and lots of cursing. As for the people with the negative responses, you really have to watch out for those e-thugs, they are real hard asses. Click the image to open in full size.
Edit: If you plan on addressing more general maintenence issues with your car, it would be very beneficial to pick up a Haynes manual at your local Auto Parts store.
Old 01-05-2005, 08:26 AM   #11
mrvinyl33
Good call for the flathead screwdriver. I couldn't get mine to move either until one was used. There were serveral of us trying to do it, they all thought I wasn't strong enough to turn it until they realized none of them could. At that point I remembered that the screwdriver trick and voila!
'92 Accord LX Sedan 210k--OEM
mrvinyl33 is offline   Reply With Quote
Old 01-05-2005, 10:20 PM   #12
Trumpster
Trumpster's Avatar
Default Re: 92 Accord EX - How to change front headlights? (mrvinyl33)
Haha, good times. I remember having trouble trying to figure out how to get mine out too. I actually tried twisting the bulb before I figured out that it was the black ring AROUND the light that I had to turn. I actually broke the plastic plug where the wires plug in completely off! I got that all figured out, now I just need to find some good bulbs that are bright and have good distance (that don't burn out between 20 and 90 days Click the image to open in full size.)
1990 Accord EX:
Matrix Short Ram Intake w/K&N cone, Matrix Header and Downpipe
Bosch o2 Sensor
High Flow Cat, 2.5'' Piping w/22'' Glasspack, Flowmaster 40 Series Muffler
Silver 17''x7.5'' BSA 220's
Tsudo Coilovers (500f/400b), Camber kit ([img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] to even tire wear)
DC Upper Front Strut Bar
South Bend Rally Stage 2 Clutch
1/4 Time: 16.7 sec @ 81.58
Trumpster is offline   Reply With Quote
Old 01-24-2011, 04:02 PM   #13
chiko321
Hoping to get better leverage, I wedged a screwdriver in one of the slots on the back of the ring and broke it as soon as I struck the screwdriver. Obviously I can change the bulb now, but the ring is very loose. Where can I get a new ring? Must I buy the entire headlamp assembly? Surely not!?!?
chiko321 is offline   Reply With Quote
Old 01-26-2011, 06:46 PM   #14
uberEFtuner
1991 Honda Civic
My Garage
uberEFtuner's Avatar
To change the bulbs, I sprayed the headlight retaining ring with WD40 first. Then after getting it apart, cleaned it off with soap and water.
Its all about HONDA help your brothers.
uberEFtuner is offline   Reply With Quote
Old 01-27-2011, 04:12 PM   #15
poorman212
I've seen the ring in the aftermarket (AZ, NAPA, CARQUEST, ECT). The dealer might also carry them.
66 Chevelle...89 LX auto...89 LXI 5 Speed
...95 EX auto...07 Pilot 2wd
87 LX 5 Spd (sold )...88 LXI Auto (soon to be sold)
poorman212 is offline   Reply With Quote
Old 04-05-2013, 08:06 PM   #16
Easy Duzit
I just went through this too. Wound up breaking the locking ring. Only $5 for a new one through the dealer but it's a special order part. Won't be in for a few days. So right now the bulb is being held in place by duct tape lol.
92 Accord 2dr Ex
2.2L Auto
Easy Duzit is offline   Reply With Quote
Old 04-06-2013, 12:28 AM   #17
holmesnmanny
Everyone is not completely and totally careful will break the locking ring. I did this the very first time I tried replacing my bulb on the first Accord I had. Now I have to be really careful and spray the **** out of em when I try to replace mines.
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is offline   Reply With Quote
92, 97, accord, adjust, broke, bulb, change, front, headlight, headlights, honda, light, retaining, ring, ways
