> Acura Integra
Old 01-02-2002, 08:41 PM   #1
Brian_92GSR
Brian_92GSR's Avatar
Default fuel rail stud broke
When I was installing new injectos a while back one of the studs holding the fuel rail to the intake manifold broke off. Does anyone know if these studs are screwed in or cast into the manifold. If they are screwed in, are they something an acura dealer shoul have?
1992 Acura Integra GS-R Turbo
Brian_92GSR is offline   Reply With Quote
Old 01-02-2002, 10:11 PM   #2
da6_b17a
Send a message via AIM to da6_b17a
Default Re: fuel rail stud broke (Brian_92GSR)
don't worry, they come off.
Sometimes I wonder where it's all gonna end!
Hopefully somewhere in the single digits.
da6_b17a is offline   Reply With Quote
Old 10-14-2003, 09:31 PM   #3
MiraiZ
1998 Acura Integra
My Garage
MiraiZ's Avatar
Default Re: fuel rail stud broke (da6_b17a)
Hey ...this happened to me...does anyone know the part number and where I can get a replacement online?
1998 Honda Integra Type R Turbo (All JDM) est. 320whp (race car)
1992 Rover Mini Cooper (team car) est. 90whp (sold)
2004 Subaru Forester Cross Sports 2.0 Turbo est. 210 whp (daily car)
MiraiZ is offline   Reply With Quote
Old 10-14-2003, 09:37 PM   #4
IN VTEC
2004 Audi S4
My Garage
IN VTEC's Avatar
iTrader Rating: (1)
Ben Chang Dr Eugh
Send a message via AIM to IN VTEC
Default Re: fuel rail stud broke (MiraiZ)
I had an issue with having only one usable stud when we switched the GS-R manifold for a Skunk2 manifold. I ended up using (2) M6x1.00x22mm flange bolts from the hardware store and using the stud in the middle as a placeholder.
Use a set of pliers to screw the stud out, or you can cut parallel faces onto the stud and use a wrench. Go to the hardware store and buy 6mm flange bolt of the appropriate length for your application. 22mm length might not be right for you.
IN VTEC is offline   Reply With Quote
Old 10-22-2003, 07:34 PM   #5
MiraiZ
1998 Acura Integra
My Garage
MiraiZ's Avatar
Default Re: fuel rail stud broke (IN VTEC)
anyone else know the size for the OEM fuel rail studs?
Old 10-22-2003, 07:46 PM   #6
tilt
tilt's Avatar
haha. I ended up doing the exact same thing with my skunk2 swap (2 of the fuel rail studs broke). I felt like i was ghetto-rigging the fuel rail going to the hardware store piecing parts together to bolt it down. But now i feel much better knowing im not the only one
tilt is offline   Reply With Quote
Old 10-23-2003, 12:05 AM   #7
IN VTEC
2004 Audi S4
My Garage
IN VTEC's Avatar
iTrader Rating: (1)
Ben Chang Dr Eugh
M6x1.00x22mm for the center one and M6x1.00x35mm for the two ends on GS-R's, and they're all M6x1.00x22mm studs on the ITR manifolds.
95, accord, bolt, bolts, broke, broken, fuel, furl, gm, h22, honda, intake, m6x100x22mm, rail, stud, studs
