> Honda Prelude
Old 11-29-2004, 10:44 AM   #1
Sam1am26
Sam1am26's Avatar
Default ...G23 VTEC...(56K...Definitely Beware)
EDIT: Here is the semi-disappointing dyno... After a few fixes, a boost controller, and some more tuning I think the numbers will be alot more impressive...
214whp@7150rpms_____195wtq@4400rpms_____@ 6 PSI
*Sorry for the shatty picture...
The Beginning:
Well it is getting closer to being complete so I decided it was time to start posting up some pics in case anyone was interested... As some of you know I spun the rod bearings in my H23 VTEC due to oil starvation and over-revving... So now I am taking my H22 head and putting it on an F23 block and boosting the hell out of it...
I got this F23a1 from a friend who has had it in his garage forever...
This was the most recent pic I had of my H23 VTEC before I fooked it up...
Hear are a few pics of the tear down...
AEBS head studs that I will be re-using...
Tranny coming off...
I also looped my power steering lines this time around since I have been running with no belt for months...
It looks a lot cleaner with no power steering, cruise control, and no windshield washer fluid reservoir...
I haven't had a chance to weigh everything but I put it all in a bag and it has to weigh at least 20 lbs, and that doesn't even include the fluid you drain...
Head came off in like 5 seconds just like Pirate said...
This pic is supposed to show the block code, but you can't even see it cause the block is so worn...
2.3L Iron sleeved...97mm Stroke... Mmmmm.....
This is actually a picture of my H23 block with the F23 head gasket sitting on top just so you can see where the head isn't going to line up perfectly... Nothing a little Hondabond won't fix...
This is a comparison of the H22 water pipe(top) and the F23 water pipe(bottom)... Pirate was lucky that an F22 water pipe fit perfectly for him but when using an H22 head there aren't any water pipes that will bolt up... So I am going to cut them both in half and connect them with a rubber hose, no biggie...
This is a picture of the H22 alternator and AC brackets bolted to the F23 block... If you look at the alternator bracket you can see the it has 4 bolt holes while the F23 Bracket only had 3... However, it is interesting that when you bolt up the H22 Bracket there is a 4th hole that lines up perfectly but is not threaded because it was not intended to be using in an Accord... I could always tap the hole and use it but the three bolts will hold it just fine... But that just shows how similarly cast the F/H blocks were...
And this is the motor half assembled...
And the rear...
So I just need to put the tranny on the new motor and drop it in... Then it is time for the turbo install and to get it tuned on the dyno... They are having a dyno day at Titan Motorsports on Dec. 4th that I was planning on going to, but by the looks of things now I'm not gonna make it... But that's ok, I need to take my time and do things right anyways... More pics to come as the project progresses...
Modified by Sam1am26 at 2:13 PM 6/15/2005
Modified by Sam1am26 at 11:48 AM 6/19/2005
Sam1am26 is offline   Reply With Quote
Old 11-29-2004, 10:53 AM   #2
JadedGamerX
JadedGamerX's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (Sam1am26)
I'm in love.
JadedGamerX is offline   Reply With Quote
Old 11-29-2004, 11:01 AM   #3
uncle
uncle's Avatar
WOW.
I wish I could see the all motor dyno but the turbo dyno will do I guess.
Originally Posted by George Knighton
I object to that comment [chet], just for the record, and condemn you to your own mind.
uncle is offline   Reply With Quote
Old 11-29-2004, 11:01 AM   #4
blaster834
Send a message via AIM to blaster834
Still blows my ****** mind how you can put a DOHC head on a SOHC motor, i guess i am just used to B and D series not getting along well. Cant wait for that turbo
SO CAL<NOR CAL< HAWAII
but princess will always take the cake.
blaster834 is offline   Reply With Quote
Old 11-29-2004, 11:30 AM   #5
Sam1am26
Sam1am26's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (PirateMcFred)
Originally Posted by PirateMcFred
Are you going to run the balance shaft belt? I guess with turbo you won't be starving for power. Wht are you going to do for the driver's side engine mount? Mod the stock one?
So, when is the swap?
Great project
Pirate
Yeah, like you said I won't be starving for power and I don't want the extra vibration... I'm still undecided on the mount... Will the prelude mount bracket bolt to the f23 block? If not I know you used an f22 mount bracket so I'll figure something out... The motor will hopefully be in by this weekend...
Old 11-29-2004, 11:32 AM   #6
AndyD
AndyD's Avatar
Nice, dude!!!
I really wanted to see a dyno of a NA G22/3 though
'92 Accord Sedan w/H22A. '92 Prelude Si 4WS engineless. '89 240SX w/SR20DET.
Vouch thread
CB7 F22A1 H22 5spd swap parts FS
AndyD is offline   Reply With Quote
Old 11-29-2004, 11:45 AM   #7
SKDRCR
SKDRCR's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (AndyD)
Awesome, I've been waiting for you to post up some pics of this project
So you left the block completely stock?
