how can you tell if a ecu is automatic or standard i have a p30
Old 12-11-2004, 04:57 PM
jaydmegsix's Avatar
Default how can you tell if a ecu is automatic or standard i have a p30
how can you tell if a ecu is a automatic or standard i have a p30 ecu
Old 12-11-2004, 07:22 PM
RedlinedVTEC's Avatar
Default Re: how can you tell if a ecu is automatic or standard i have a p30 (1990efeight)
You can thank Katman for the image.
Old 12-11-2004, 08:00 PM
d16rice's Avatar
YES, I can finally share my research with someone.
To answer your question, look at the code on the ECU/ECM, If the last two digits are 50 and up (for example: …..-A53), then it’s an automatic.
Please correct me if I’m wrong.
I noticed that the first sequence (5 digits) is identical for all Honda/Acura cars, so it doesn’t do much.
The second sequence (3 digits) tell us what engine the ecu goes with.
The third sequence (3 digits) tell us what transmission it goes with.
I still don’t know that the big letters (AWL, ARM, etc..) or the rest of the numbers stand for.
ECU/EMC CODE LETTER OTHER #’s YEAR MAKER MODEL Trim OBD TRANNY
37820-P28-A02 AWL 760-840433 92-95 Honda Civic EX 1 5-speed
37820-P28-A01 ARM 760-620375 92-95 Honda Civic/CRX EX 1 5-speed
37820-P06-A02 AUI 740-327690 95 Honda Civic LX 1 5-speed
37820-P06-L00 AP? 742-501219 92-95 Honda Civic DX 1 5-speed
37820-P2T-A11 Z4 99-00 Honda Civic Si 2 5-speed
37820-P2P-A31 99-00 Honda Civic EX 2 5-speed
37820-P2E-A12 59 1200-246675 99-00 Honda Civic LX 2 5-speed
37820-P2E-L01 EF 901-115146 96 Honda Civic DX 2 (5-speed?)
37820-P2E-L02 LG 901-200297 96-98 Honda Civic DX 2 (5-speed?)
37820-P2P-A34 UP 921-322852 96-98 Honda Civic EX 2 5-speed
37820-P2E-A71 ER 260-175174 96-98 Honda Civic DX 2 (automatic?)
37820-P72-A02 G1 970-102606 96 Acura Integra GSR 2 5-speed
37820-P2N-A61 1111-301713 96-98 Honda Civic HX 2 CVT
37820-P2N-A31 297-302848 96-98 Honda Civic HX 2 5-speed
37820-P75-A53 981-202919 98 Acura Integra LS 2 Automatic
This is my conclusion for now:
ECU/ENGINE
P06 – 1.5l SOHC ----- OBD1 - LX, DX
P28 – 1.6l SOHC Vtec OBD1 - EX, Si
P2E – 1.6l SOHC ----- OBD2 - CX, DX, LX
P2T – 1.6l DOHC Vtec OBD2 - Si
P2N – 1.6l SOHC Vtec OBD2 - HX
P2P – 1.6l SOHC Vtec OBD2 - EX
P72 – 1.8l DOHC Vtec OBD2 - GSR
P75 – 1.8l DOHC ----- OBD2 - LS
ECU/TRANSMISSION
A50 and up Automatic
A61 CVT
A under 50 manual
L under 50 manual
Lance Darling
Honda Civic (2006 - 2015)
06-18-2019 01:36 PM
Kipper-Fish
11-25-2008 09:43 AM
reyrey2006
09-21-2008 11:19 AM
Quick Reply: how can you tell if a ecu is automatic or standard i have a p30
