drivers side heater vent----crx
Old 11-29-2004, 12:41 PM
limpy's Avatar
Default drivers side heater vent----crx
I know that everyone with a crx has had the problem with the drivers side heater vent not closing like it should. every crx i've been in has had that problem. does anybody know how to fix it?
Old 11-29-2004, 12:59 PM
301am's Avatar
mine works
Old 11-29-2004, 01:08 PM
jam4484's Avatar
Default Re: (301am)
Mine just blows cold air even when the heat is on so I am curious as how to fix it too.
jon
Old 11-29-2004, 01:44 PM
NONVTECSI's Avatar
Mine hardly blows even on full blast. I Think its just clogged with dirt.
Old 11-29-2004, 01:59 PM
itsallmotor's Avatar
Location: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: (NONVTECSI)
mine works like a charm sorry
spyz34's Avatar
Default Re: (jam4484)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jam4484 &raquo;</TD></TR><TR><TD CLASS="quote">Mine just blows cold air even when the heat is on so I am curious as how to fix it too.
jon</TD></TR></TABLE>
Ditto. I just noticed it a week ago. Always cold air. Any reasoning behind this phenomena(sp)??
Old 11-29-2004, 02:07 PM
ELAMINT5's Avatar
Default Re: (spyz34)
Old 11-29-2004, 02:54 PM
erikiksaz1's Avatar
I forgot how my old crx was set up, but i figure it's something similar to my hatch. Anyways, don't you guys have a slider right underneath the vent that allows either "recirculation" or "open circulation?"
My only gripe is that recirculation isn't as strong as it should be.
Old 11-29-2004, 02:56 PM
limpy's Avatar
Default Re: (erikiksaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 &raquo;</TD></TR><TR><TD CLASS="quote">I forgot how my old crx was set up, but i figure it's something similar to my hatch. Anyways, don't you guys have a slider right underneath the vent that allows either "recirculation" or "open circulation?"
My only gripe is that recirculation isn't as strong as it should be.</TD></TR></TABLE>
yeah... that is what i'm talking about. the fresh air is always stuck on so it blows the air from the outside of the car inside. i can't slide it over in order to get it into recirculation so that it will stop blowing the damn cold air.
Old 11-29-2004, 02:57 PM
T--Rex's Avatar
Mine has that switch below the vent, when it is on one side i get warm air through it... a tad weak, but still warm. When it is the other way i get cold air.
Old 11-29-2004, 04:23 PM
limpy's Avatar
Default Re: (Matrix_Zero)
mine is stuck on the side that only gets cold air. how do i fix???????????????????
Old 11-29-2004, 04:31 PM
The Lobster's Avatar
yea mine isnt stuck but on recircuit it sucks *** its getting cold in here now too and how small these cars are and how fast they fog up everythign helps!
Old 11-29-2004, 09:18 PM
erikiksaz1's Avatar
Default Re: (limpy)
I remember a while back when my climate control slider was stuck as well. What happened was that i accidentally zip tied something to one of its sliding components in the back. Maybe the same thing happened with your air vent? Maybe you've got something jammed up there?
Old 11-29-2004, 09:45 PM
eda6's Avatar
That vent fell out in my hatch. Is this a junkyard item or do i need a new dash?
Old 11-30-2004, 12:59 AM
mike_belben@yahoo.com's Avatar
Location: not riding any bandwagons in, massachusetts, usa
unscrew the left side change tray and look underneath. the vent slider has a cable that pulls an arm. it just opens or closes a door into the tunnel that is connected to the windshields high pressure base area. the faster you go, the higher the pressure and therefore more force on the vent. that vent is also connected to the heater/aC ducting like the others i believe, but the pressure overpowers the ventilation system until you close the door by sliding the lever.
atleast im pretty sure. i strip them all the time and dont pay much attention to anything but removing the cable. you have to to get the dash off.
Old 11-30-2004, 01:54 AM
limpy's Avatar
Default Re: (mike_belben@yahoo.com)
all i want to know is how can i make it stick on recirculation instead of fresh air. i'm tired of that damn cold draft.
Old 11-30-2004, 05:07 AM
CRX Toad's Avatar
Default Re: (limpy)
You need to remove the coin tray as stated above, get your head under the dash and your feet on the headrest so you are completely under the dash. At this point the cable wil be in a black sheath or tube that connects the fresh air vent lever to the vent itself (it will be on you right at this point). You can remove the lever (the one on the dash) and cable but be careful and not break the white lever that is connected to the actual vent up by the firewall. At this point you can either replace the wire with a junkyard find, or the local hardware has this wire and you can repair it with a whole new piece. If you want a quick winter fix just move the white lever up by the firewall and you will hear the vent shut and you will receive warm air instead of the fresh outside air.
And no you don't need a new dash, and YOU DON'T NEED TO REMOVE THE DASH TO FIX THIS
Old 11-30-2004, 05:08 AM
Erik_Pb_Foot's Avatar
Default Re: (limpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">all i want to know is how can i make it stick on recirculation instead of fresh air. i'm tired of that damn cold draft.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">unscrew the left side change tray and look underneath. the vent slider has a cable that pulls an arm. it just opens or closes a door into the tunnel that is connected to the windshields high pressure base area.</TD></TR></TABLE>
Old 11-30-2004, 07:14 AM
thanks.. i didnt think it was very hard.
Old 11-30-2004, 12:21 PM
limpy's Avatar
i took that whole thing appart and when i put it back in the dash it wouldn't turn of again. wtf?
Old 11-30-2004, 12:28 PM
CRX Toad's Avatar
Default Re: (limpy)
Also if you look in the drivers side vent you can see the "door" or "flap" that opens and closes, you can also take a long screw driver and SLOWLY close the vent don't force it. Take the vent out and you can really see the fresh air vent. That would be a last resort.
As far as why you took is part and put it back together and it still doesn't work might suggest that you put it in slighty wrong or something is binding in there that you can't see. Make sure that the lever that is attached to the dash is lubed and has some grease on it or it may have slight rust on it which would also bind it
If you lived in NC I would say bring it down but....OR is a ways away
Old 11-30-2004, 02:08 PM
limpy's Avatar
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
If you lived in NC I would say bring it down but....OR is a ways away</TD></TR></TABLE>
just across the country... not to far, lol. i think ill take it apart later today and trace the wire back and find out what is going on. thanks guys.
alscrx
10
01-03-2008 06:57 PM
circapunk
11-19-2007 06:20 AM
cbp_crx
07-26-2005 04:25 PM
cascaritas
07-21-2004 11:39 PM
95integraTurbo
02-13-2002 08:37 AM
Quick Reply: drivers side heater vent----crx