What do expect the compression ratio to be?
Somewhere around 9-9.3:1?
Chris
92 lude h22a
Karma police own j00
FOR SALE THREAD http://www.honda-tech.com/zerothread?id=981072
Good buyers: *barroom hero**five-0**PrecisionH23a**LudeyKrus*
Good sellers: *CHK4TIX**lightning**waterboy683*
<FONT COLOR="red">Need used import car parts cheap? Tell me what you're looking for http://images.honda-tech.com/set1/smile/emthup.gif </FONT>
SKDRCR is offline   Reply With Quote
Old 11-29-2004, 11:52 AM   #8
Nikoli
Nikoli's Avatar
Send a message via AIM to Nikoli
looks like its gonna be a boost monster
im glad everyone is doing this setup now. i just got my hands on an f22a7 sohc nonvtec. i plan on putting an h23 head on it and some bo0ost
cant wait to see the dyno
<FONT COLOR="red">FOR SALE</FONT> DEFI link meter gauges
http://honda-tech.com/zerothread?id=1720624
Nikoli is offline   Reply With Quote
Old 11-29-2004, 12:35 PM   #9
monalisa overdrive
monalisa overdrive's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (Deckedlude)
so how does this compare to an H23VTEC (in both NA and FI trim)?
monalisa overdrive is offline   Reply With Quote
Old 11-29-2004, 12:55 PM   #10
hOndafienD 04
hOndafienD 04's Avatar
Send a message via AIM to hOndafienD 04
Default Re: ...G23 VTEC...(56K...Definitely Beware) (uncle)
Originally Posted by uncle
WOW.
yeah man get an all motor dyno then go boost
great job on the hybrid, i see a new trend starting....will this hybrid have the same reving problems as the h23/vtec since it has even more stroke?
FOUNDER and co owner of SB TUNING
hOndafienD 04 is offline   Reply With Quote
Old 11-29-2004, 01:09 PM   #11
Boost Addict
Boost Addict's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (hOndafienD 04)
awesome setup man.
I can't wait for some dyno numbers.
[I]Criminals thrive on the indulgence of society's understanding.[/I]
[B]'99 Acura 3.0CL[/B]
[B][url="http://www.honda-tech.com/garage?cmd=viewcar&id=3826"]'02 Honda S2000[/url] - SOLD[/B]
[B][url="http://www.honda-tech.com/garage?cmd=viewcar&id=1915"]'99 Honda Prelude[/url] - SOLD[/B]
Boost Addict is offline   Reply With Quote
Old 11-29-2004, 01:42 PM   #12
Sam1am26
Sam1am26's Avatar
Yeah I left the block completely stock... Compression is about 8.6:1, which is super low but super boost friendly... And that is another reason there won't be an all motor dyno, because it would be weak with this c/r...
Well an h23 has a bore and stroke of 87mm and 95mm respectively, and an f23 has a bore of 86mm but a stoke of 97mm.... So the torque comes up just a few hundred RPMs earlier than an h23... but the rod stroke ratio is a little lower... FI wise, accord blocks are known to hold up to 15 lbs of boost stock... So I can run more boost on this motor than if i had boosted my h23 vtec because f23's are iron sleeved and h-series are made of frm...
Well the rod to stroke ration is worse...But the F23a1 does have newer 55mm crank mains which are larger then the 50mm crank mains of the h23 and pre98 h22 blocks... Theoretically the larger mains would reduce the amount of sideload and stress on the rods... But either way I'm taking it easy on this motor... Whatever rpm the motor stops making power at is gonna be my rev limit....
Old 11-29-2004, 02:01 PM   #13
AndyD
AndyD's Avatar
AMEN to that.
Are you going to run the H23 tranny again??
Vouch thread
Old 11-29-2004, 02:05 PM   #14
hOndafienD 04
looks promising....cant wait for the results!
Old 11-29-2004, 02:41 PM   #15
fenominal
fenominal's Avatar
Send a message via AIM to fenominal
Default Re: (hOndafienD 04)
yeah actually, what tranny will you be using? and for what purpose will this car be for? everyday with some track, or a lot of track?
"...the concept of man as a heroic being, with his own happiness as the moral purpose of his life, with productive achievement as his noblest activity, and reason as his only absolute." -Ayn Rand, Atlass Shrugged, on her philosophy of Objectivism
fenominal is offline   Reply With Quote
Old 11-29-2004, 02:46 PM   #16
Sam1am26
Sam1am26's Avatar
I'm going to be re-using my h23 tranny... The car is going to be daily driven and abused on the weekends if ya know what i mean...
Old 11-29-2004, 02:52 PM   #17
Daboi630
Daboi630's Avatar
Send a message via AIM to Daboi630
good stuff
will you be taking donations as well
[url="http://www.honda-tech.com/garage?cmd=viewcar&id=1038"]95 Prelude SE JDM H22[/url] - Sold [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
03 Acura TL Type S [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img]
[url="http://www.honda-tech.com/zerothread?id=838378"]My Vouch Thread[/url]
[b]*** Type S Cams and 96 Spec Type <FONT COLOR="red">R</FONT> Rims for sale!*** [/b]
Daboi630 is offline   Reply With Quote
Old 11-29-2004, 03:09 PM   #18
Nikoli
Nikoli's Avatar
Default Re: (PirateMcFred)
You intend to take it to the strip right? So once you are turboed aren't you going to have all sorts of traction problems? Maybe while it is all apart you could see what happens with an OBX LSD. I know that it sounds bad, but the B series ones have been holding up pretty well the FI forum. If it blows then get your money back and then get an H22 tranny. Just a thought...
Pirate
i didnt think they had one for us?
Old 11-29-2004, 03:50 PM   #19
Paulnsx
Paulnsx's Avatar
very nice.
Fun: GG Evo IX SE
Daily: Mk6 GTI
Paulnsx is offline   Reply With Quote
Old 11-29-2004, 06:41 PM   #20
GOTNOS
GOTNOS's Avatar
Send a message via AIM to GOTNOS
Default Re: ...G23 VTEC...(56K...Definitely Beware) (Paulnsx)
can i get the official gather up part list for the G23 Vtec please thanks. Winter Project
<U>[B]P14 ECU Unchiped (Make offer)</U>[/B]
<U>[B]Want Your Xbox Modded?</U>[/B]
MSG ME
<u>[b]My Lude[/b]</u>
[url="http://honda-tech.com/zerothread?id=1066727"]http://www.mnsportcompacts.net/forum/vbgarage.php?do=view&id=734[/url]
Testing WATERS: FS: Prelude
[url="http://honda-tech.com/zerothread?id=1073795"]http://honda-tech.com/zerothread?id=1073795[/url]
GOTNOS is offline   Reply With Quote
Old 11-29-2004, 08:55 PM   #21
BolivianFuego
BolivianFuego's Avatar
Send a message via AIM to BolivianFuego
Default Re: ...G23 VTEC...(56K...Definitely Beware) (GOTNOS)
Fucking awsome. Man a couple years back and people would think that you were liar. hahaha For the advancement of the hseries.
JustDoingMy Thing.
BolivianFuego is offline   Reply With Quote
Old 11-29-2004, 09:23 PM   #22
BolivianFuego
hahaha. Word. If it wasnt for Bizi Though i doubt there wouldnt be to many enquioring(sp.) minds
JustDoingMy Thing.
Old 11-29-2004, 09:25 PM   #23
d0twinx
1998 Honda Civic
d0twinx's Avatar
Send a message via AIM to d0twinx
Default Re: ...G23 VTEC...(56K...Definitely Beware) (BolivianFuego)
yea i know ppl taht still say it cant be done. ha to them
1998 Honda Civic ~ Work In Progress - 1997 Toyota Camry XLE 4cyl ~ FOR SALE - 1994 Acura Integra ~ SOLD - 1993 Honda Civic DX ~ R.I.P. Totaled - 1992 Acura Integra ~ SOLD - 1991 Honda Accord ~ Sold ~
d0twinx is offline   Reply With Quote
Old 11-30-2004, 05:04 AM   #24
95cxh22a
95cxh22a's Avatar
Send a message via AIM to 95cxh22a
Default Re: ...G23 VTEC...(56K...Definitely Beware) (d0twinx)
I am so interested in this thread. I have really been thinking of doing this. I will be watching this thread.
sold to: boostinhard ,dyrcivic,phatboy5015
traded to: driftt
bought from: 93turbo16,honda9369,H-T JT0220 ::csracing ::soon2brb240 ::Honda4CX-T :: b18TurboEF:
bought from:95_integra [img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img]
[url="http://www.torqueaddicts.net"]http://www.torqueaddicts.net[/url]
95cxh22a is offline   Reply With Quote
Old 11-30-2004, 05:11 AM   #25
five-0
five-0's Avatar
Default Re: ...G23 VTEC...(56K...Definitely Beware) (95cxh22a)
Man, this is some really good stuff. It's good to know that there are options.... thanks to those that aren't afraid to try something different. Pirate SamIam
God I love the 4th gen. [img]http://images.honda-tech.com/set1/smile/emwink.gif[/img]
Si4WS*2.3L*H22 appatite*
[I]Good sellers: SKDRCR, 92LudeSI[/I]
five-0 is offline   Reply With Quote
belt, build, frank, g23, h23, honda, key, limit, numbers, power, rev, timing, turbo, vtec, wiki, woodruff
